Arborwear
Author Topic: Kohler engine won't start  (Read 3176 times)
Offline BadgerJim
« on: May 04, 2017, 09:53:44 PM »
I pulled my LT40 Hyd out of the shed for the first time since last fall, put in fresh gas, engine won't start after extended cranking.  Pulled spark plug and it appears dry.  This is the 29 hp ECH749 EFI engine.  Doesn't appear to have any suction pulling gas out of tank.  Not a lot of hours on this engine. I don't see a fuel pump on this engine.
Any suggestions?
Offline Oliver05262
Re: Kohler engine won't start
« Reply #1 on: May 04, 2017, 10:13:53 PM »
  Put a small amount of gas right in the carburetor and try it. I usually have to do this with small engines the first startup of the season. Should be OK after the initial run.....
  Usually a few squirts of gas from a pump oiler or a small bottlecap full will be all you need to get her to snort. Might have to repeat once or twice before it will stay running.
If a tree falls in the forest, and then springs back up again; do the squirrels freak out?
"Abandon hope, all ye who enter here"
Offline Bluejay27
« Reply #2 on: May 04, 2017, 10:19:17 PM »
If it's the same as our '08 LT40HD (28hp), the fuel pump is mounted under the fuel tank mount, inside the cover for the up/down motor. If it's fuel injected, then it should have the electric pump. Does it run if you spray starting fluid in the intake?
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
Offline BadgerJim
« Reply #3 on: May 04, 2017, 10:32:17 PM »
thanks for the suggestions. It is the electronic fuel injection. I have not sprayed starting fluid into the air intake nor have I put any fuel in the carb. I don't think it has a carb being EFI.
I was going to get some starter fluid, a new fuel filter and will take a look at the fuel pump tomorrow.
Thank you both for the quick replies.
Offline carykong
  • Installing my roof ridge metal
    • Have Mill Will Travel
« Reply #4 on: May 04, 2017, 10:37:28 PM »
Sea foam! It's magic
Offline pineywoods
« Reply #5 on: May 04, 2017, 10:46:17 PM »
Look at the O ring seal in the fuel line quick disconnect. O ring shrinks due to alcohol gas allowing the fuel pump to suck air instead of gas..Had this problem more than once..
Offline greglwood
  • I used to be new
« Reply #6 on: May 04, 2017, 11:13:55 PM »
This happened to mine about 4 months ago. It turned out to be the fuel pump. Even though it was pumping fuel it was not pumping at a high enough pressure. In my case it was fixed under warranty. I believe that engine has a 3 year warrenty.
Offline BadgerJim
« Reply #7 on: May 04, 2017, 11:25:46 PM »
it definitely seems like a lack of fuel problem to me. Both the o-ring and the faulty fuel pump sounds like strong possibilities I'll check out in the morning.
Thank you all.
Offline sawguy21
« Reply #8 on: May 04, 2017, 11:45:53 PM »
Leave the starting fluid for the diesel, that is one of the worst things you can do to a gas engine. A squirt of fresh gas is far better.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #9 on: May 05, 2017, 01:28:35 AM »
I agree 100 percent...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: May 05, 2017, 06:49:17 AM »
I'd bet that this is your problem!
I always keep spare O-Rings for the quick disconnect!
~Chuck~
I LOVE MY SAWMILL
Offline tacks Y
« Reply #11 on: May 05, 2017, 07:47:34 AM »
You guys running gas with alcohol????
Offline Chuck White
« Reply #12 on: May 05, 2017, 08:46:51 AM »
Not Me!!!!    :o
I only run 91 octane!   :P
~Chuck~
I LOVE MY SAWMILL
Offline sealark37
« Reply #13 on: May 05, 2017, 08:54:40 AM »
If you are running fuel containing ethanol, you should find a source of ethanol-free fuel.  This gas is called "recreational fuel" in some areas.  It is easily found in areas near lakes and rivers.  It cost more per gallon, but it avoids many problems caused by alcohol in your fuel system.  Ethanol has no place in engines that don't run daily.   Regards, Clark
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #14 on: May 05, 2017, 09:46:53 AM »
Quote
Ethanol has no place in engines/gasoline.....period.
Offline paul case
  • Original wearer of the PCM.
« Reply #15 on: May 05, 2017, 03:47:01 PM »
Quote
All the more reason to saw something every day , Right?
PC
pc
Offline Grandedog
    • Left Coast Supplies
« Reply #16 on: May 05, 2017, 05:15:56 PM »
Howdy,
That engine should be able to throw a code for you. You turn the key on and off twice, and then turn it back on. Red light should start flashing to give code. The owners manual should have the failure code descriptions.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #17 on: May 06, 2017, 08:17:59 AM »
Blasted ethanol I hate the stuff and never use it in my small engines.
I use the Marine Blue Stabil if I know the mill is gonna sit (which it has been).
I also add a little 2 stroke oil to the fuel when I'm running, just to add a little
"slippery" to the fuel.
D
Offline Saga Dan
« Reply #18 on: August 25, 2017, 07:13:23 PM »
Was there any solution to the problem with this engine not starting?  I am interested since I am experiencing the same type of issue with my ECH749 26.5hp engine.  Have not used it for a while...went to use it the other day and it started up like a champ and ran for a couple minutes then died.  I am guessing there was fuel in the electronic pump that allowed things to run for a little bit...    I did not have any fuel in the tank while stored and started with fresh gas now.  Engine cranks,  I have spark, can get it to run momentarily when adding 50:1 mix to the cylinders through plug hole.  Electric pump does cycle on for a couple seconds upon key turn.  Never used anything except 91 octane non-ethanol gas.  Originally checked fuel lines use to pulse pump on valve cover.  Blew gas back to tank checked tank and pickups.  Installed new filter.  Sucked gas back up to just the bottom of new filter.  Pulse pump was dry at this point, cranked and no change to fuel level in filter.  Removed pump and the diaphragm looked to be dry maybe a chance the "seal" was not functioning.  Added RTV sealant to top and bottom around exterior of diaphragm, reinstalled.  Still nothing past pulse pump at this point.  Called Woodmizer and they walked me through a few different things to try then deduced it was the pulse pump that needed to be replaced.  Continued to tinker and decided to do a little bit more "work".  Removed the fuel line coming out of the pulse pump and cranked a little bit...  At this point I was able to get fuel to spray out of this one.  I was able to fill the fuel line to the electric pump...no change to fuel level in the line when the electric fuel pump cycles.  Oh and to make things more interesting my MIL light is burned out (new one should be here Monday) so it is difficult to know if there are any trouble codes being thrown.  Any suggestions or resolutions.
2014 LT40 Manual; XP346; XP395; Logosol M8
Offline Kbeitz
    • My Hobbies
« Reply #19 on: August 25, 2017, 08:13:45 PM »
Any time I get an engine with a gas problem I fill an old oil pump can with gas.
I pump gas in the carb when cranking. Then you can keep pumping the oil can
to keep the engine running until the gas  gets up to the carb. If everything's
working it will sooner or later run on it's own.
10 hp. Kohler electric start engine.
Started by Woodchuck53 on General Board
Last post September 23, 2009, 11:52:09 PM
by Woodchuck53
27hp kohler won't start!!
Started by solodan on Sawmills and Milling
Last post December 07, 2005, 01:36:10 AM
by solodan
Help with Kohler engine
Started by stumpy on Sawmills and Milling
Last post September 16, 2009, 07:56:46 PM
by backwoods sawyer
Kohler 30 Hp Engine
Started by Bodger on For Sale
Last post January 20, 2012, 01:48:42 PM
by Bodger
