Arborwear
Author Topic: It looks easier when you watch other people do it.  (Read 622 times)
Offline SW_IOWA_SAWYER
  • I see I saw I stack
« on: May 15, 2017, 05:09:04 PM »
I love watching sawmill video's all kinds Timberking, Woodmizers, Cooks, Norwood. So when I finally decided on a different mill I went with Norwood as I had special size restrictions that limited my choices. So I bought a HD36 got it together and tried my first log.
Ok not as easy as it looked on the video's I will try it again
Ok this hydraulic control thing is going to take some getting used to, I was used to the Lumbermate 2000 this is a different way of doing it.
But when it does work out I like the results
I think my back will thank me eventually once I master the controls  :D
I owe I owe so its off to work I go....
Offline paul case
  • Original wearer of the PCM.
Re: It looks easier when you watch other people do it.
« Reply #1 on: May 15, 2017, 08:04:13 PM »
At least it was on the same side as your loader. :-\
PC
pc
Offline bandmiller2
« Reply #2 on: May 15, 2017, 08:19:39 PM »
I avoid those short stubby log chunks, I do make exceptions but usually nothing shorter than 8'. Norwood is a good mill and should serve you well. Improvements in log handling pay big dividends. Frank C.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: May 15, 2017, 08:23:54 PM »
I hates short logs.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #4 on: May 15, 2017, 08:27:49 PM »
There is a leetle bit of a learning curve, but the main this is you didn't let it get away.  Congrats, and yeah, as people are saying, short logs are a total pain.
HobbyHardwoodAlabama.com
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: May 15, 2017, 08:37:24 PM »
"Logs" less than 8' are sawed hourly rate.
Offline Percy
  • Resident trouble maker
« Reply #6 on: May 15, 2017, 08:59:42 PM »
Short logs are as miserable as the "too much diameter" ones. You gotter done without damaging the mill or busting a hip... smiley_thumbsup smiley_thumbsup
Offline Brad_bb
    • My timberframe blog
« Reply #7 on: May 15, 2017, 09:07:24 PM »
Yes, it takes a little while to realize that it takes just as much time to mill a short log as it does a long one, and you get far less out of a short log.  Beggars can't always be choosers though.  Mill what ya got, but mill the longer ones first if you want to maximize your output.  I mill 6 foot logs a lot, but I'm only cutting a flat on 2 sides to make a timber, so they are actually quick.  I'm getting pretty good (fast) with those.
Offline paul case
« Reply #8 on: May 15, 2017, 09:15:46 PM »
I hates short logs.
If I am not President of that club, I am at least an officer.
PC
pc
Offline sandsawmill14
  • love my job (most days)
« Reply #9 on: May 16, 2017, 07:02:09 AM »
i dont know if i hate short logs or not  ???  i never tried one under 8' ;D at least not that i remember ::) i have burned alot of them though :)
 and as paul said at least your log was on the loader side of the mill when i was learning the timberking the log always went on the back side of the mill  and on the s&w mill it would come off the front side of the mill but we use a log deck on it so it goes in between the log deck and mill right in the dust conveyor ::) but you will get it figured out and that will stop in a few days :)
Offline Joed
« Reply #10 on: May 16, 2017, 07:20:38 AM »
Like MM said, by the hour. I make one jig for one perticular short log, never seems to work with the next one.
TK2200
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #11 on: May 16, 2017, 09:13:35 AM »
   I have posted before how I used to hate short logs (just like I hated edging) but I have mellowed with time and experience. I salvage a lot of 5-6 foot logs on my place. We all use boards that length plus some make nice live edge benches. I agree you need to charge hourly for short logs as you do not get the production out of them. Like Brad said - it takes just as long to saw short logs as long ones. Loading a log under 5' is harder for me as it is shorter than my loading arm width in addition to the extra clamping issues/difficulties.
« Reply #12 on: May 16, 2017, 10:56:38 AM »
I had the short log thing down pretty well on the LM2000 so far I have struggled some on the new mill. I had a lady whose Mom had died and they had to cut her favorite tree down so she wanted the tree made into lumber. I talked to her on the phone and she said the logs (key word ) were all at least 4' long and good size diameter. They dropped it off while I was out and when I got home I had a pile of firewood. True there were many that were 4' long and twisted like a corkscrew. I called her back and said it wasn't doable but I could tell it meant something to her so i said i would try. I did manage to cut about 10 or 11 up and it turned out ok. I managed to hit a log dog and ruin a blade but that was my fault I was busy watching were I had been and not were I was going.
I need to get all the bugs worked out of this before I cut my walnut logs I guess I had more then I thought I did so I better get this thing figured out so i can clean up the piles.
New Toy, life is getting easier
Started by PineHill4488 on Sawmills and Milling
Last post December 05, 2017, 11:07:12 AM
by PineHill4488
need to get my saw to start easier.... Getting old
Started by shinnlinger on Chainsaws
Last post June 25, 2012, 07:53:31 PM
by Al_Smith
Log moving just got easier
Started by outpost22 on Sawmills and Milling
Last post February 18, 2016, 11:37:02 PM
by YellowHammer
Sawing Just Got A Little Easier For Me
Started by Tree Feller on Sawmills and Milling
Last post August 27, 2012, 01:47:35 PM
by grweldon
