Arborwear
Author Topic: old man on a roof  (Read 1465 times)
Offline grouch
  • I'm recyclable!
Re: old man on a roof
« Reply #20 on: May 15, 2017, 04:26:28 PM »
It took 3 days to staple the 30 lb roofing felt on the east side, snap chalk lines, make a chicken ladder, remove ridge vent and fully screw down 5 sheets of roofing. Each sheet was dragged the full length of the ramp, one at a time. That had to change.
I'd already had a longer stretch of fair weather than was reasonable to expect -- even the wind hadn't gotten above 5 mph.
Then it rained, followed by wind gusts of 15 mph. But only for 1 day.
The whole stack inching up the ramp, courtesy of a 2 inch tie-down strap (3335 lb w.l.l.), some 3/8 inch chain, a 1900 lb capacity boat winch with wire rope, a come-along, a maple tree and some cardboard:
Can you see the wire rope and chain?
Whole stack to the eave:
There's the hook end of the 2 inch strap with a cardboard cushion:
No more crab-walking up those blasted 2x4s two feet apart while dragging a 23 ft sheet of steel one-handed:
That's the top of the maple tree in the background. The wire rope on the boat winch goes over the ridge, hooks to a 3/8 chain which hooks to a 1/2 inch chain which wraps around the trunk of that tree.
The edges of my cardboard track for dragging sheets up the roof were starting to curl from the rain the day before. Had to re-staple. Only stepped on that once and didn't fall or let the sheet go back down the hill much.
Find something to do that interests you.
Offline coxy
« Reply #21 on: May 15, 2017, 07:53:44 PM »
in the first pics I was wondering what heck you where building  :D but I understand now and I would have never though of that  when my dad did the roof for the house we picked it up with the log loader the first few units was a pain till we got it right on the last few units  :) but that's the way it goes    are you done with it or just start it  the metal I nailed was the same as your using    the nails was a lot cheaper  for a young guy with his first kid on the way now every thing gets screwed much easer to take apart when you mess up and I do it a lot never clamed to be a carpenter and never will :D :D
Offline grouch
  • I'm recyclable!
« Reply #22 on: May 16, 2017, 01:16:16 AM »
coxy:
Nothing I have would lift that metal high enough to get it on the roof. I had to go ancient Egyptian and build a ramp. I just used wood instead of sand and mud. :)
That last photo was taken 2016-10-28. During the time this was going on, I had blinders on. Weather and that roof totally occupied me from the time I'd get up until the time I went to bed. Normally when I grab my camera, I take photos of everything that catches my eye on the way to whatever made me grab the camera. There are hardly any photos of anything but that roof for that whole time period.
I used an impact driver for running the screws in. I've seen people use drywall screwguns and rely on the clutch setting, but that usually results in over tightened, under tightened and broken screws. Every screw in this roof was run in until the rubber washer touched, then backed out to let everything relax, then run in until the washer compressed properly. There's no substitute for a person's eyeball and judgment for some jobs, in my opinion.
Well, until they make a cheap robot that measures torque and the bulge of the washer while running in the screw. Even then, I'd want somebody (who has an interest in the job) watching the robot.
Offline grouch
  • I'm recyclable!
« Reply #23 on: May 16, 2017, 12:37:36 PM »
The day after getting the stack to the top of the ramp was Saturday and my son was on the scaffold helping align sheets most of the day. Got 7 sheets put on that day. 4 were only partially screwed down -- I wanted to get as many aligned and 'tacked' as possible while he was there. Not even pictures from that day.
My ox was in the ditch, so I finished off the east side on Sunday and started the felt on the west side.
My homemade scaffold in all its glory:
And the outriggers...
What? You don't have any clutter in your back yard?
All the wheels were off the ground. The outrigger in the lower left of the picture is sitting on a 9x10 block that's sitting on a pair of 6x6s with some 2xsomething chunks at their ends. Scaffold was level, plumb and more stable than any I've worked from.
A strip of plastic was used to close up the ridge vent at night.
That lump in the middle of the ridge is where my "Fall Protection Kit" is anchored to the trusses inside with a 1/2 inch log chain.
I used 3/4 inch pipe insulation tied to the rails of the chicken ladder to avoid scratches. The ladder is anchored to the railing at the eave of the other side of the roof.
Pretty straight:
The anchor rope (actually, 2; I like redundancy) passes through the hollow rung of the ladder.
