Arborwear
Author Topic: TRACTOR for powering Woodchipper  (Read 1759 times)
Offline snowkraft
« on: May 08, 2017, 09:07:14 AM »
I researched and bought a PTO driven woodchipper. I have the Morbark 12 inch:http://www.morbark.com/wp-content/uploads/PTO.pdf   I bought it used, with maybe 5 hours. It is new for all practical purposes. It was just about what I would have paid for the biggest Bearcat model, so super happy about that.
Anyways, need a tractor to power it. (I needed a tractor to for other things also.) I talked to a farmer friend and he recommended a closed hydraulic system. I think that was mostly based on a hydraulic driven nurse tank pump, (which I dismantled in favor of a gas pump) but also assuming a closed system is the better way to go. Are there any recommendations based on what I'll be using it for?? Is a loader good to have on the tractor?? I have 2 skid steers.
Other things I will do with the tractor:
1. Pull running gear loaded with logs. LOTS of logs!!
2. Pull a 1500 gallon nurse tank for watering transplanted trees- lots of this
3. Cut grass on 10 miles of 15 foot wide ski trail, and some thicker brush. I do have a Ferris 3200 6 foot mower which works well, so may continue using that. Tractor maaaaybe only for thicker brush
4. I have an 8 acre field- possibly will plant something
5. Possibly use for snow clearing, although I have a tracked skidsteer that may work better.
6. Possibly pull a drag on trails I'm working on to smooth them
7. Pull float in parades. Hehehheheh
I sorta think the tractor will be used mostly with the wood chipper and a few things listed above, but tractors of course are very useful, so that could change. The tractor I am looking to get is around $25,000 and a good value for the money. I have mainly been looking at Kubota and New Holland. https://www.tractorhouse.com/listings/farm-equipment/for-sale/18670751/2008-kubota-m9540  At first I was looking at a cheaper tractor, but then realized that I'll probably have this for 15 years and will get used often, so I think it makes sense to spend a bit more, get something a bit newer, more reliable and comfortable. Tractor ideally is equipped with: 1.) 4 wheel drive  2.) Loader??  3.) At least 20 GPM hyd. flow  4.) About 100 HP 5.) At least 2 hyd. hook ups. 6.) Larger front tires for less PSI on the ground on ski trail = less damage.
THANKS for you recommendations!!
http://www.forestryforum.com/gallery/albums/userpics/45568/Tank-1.jpg
http://www.forestryforum.com/gallery/albums/userpics/45568/IMG_3050.JPG
http://www.forestryforum.com/gallery/albums/userpics/45568/IMG_3054.JPG
Offline nativewolf
Re: TRACTOR for powering Woodchipper
« Reply #1 on: May 08, 2017, 12:58:25 PM »
Many PTO implements give you HP ranges required to drive the implement and then the maximum HP you can safely have on the tractor.  Do you know what the max is for your chipper.  Sounds like a great great chipper, you can go professional just with that machine and a chainsaw...and insurance.
Offline ljohnsaw
« Reply #2 on: May 08, 2017, 07:24:27 PM »
Here you go!  Big enough front tires! ;)
Doesn't have a 3-point but has a draw bar, TWO pto's (one looks like a drive line yoke) and two hydraulic quick disconnect pairs on the rear.  And from the color, it looks to be a Case so it has to be good!
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #3 on: May 08, 2017, 08:34:23 PM »
I think one of the qualifications for running it in a parade is, it has to be shiny. :D  smiley_thumbsdown
Offline snowkraft
« Reply #4 on: May 09, 2017, 09:05:49 AM »
I called Morbark and got some grouchy guy who I think thought I was supposed to know more than I do about tractors and equipment. He would give me absolutely no specifics. I USE equipment, but am one of the most non-mechanical people there is. I don't KNOW equipment!!
Johnsaw- the tractor gives me a backache just looking at it. It would get egged at a parade.
What about open vs closed hydraulic system??
Offline nativewolf
« Reply #5 on: May 09, 2017, 09:19:13 AM »
Man, That is not Morbark's best advert.  It is a simple question too, just how many HP is this rated?  Perhaps a user manual?  Should be fairly readily available as using with too high a HP will be dangerous.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #6 on: May 09, 2017, 09:28:46 AM »
I was raised on a farm (fifth generation).  We have several tractors that we use regularly.  Newest is a 2755 Deere (Not really new by any means  :D).
I have no idea which ones have closed or open hydraulics or advantages/disadvantages.  I'm thinking open/closed may be closer to a Ford/Chevy/Dodge debate than something that matters.
Offline TKehl
    • Kehlhof Ranch
« Reply #7 on: May 09, 2017, 09:41:22 AM »
OK.  I got curious and had to look up closed versus open.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=65791
Still couldn't tell you which tractor had which without looking up model #s.
