Arborwear
Author Topic: WM 1998 Setworks  (Read 2202 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: WM 1998 Setworks
« Reply #20 on: May 19, 2017, 08:28:51 PM »
I'm sure that Accuset 2 will be the next modification to go on this sawmill, but for now $100 was much easier to spend than $2500.   ;D
Online LeeB
« Reply #21 on: May 19, 2017, 10:03:23 PM »
I think I know where the display ended up but I won't be able to be sure until I get back from work this time.   ;)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #22 on: May 19, 2017, 10:19:32 PM »
I'm sure that it is there Lee.   :)
I am just hoping that the display was my problem and not something else, but at least it is now working.  I will do whatever it takes to keep my sawmill running.
Offline grouch
  • I'm recyclable!
« Reply #23 on: May 20, 2017, 05:44:34 AM »
Quote
Showing closeups of the front and back of those 2 printed circuit boards may help.
I found several 4x20 LCDs in a quick search but don't know if they are pin- or signal- compatible with yours.
Find something to do that interests you.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #24 on: May 20, 2017, 06:05:27 AM »
It's good your up and running, Now back to work. :D :D :D :D 8) 8) ;)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Online LeeB
« Reply #25 on: May 20, 2017, 02:25:50 PM »
It showed up yesterday afternoon but I didn't have any chance to install it. It will wait 'til I get home. The old one still works somewhat but has some moisture trapped in it and is all but impossible to read when the sun is shining on it. If the humidity is right and the sun isn't bright you would not know there was anything wrong with it. I may try to see if I can fix the old one and have the new as a backup.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #26 on: May 20, 2017, 02:28:39 PM »
It sounds to me like there is dust and moisture between the display and the faceplate.  You may only need to remove the display and use some Windex and paper towel.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #27 on: May 20, 2017, 02:45:07 PM »
Had moisture in my Accuset display many times and finally last March took it out and put it on the mantle over the weekend,  which cleared it up.  We had the wood stove going so it was a very dry place.  The moisture in the display problem hasn't come back yet.
I also have times when the display is barely visible in direct sunlight.  When this happens I by wipe the display with a drop of ATF.   Originally once I had skin so soft on my hands (I was sawing with skeeters and use this as repellent) and was wiping the display in frustration and this made it much more visible.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #28 on: May 20, 2017, 04:24:08 PM »
The Setworks display and the actual faceplate are about 1/8" apart so there is almost 20 years of accumulation between the two.  It would sorta be like the film that forms on the inside of your windshield plus the powdered sawdust.   :-\
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #29 on: May 20, 2017, 07:11:08 PM »
I'll have to try the atf. Its got to be better than licking my finger and rubbing it on the display.  ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #30 on: May 20, 2017, 07:17:50 PM »
No wonder it didn't work Dave.  You were licking the ATF off of your finger.   :o
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #31 on: May 22, 2017, 08:34:53 AM »
I'm glad you got it going Lynn, and for not too much $ :).  If you'll send me the old display, I'll see if I can do anything with it.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #32 on: May 22, 2017, 08:41:23 AM »
Thanks Paul.  I know that I have it but shoot me your address again.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #33 on: June 11, 2017, 04:17:47 PM »
I sawed two jobs this past week with no display issues, so for now the $100 decision seems to have been a good one.   :P   8)
Going right through 1998 WM 40 Hydaulic.....
Started by linrick1 on Sawmills and Milling
Last post February 02, 2009, 07:58:29 AM
by linrick1
Milling Big Red Oak, cut it down in 1998, STILL beautiful inside
Started by Ironwood on Sawmills and Milling
Last post May 23, 2005, 07:02:15 PM
by Ironwood
1998 Timberjack 608B computer
Started by Mike_M on Forestry and Logging
Last post March 08, 2018, 09:45:57 PM
by Mike_M
1998 F800, Diesel, 24,500 GVW, 14' flatbed, includes parbuckling $7,500
Started by sgschwend on For Sale
Last post May 31, 2012, 03:06:15 PM
by sgschwend