That dimpling is not caused by overtightened screws; it's from the shingles underneath. Some people object to that look and remove the shingles first. From the ground, you have to be looking for it to notice. Doesn't bother me at all.
That oak tree is an old buddy. Was practically a sapling when we moved here.
Screws are 24 inches on center, eave to ridge, measured and marked but *not* pre-drilled. Drilling the holes can cause leaks and damage the coating from heat and chips. Manufacturer claims graphite pencil marks can lead to corrosion, so a Sharpie was used for marking.
Any one of the 12 strands holding that lower ladder section to the upper could hold my weight.
Hmph. Bad photographer. I swear that lump is what anchored my fall protection rope and harness.
Ok, a distraction from the (other) bad photography -- shot looking down from the scaffold:
That's a 3v 3/8 geodesic dome with 11.82 ft radius (close enough for me to 24 ft diameter), made out of 3/4 inch conduit. My wife hangs plants from it. I just wanted to build one. The maroon thing is yet another project: 1984 Mercedes 300D turbo diesel. The engine is interesting to me. Don't care about the rest of it.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #24 on: May 16, 2017, 04:10:06 PM »
Love the country engineering and safety factors.  Roof looks great, too.
5 cylinder turbo diesel Mercedes - reported to be a 500,000 mile engine with proper maintenance.
I'm also partial to certain trees.  I've got an old black cherry close to the house that looks like hell warmed over but I refuse to cut him down.  He's my buddy.  Now and then some deer will come out in the fall and nibble on the little black fruits that fall off from him.  He stood up to the straight line 70+ MPH gust from the last storm so he can stay.  :laugh:
Where did you get the fittings to put your dome together?  It's very interesting to me... I'd like to know more about it.  Plans?  Just put together from your mind?  How strong?  If you covered it would it hold up to a couple foot deep snow load?
Offline grouch
  • I'm recyclable!
« Reply #25 on: May 16, 2017, 05:22:59 PM »
Thanks!
Quote
That's the one. It has bad injector knock until it warms up. I've tried replacing a nozzle, but me and flat copper washers have never gotten along. Now it blows bubbles around the base of that injector.
Quote
No fittings -- I crushed the ends of the conduit with an arbor press, drilled, and bolted.
Plans (sorta):
3V dome calculator.
I used 4.875 ft in the C position so I could get 2 pieces of each type from a 10 ft stick of EMT. (The C struts are the longest). That's 4 ft 10-1/2 inches center to center of the bolt holes. Add 3/4 inch to each end and that makes the cut length 5 ft even. I used a 1-1/2 inch diameter disc of mild steel to crush the ends in the press. Made for a stronger end than a squared crush. BTW, I used a 2 ft cheater on the bar of a HF arbor press and it didn't flinch.
Conduit Dome Tips. That has a wealth of info, including assembly diagrams.
As for strength, I can hang from any of those nodes without sign of bending. That 3/4 inch conduit would likely bend if I tried that between nodes. I wouldn't worry about a snow load on it. Tarp, canvas or plywood triangles, I think it'd hold up fine.
Offline Ox
« Reply #26 on: May 16, 2017, 06:02:21 PM »
Cool!  Thanks very much for the info.  Your half round crimping makes sense and I doubt I would have thought of it.
Offline grouch
  • I'm recyclable!
« Reply #27 on: May 16, 2017, 07:05:13 PM »
Crimping and drilling all those ends took the most time even though I set up jigs for each operation. I cut them in batches of 10 by banding them together with hose clamps and using a metal cutting bandsaw. It needs some kind of cover now.
Offline grouch
  • I'm recyclable!
« Reply #28 on: May 17, 2017, 07:03:25 AM »
An ominous looking cloud
Ugh. Glad I don't have to carry any more rolls of that roofing felt up 2 ladders and then the roof.
Felt all stapled down. I used a pneumatic stapler -- Surebonder something-or-other -- for this job. Got tired of having to buy a new slap stapler (hammer tacker?) every time I needed to staple felt, plastic, whatever.
I thought I had a picture of the fall harness, but couldn't find one. Here's a full crop from that last photo:
First time I've ever used one of those things. That rope clips to the back of a harness. It won't stop you from falling; it just "arrests" the fall so you don't have that possibly fatal sudden stop. That assumes you keep the rope grab caught up with you so you don't end up with enough free rope to hit the ground.
