Arborwear
Author Topic: GFI issue  (Read 1577 times)
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
GFI issue
« on: May 08, 2017, 09:28:34 AM »
A week ago one of my GFI's started tripping. All that is on this circuit is my beer box. There are 5 outlets but nothing except the refrig was plugged in.
I swapped out the GFI and installed a mechanical ground but it still tripped. I opened the breaker box, checked all the connections for tightness including grounds, common and feed didn't find anything loose. Still tripped.
I replaced the other 5 receptacles, still tripped.
Wire is in metal conduit, never an issue before.
Any ideas?
The First 60 years of childhood is always the hardest.
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: GFI issue
« Reply #1 on: May 08, 2017, 09:41:04 AM »
Does the GFI trip when the refrigerator is not plugged in to this circuit? ie, when there is no load attached to the circuit at all???
Offline ljohnsaw
Re: GFI issue
« Reply #2 on: May 08, 2017, 09:50:22 AM »
I have a light and fan in my shower stall on a GFI.  When the conditions are right (very cold and damp - raining), my hot shower produces a LOT of steam.  That trips the GFI.  Also, if I sloppily hit the two switches and they toggle on/off/on very quickly, that trips the GFI.  Perhaps there is some moisture in or around the electrical connections?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Raider Bill
Re: GFI issue
« Reply #3 on: May 08, 2017, 09:59:18 AM »
yes,
I plugged the fridge into another GFI circuit and it works fine.
Offline rjwoelk
    • countrysidefirewood
Re: GFI issue
« Reply #4 on: May 08, 2017, 10:07:02 AM »
I would say either a short in your wireing someplace or a bad gfi.  Had one that trip all the time back in the 80's replaced no problems after that. We have 5 in my sons cabin no issues. That said you have tried the applance in a different circit and it is ok. So change the GFI and see.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline JJ
  • Gotta figure this out
Re: GFI issue
« Reply #5 on: May 08, 2017, 01:00:44 PM »
Replace the breaker in panel.
Resistive connection from corrosion in the breaker can trip the GFI even before your circuit becomes intermittent.
      JJ
Offline Raider Bill
Re: GFI issue
« Reply #6 on: May 08, 2017, 01:48:17 PM »
Actually the first indication I had of a problem was the breaker tripping then the GFI started popping but the breaker only tripped that 1 time.
It's off to the breaker store I go, I go!
Offline DFILER2
Re: GFI issue
« Reply #7 on: May 09, 2017, 01:00:28 PM »
A GFCI works by measuring the amount of current flowing from the hot wire to the neutral wire. If this differs by 4-5 milliamps the breaker in the GFCI will trip. The problem will be with what is plugged into the outlet or an outlet connected to the load side of the GFCI. Did you make sure you connected the wires coming from the fuse panel to the "LINE" side of the GFCI? Refrigerators are known for causing this problem even after running fine for years, I believe it has something to do with the fact that the motor wears out some and that it is turning off and on. Here is a link to an article from someone with a similar problem.
 https://diy.stackexchange.com/questions/53252/why-is-gfci-tripping-on-refrigerator-circuit
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: GFI issue
« Reply #8 on: May 09, 2017, 10:30:01 PM »
Using your ohm meter, check if there is continuity between your GFCI outletís ground, and the white and black wires. If you get continuity from disconnecting the white and black wires then the problem could be that the white and black wires are touching with the bare ground.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Re: GFI issue
« Reply #9 on: May 10, 2017, 07:36:21 AM »
Time for a new gfi breaker
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Raider Bill
Re: GFI issue
« Reply #10 on: May 10, 2017, 09:26:21 AM »
First thing I did was put the refridge on another circut with no problems, then I changed out the GFI, then all the outlets on that circut and then the breaker.
There is nothing plugged in.
I have 1 junction box I haven't opened up yet that will be this afternoon.
This was wired 13 years ago when I put the addition on my house. Never had a problem.
Re: GFI issue
« Reply #11 on: May 10, 2017, 10:46:25 AM »
Of course, the cause of the problem will be in the last place you look...
After all, why should you keep looking after you get it fixed?
Good luck!
Be Careful!
Herb
Offline DFILER2
Re: GFI issue
« Reply #12 on: May 10, 2017, 12:49:02 PM »
When you say you tried the refridge on another circuit, was that circuit also GFCI protected?
Offline Raider Bill
Re: GFI issue
« Reply #13 on: May 10, 2017, 01:37:02 PM »
Yes.
Offline DFILER2
Re: GFI issue
« Reply #14 on: May 11, 2017, 09:21:43 AM »
The next thing I think I would try would be to disconnect the outlets on the "load" side of the GFCI to see if that cures it.
Offline Raider Bill
Re: GFI issue
« Reply #15 on: May 11, 2017, 09:45:06 AM »
I got up in the crawl space to look at the junction box and saw another run of conduit coming out of it so I followed that to a receptical that I thought was on another circut. Opened it up and there was a bunch of corrosion so I replaced the recep, cleaned everything up. Still powered up this morning so I'm thinking that was my problem.
The lights are still on and all my soldiers are Happy, Happy, Happy!
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: GFI issue
« Reply #16 on: May 11, 2017, 05:40:42 PM »
I love the way you have decorated that space!
If it is true that we learn from our mistakes, I must be Brilliant!
Offline samandothers
Re: GFI issue
« Reply #17 on: May 11, 2017, 05:51:16 PM »
Good to see a balance of orange juices with the other items.
Offline DFILER2
Re: GFI issue
« Reply #18 on: May 11, 2017, 07:12:54 PM »
Glad you found the problem:)
Offline Raider Bill
Re: GFI issue
« Reply #19 on: May 22, 2017, 03:51:37 PM »
Update,
Everything was working good. Beer box cooling away.
Left a week and a half ago to go see my Daughters in Il.
Come back late last Thursday it was popped. Ran an extension cord, left for Jake's.
Back to the drawing board.
Maple log issue...
Started by mrcaptainbob on Ask The Forester
Last post July 03, 2010, 11:51:23 PM
by mrcaptainbob
new banner issue
Started by Ga Mtn Man on Technical Support Topics
Last post October 29, 2014, 08:44:09 PM
by Ga Mtn Man
290 oiler issue
Started by pabst79 on Chainsaws
Last post May 10, 2015, 12:59:56 PM
by joe_indi
computer issue
Started by drobertson on General Board
Last post March 22, 2015, 06:12:07 PM
by drobertson
