Arborwear
Author Topic: WM 1998 Setworks  (Read 2203 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
WM 1998 Setworks
« on: May 08, 2017, 01:21:27 PM »
Of course this Setworks has be manufacture discontinued for many years and parts are no longer available.  My display died in 2010 and new displays were still available at that time so I replaced the old display.
Well, while I was sawing Saturday the display started showing gibberish and then went blank.  Setworks still works and still responds accurately to the 4 buttons but the display unit apparently is gone.  I unplugged/replugged and all of that stuff.
So what to do?  Maybe someone that has changed their Setworks to Accuset still has their old display or if not, my next move will be to upgrade mine to Accuset II.  I realize that it is inevitable that it will eventually happen, but ~$2500 is hard to spend if there is an alternative.
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: WM 1998 Setworks
« Reply #1 on: May 08, 2017, 01:53:57 PM »
MM, open it up and give us a pic of the actual display.  It may be a common LCD display module that is cheap and easy to replace.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Delawhere Jack
  • I ought to know better.....
« Reply #2 on: May 08, 2017, 05:24:45 PM »
I'm with GMM on that. Find a part number on the display and do an Internet search.
https://www.digikey.com/products/en/optoelectronics/display-modules-lcd-oled-character-and-numeric/99?k=LCD%20display
954 results. And then there is eBay.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: May 08, 2017, 05:44:47 PM »
Thanks guys.  I may have a fish nibbling at my cricket already.  I should know this week.   ;D
Here is a LINK to the topic where I did the replacement in 2010.  Paul, the display is shown at the top of the first picture.
Offline Ga Mtn Man
« Reply #4 on: May 08, 2017, 07:29:48 PM »
Hope you can reel him in...that display may be hard to find.  The white sticker on it probably has the manufacturer and part number.
If your fish throws the hook (sorry, I had to keep it going ::)), give me the dimensions of the board and the mounting hole spacing.  I may have a display that we could make work.
Online barbender
« Reply #5 on: May 08, 2017, 07:58:06 PM »
MM, I also have the old setworks. Mine currently has an encoder issue, it's either the encoder itself or the plug in on the back of the display (which I suspect it is). The new encoder and cable was almost $600, and while it's still available, it's kind of a hard pill to swallow, since the rest of the system is not supported. I still want to fix it, I just haven't had the time. I did get a kick out of your "fish nibbling at my cricket" statement, that has to be an "old saying"?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: May 08, 2017, 09:20:36 PM »
I replaced the encoder last year so this baby has no choice but to keep on working.  Not is not an option.   :-X
Online barbender
« Reply #7 on: May 08, 2017, 11:30:45 PM »
My setworks has always had some accuracy issues, that I was just finally getting resolved when this new problem reared it's head. Thus, I am somewhat hesitant to put any money into it, being that it wasn't working well in the first place.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: May 09, 2017, 09:16:31 AM »
I have a '98 WM Setworks.  That would be of no use to me whatsoever.
Offline Kbeitz
    • My Hobbies
« Reply #10 on: May 09, 2017, 09:20:14 AM »
I tried....
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: May 09, 2017, 09:24:59 AM »
I know, and I guess that my response sounded sharp.  Please accept my apology.   :)
Online LeeB
« Reply #12 on: May 10, 2017, 09:54:20 AM »
Following this. My display is also about to give up the ghost. Already replaced it once. Can't remember how much it was then.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #13 on: May 10, 2017, 10:02:47 AM »
I have another display on the way.  Well sorta.   ;D
Offline Ga Mtn Man
« Reply #14 on: May 10, 2017, 12:20:43 PM »
Does the display happen  to have a  2   on the front panel? :)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #15 on: May 10, 2017, 01:12:52 PM »
I wish, but with the FF there are rabbits in the hat sometime.   ;D
Offline Ga Mtn Man
« Reply #16 on: May 10, 2017, 04:35:04 PM »
You're gonna make us wait for the pics, aren't you?  You are a very bad man.
Online barbender
« Reply #17 on: May 10, 2017, 09:50:45 PM »
Well, through all of this, one of three of us should end up with a working original Setworks :) We  could have just drew straws, the lucky man gets the other's components  ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #18 on: May 19, 2017, 05:49:27 PM »
  Yes, I am a bad man.   :)
Although the new display showed MD and not available from Wood-Mizer, I contacted Sparks and he did some investigating.  He found two displays in stock but not tested or packaged for sale.  Yup, after the necessary bench testing and packaging I received my new display today.
Out with the old and in with the new.
Yeah, I am back in business, but this is the last time for this Setworks.  Because of this topic, the other new display was also sold so there is nothing in stock to repair this unit again.  I was offered a removed Setworks which could be an option in the future, or not, because it could be gone by then.
Anyway, my Thanks to Sparks!
Offline grouch
  • I'm recyclable!
« Reply #19 on: May 19, 2017, 06:31:36 PM »
The only thing I can make out on the back of the LCD is EDT 20-20033-2 Rev. C. It looks like there is a white sticker with more writing, but I can't read it.
There could be later but still compatible displays being made.
Find something to do that interests you.
Going right through 1998 WM 40 Hydaulic.....
Started by linrick1 on Sawmills and Milling
Last post February 02, 2009, 07:58:29 AM
by linrick1
Milling Big Red Oak, cut it down in 1998, STILL beautiful inside
Started by Ironwood on Sawmills and Milling
Last post May 23, 2005, 07:02:15 PM
by Ironwood
1998 Timberjack 608B computer
Started by Mike_M on Forestry and Logging
Last post March 08, 2018, 09:45:57 PM
by Mike_M
1998 F800, Diesel, 24,500 GVW, 14' flatbed, includes parbuckling $7,500
Started by sgschwend on For Sale
Last post May 31, 2012, 03:06:15 PM
by sgschwend