It interfered with working far less than I expected. It was well worth the price of having it while I was working on the east side of the roof.
Offline Ox
« Reply #29 on: May 17, 2017, 09:08:47 AM »
The hammer stapler you mentioned reminded me of a funny story:  I was helping the old man years ago roofing the small carriage barn, now used for parking his car and mower and firewood.  We were putting down the felt for shingles (I hate shingles but couldn't talk him out of shingling this and the entire big barn) and he was swinging that hammer stapler all over the place random like and I saw a wrinkle in the felt as he was getting to that area and quick swiped at it with my hand to flatten it and in perfect unison my hand and that hammer stapler met in the same place.  I quick pulled my hand back and looked and laughed.  That big old 1/2" staple was completely embedded in the back of my right hand, pushing the skin down hard and made it look funny.  The two prongs of the staple had missed the tendons, but were straddling my middle finger tendon just perfectly.  Well, almost perfect, I think it nicked that tendon a bit.  It was so tight in there I couldn't get ahold of it to pull it out so I had to use a utility knife blade to get under it.  Just two dots of blood and not much pain, but felt funny there for a few days when I used my fingers which made me believe it might have nicked that tendon a bit.  No infections.  Good story to tell if I remember it when I'm old on my porch rocker.
I'm enjoying following your project with your pics.  Thanks for taking the time.
Offline grouch
  • I'm recyclable!
« Reply #30 on: May 17, 2017, 11:19:26 AM »
Ow. That hurts me just reading your description. Good that you can look back and laugh at it, though. We all tend to ignore any injury that doesn't stop us from working, but that's not always a good thing.
Puncture wounds, especially, can go rotten in a hurry. Everything on the outside is suddenly pushed to the inside and trapped there. (Google cat bites if you want to see some horror stories).
Offline grouch
  • I'm recyclable!
« Reply #31 on: May 17, 2017, 11:35:51 AM »
Couple of details I left out before:
The fiberglass rods I used at the start to separate the sheets were scuffing both the underside of the sheet I was dragging and the top side of the next sheet in the stack. I switched to clamping a piece of cardboard to the tail of the sheet of roofing and slipping another piece of cardboard under the mid-point. Lifting the upper end to drag it left only cardboard in contact with the remaining stack.
The clamps were some little plastic ratcheting squeeze clamps that my wife had bought sometime, somewhere. She has this habit of buying little tools for me on a whim. Sometimes she gets junk; sometimes she finds jewels.
These little clamps (you can hide one in your hand) looked pretty useless to me at the time she brought them home. They were perfect for this task -- didn't scratch, applied only as much pressure as I wanted to squeeze, the handles held the very end of the metal up off the next one, and they slid off as the end of the sheet came off the end of the stack.
Another detail I forgot to mention before is that I swept that shingle roof with a shop broom several times. It was like trying to walk on BB's. The amount of loose granules scattered over the roof was pretty amazing. Sweeping made walking more comfortable whether or not it makes any difference to the roofing felt.
Offline grouch
  • I'm recyclable!
« Reply #32 on: May 18, 2017, 06:38:12 AM »
There were wind gusts the day after that last photo. That was only the 2nd day the weather didn't cooperate. Revised my chicken ladder from one that hangs to one that stands -- feet of the ladder against the bottom rail. Got 3 sheets screwed down when the gusts died down. Got 4 sheets plus 16 ft of ridge vent the next day. Since the ridge vent is aluminum, I put a strip of self-adhesive flashing on the bottom so it and the steel roofing wouldn't fight over who gets to turn to rust fastest.
Dreary sky, threat of rain. Halfway point on the west slope:
Weather had changed a bit since the start:
The ramp is empty:
Only half the ridge vent up, the rest is covered in plastic:
Can't use the fall protection kit if you can't anchor it. The ridge vent was installed from the chicken ladder. Late dew kept me twiddling my thumbs for a while on 2 mornings.
Offline grouch
  • I'm recyclable!
« Reply #33 on: May 18, 2017, 01:37:22 PM »
Some disassembly required. Top rails from the roof, rest from below.
Let it rain, sleet, snow, hail or drop custard pies from the sky; I'm off that roof. With a 40 year warranty, I shouldn't have to repeat this. Let the next guy deal with the sliding board.
