Author Topic: learning  (Read 407 times)
Offline coxy
learning
« on: May 06, 2017, 08:33:23 PM »
experience took the motor and tranny out of the old 440 thats been sitting for the last 12 years those trannys are a pain in the ars to get out the steering pump was also a night mare with all the hydro lines that go to that  >:(  have to figure out what I'm doing with the other parts is the motor the same as a 450 dozer non turbo  a friend wants the tranny  also are the winch pumps from a 3325 the same as a 3315
Offline snowstorm
Re: learning
« Reply #1 on: May 06, 2017, 09:08:50 PM »
440a used a 219 same as a 450 less the turbo the turbo motor has a oil cooler and lower compression pistons.the early 440 could be gas or diesel and was smaller than an a.
We're learning
Started by Ed_K on Sawmills and Milling
Last post July 20, 2003, 06:43:35 PM
by Ed_K
learning to saw
Started by edgerman24 on Sawmills and Milling
Last post August 28, 2014, 08:18:50 AM
by Jeff
Learning as I go
Started by 123maxbars on Sawmills and Milling
Last post October 24, 2012, 11:49:53 PM
by WDH
Learning some
Started by Timo on Sawmills and Milling
Last post October 15, 2005, 02:15:21 AM
by Brucer
