Arborwear
Author Topic: Sawdust catcher  (Read 1032 times)
Offline 78NHTFY
  • I'm old!
Sawdust catcher
« on: May 09, 2017, 07:54:35 PM »
Scraping sawdust off hardpack was getting old, so I banged out a sawdust catch that should make my life a little easier: two old pieces of 5/8 plywood, a few hinges and some left over scrapwood.  Now that wasn't so hard Rob, was it? and a lot more comfy to walk on!!:D
 .  And yes, I sometimes cut the little stuff to make 4 x 4's, ever since I cut a bunch and a guy bought all I had for $ 5 each!  All the best, Rob.
If you have time, you win.
Offline paul case
  • Original wearer of the PCM.
Re: Sawdust catcher
« Reply #1 on: May 09, 2017, 08:54:13 PM »
We actually made a whole floor under my mills so that we could use a leaf blower to clean out under them. WE use blowers for our sawdust, but depending on how much you saw you might be able to blow that off.
PC
pc
Offline MikeON
Re: Sawdust catcher
« Reply #2 on: May 10, 2017, 06:52:38 AM »
I did something similar to the OP but made it wide enough for the 5' bucket on my  tractor to gather up the sawdust.
Woodmizer LT40HD Super.  WM Single Blade Edger,  John Deere 4310 tractor, M35A2C Deuce and a Half truck
Offline 78NHTFY
  • I'm old!
Re: Sawdust catcher
« Reply #3 on: May 10, 2017, 11:12:46 AM »
MikeON--that's my plan too: the 2' section should fold down when I remove the 4 supports and then I can scoop up with my tractor loader.
Offline 78NHTFY
  • I'm old!
Re: Sawdust catcher
« Reply #4 on: July 15, 2017, 08:55:45 AM »
Yo Paul--based on your suggestion, found my old Toro leaf blower and am now a sawdust blowing fool 8) 8).  What a difference: the blower gets in all the nooks and crannies and no more time with that little brush trying to clean up the mill! Better late than never (have owned my mill since 2003!).  Thanks Paul.  All the best, Rob
Offline paul case
Re: Sawdust catcher
« Reply #5 on: July 15, 2017, 09:48:26 AM »
 thumbs-up
PC
pc
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Sawdust catcher
« Reply #6 on: July 19, 2017, 03:50:42 PM »
I always thought about using a good quality tarp then dragging it to a pile to dump. This is nice though.
I knew what I thought I meant.
Nail Catcher
Started by thiggy on Sawmills and Milling
Last post November 04, 2005, 07:48:49 AM
by JP
You have to pay for the sawdust
Started by Sawyerfortyish on Sawmills and Milling
Last post April 02, 2005, 10:01:47 AM
by DonE911
I want to use all my sawdust !
Started by farlet on Alternative methods and solutions
Last post December 27, 2010, 10:51:12 PM
by Warren
Sawdust
Started by timberbeast on Forestry and Logging
Last post December 06, 2001, 05:16:28 AM
by Frank_Pender