I still have to do trim and the two other roofs, but those are R&R by comparison. I've already made hillside legs for a section of my scaffolding. That will go up on the north 6:12 roof to do the gable trim, then I'll adjust it for 5:12 pitch and set it on the south deck roof to do the gable trim at that end. (North is left in the above photos).
Done with that worry.
Offline Ox
« Reply #34 on: May 18, 2017, 01:40:48 PM »
 smiley_beertoast Well done - you don't mess around - kickin' butts and takin' names...
Offline grouch
  • I'm recyclable!
« Reply #35 on: May 18, 2017, 02:03:49 PM »
Thanks Ox!
I was just reviewing the thread to see if I'd left anything out and saw your reply. (In the house stretching lunch to avoid going back out in the heat).
Offline Ox
« Reply #36 on: May 18, 2017, 02:41:23 PM »
Yeah - it's darn hot right now.  I can swing it up to about 83 or so but when it's 92 it's just too much for me.  Can't breathe good, I'm a born sweater and will sweat while I'm shivering and so I just get dehydrated while guzzling water and salt.  Just too much, can't hack it.
I can't believe how quick you're doing that job, with all the scaffolding and everything.  It'd take me twice as long, easy.  When I said well done, I meant it!  It was quick and it looks great.  You'll have no worries until you die I reckon.  40 year warranty don't mean it'll fail at 40, just that it'll still look new at 40! I'm betting it'll do 100 years pretty good, maybe with a few coatings like the old barn roofs.
Offline grouch
  • I'm recyclable!
« Reply #37 on: May 18, 2017, 03:23:11 PM »
It's 92f where you're at today? I'm gonna quit complaining. It's 84 here, fairly nice in the shade with a breeze. Just the sun cooks my brain when I get out in it.
I started raising the posts 2016-09-21 and took 'em down 2016-11-12. Most of this was a one-man show. I had better weather than any reasonable person could hope for -- rain and wind stopped work 3 days during that whole period. The rest of the time had mild winds up to 10 mph, most days just 5 mph.
That ramp was the easiest, quickest and safest way I could come up with to raise 23 ft long x 29 gauge roofing that high without kinking, single-handed. You wouldn't believe some of the hair-brained schemes I came up with and thankfully rejected. The idea of a long ramp came to me one day when I was kneeling by the grapevine looking at the roof, thinking about the job. I noticed I could just bend down a little and sight flat along the slope from eave to ridge. If I can't bring the stack to the roof, bring the roof down to the stack.
Offline Ox
« Reply #38 on: May 18, 2017, 09:35:37 PM »
Hillbilly engineering.  I'm a hillbilly too, just not smart enough to do what you did.
Somehow I got mixed up and thought you were doing that job now, not last year.  It don't matter, the well done still stands.
Yeah, it was hotter here than in Texas today and yesterday.  One of those weird things that happens now and again in the north.  Thank God tomorrow will be back to the high 60s.  I can hack that just fine.  Got some sawmilling to do and I'm behind 2 days now cause of the recent heat.  Good thing I ain't getting paid or I might get fired!
Offline grouch
  • I'm recyclable!
« Reply #39 on: May 18, 2017, 09:57:47 PM »
When I do the rest of the roof, I'll update this thread as it goes on. The blinders and tunnel vision are over. :) I wish I could adequately describe the relief felt when that last section of ridge vent was screwed down. Normally fall is the rainy season here. Every day I expected rain to set in and last until winter. I wasn't even reading FF, just listening to NOAH weather radio.
I wish I was only behind 2 days on *anything*. Got in some mowing after moving that arch experiment. Didn't get finished. Hoping to get the arch blocked up before the heat gets bad, and finish mowing late tomorrow. In between, maybe I can saw a little.
roof'in people, is a metal covered hip roof practical?
Started by Modat22 on General Board
Last post December 15, 2005, 01:56:48 PM
by Phorester
Floating a second roof for shade above first roof....
Started by metroplexchl on Alternative methods and solutions
Last post April 21, 2018, 08:23:35 PM
by 47sawdust
Building a 6/12 roof over a 3/12 roof (need recommendations)
Started by CharlieCG36 on General Woodworking
Last post June 17, 2015, 10:53:31 PM
by Don_Papenburg
A Roof Over My Saw
Started by Kevin_H. on Sawmills and Milling
Last post November 29, 2006, 09:06:09 AM
by dewwood