Offline Puffergas
    • Puffergas
« Reply #8 on: May 09, 2017, 12:34:11 PM »
I think my JD 510 backhoe was closed. Sounded like the hydraulics were always working. It would respond fast and this seems to be the modern direction - high performance. I'm old so I lean toward the simpler, slower, more efficient open system.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline loganworks2
« Reply #9 on: May 09, 2017, 02:05:46 PM »
If you go to the lik you gave for the chipper it says in the specifications 50 to 100 hp for the 12" chipper. All the specifications are right there.
Offline snowstorm
« Reply #10 on: May 09, 2017, 03:43:41 PM »
Open center is not more efficient.  It uses more h p.and makes more heat. Closed center flows only enough oil to do the job. When no flow is needed the pump destrokes going to very little flow. If it takes 10 gpm ..   to operate one cylinder that's all it pumps if you want to use 3 at once it may pump 30. Multifunction is way better with closed center
Offline nativewolf
« Reply #11 on: May 09, 2017, 04:33:15 PM »
So you are looking at a smaller MFWD.  The smaller older case MFWD, like a 7110 would have been nice but frankly they are under reporting PTO HP on the older magnums so they are likely to have 120HP at the PTO and that would be too much.
If you want to save money look for an aesthetically nice tractor from the next RB auction in Tipton CA-best discount in the market but you need to get to CA and look at them (always fun to go to CA for something).  Or look for tractors in AL, LA, MS, Arkansas.  Often they are at a discount.  Prices in Canada seem high right now and I'm going to punt the other recommendations over to Bargemonkey and others that really watch auctions and know their stuff.  I'd like an armored orchard tractor used in the walnut/almond business from CA.  Those tractors are low, narrow, and armored up so they are good for forestry work (i hope).  You may find one of those for 20k  without the armor in Tipton (RB site is very nice and you can look up prior auction prices once you set up a free account).
Offline TKehl
    • Kehlhof Ranch
« Reply #12 on: May 09, 2017, 05:45:46 PM »
Do the orchard models have belly pans?  ???
I've never been around one, but from the pictures I assumed they just had more exterior sheet metal to keep from snagging branches when driving between rows.  Seems like the newer ones are even lowered somewhat, IE less ground clearance.   ???
I guess I'd have to see one in person, but from what I've seen, I'm not inclined to look for one.   :-\
Offline gspren
« Reply #13 on: May 09, 2017, 06:57:26 PM »
  My JD 2355 (1988?) 55 Horse power has a closed center as I think most modern JDs did. My old JD 620 (1956) has an open center. Auxiliary equipment such as a log splitter needs to have a valve to match either open or closed, some valves are convertible by adding a plug.
Offline nativewolf
« Reply #14 on: May 09, 2017, 08:39:50 PM »
They have low ground clearance but do have some armor underneath.  The ones I'm interested are basically forest logging ready, sides have protection, radiator protected, windows are protected.  They are meant to be driven through branches all day long, they'll have 4-8k hours on them before auction.
Offline Gearbox
« Reply #15 on: May 09, 2017, 10:13:25 PM »
I think with a 100 HP tractor you are going to turn that chipper inside out . Hundered HP is a large heavy tractor with a loader you will be over 10,000 pounds .
Offline nativewolf
« Reply #16 on: May 09, 2017, 10:20:11 PM »
This is just one example of the orchard tractors used in CA fruit nuts.
Offline TKehl
    • Kehlhof Ranch
« Reply #17 on: May 09, 2017, 10:27:41 PM »
Now we're talking about something!   :o  I was working off image search and memories of restored tractors in Farm Show.   :D
However, protecting that PLASTIC fuel tank under the cab would be the first order of business before leaving orchard grass for the woods.  Tanks like this I've been around have actually been fairly resilient, but one sharp stick at the wrong angle = a bad day.   ;)
Offline ChugiakTinkerer
« Reply #18 on: May 10, 2017, 02:29:59 AM »
I thought I recognized that design from somewhere...
Woodland Mills HM130
Offline nativewolf
« Reply #19 on: May 10, 2017, 08:41:27 AM »
It is funny they didn't have the tank protected.  Some of the tractors used in the orchards are even wackier but I never thought of renting to someone making a mad max movie!
So there you go, my best idea on how to get a forestry tractor pretty much setup (ok-fuel tank still to be done-maybe more belly work too).  That sold for 12k I think.
powering a bandmill
Started by jay wyant on Sawmills and Milling
Last post March 23, 2006, 09:34:03 AM
by jrokusek
Powering a 30" bucksaw
Started by tyb525 on Firewood and Wood Heating
Last post October 27, 2014, 03:14:35 PM
by DeerMeadowFarm
Fire Star II Not powering up
Started by joe12willy on Firewood and Wood Heating
Last post October 23, 2016, 12:56:30 PM
by joe12willy
Woodchipper question
Started by alecs on General Board
Last post August 05, 2013, 04:49:07 PM
by Roxie
