Arborwear
Author Topic: Mixing paint ??  (Read 687 times)
Offline Woodhauler
  • Logging is in my blood!
Mixing paint ??
« on: May 15, 2017, 06:29:21 PM »
Bought a gallon of paint to do the stakes on my log truck, Its the same color that stairs trailer uses, the place I bought it mixes it for them. He gave me some stir sticks but I cant seem to stir it enough to get the black tint mixed in. Should I take it to hardware store and have them shake it???? I shook it and then stirred it before I opened it.I did paint one side with it mixed the best I could get it.
2013 westernstar tri-axle with 2015 rotobec elite 80 loader!Sold 2000 westernstar tractor with stairs air ride trailer and a 1985 huskybrute 175 T/L loader!
Offline 21incher
Re: Mixing paint ??
« Reply #1 on: May 15, 2017, 06:37:57 PM »
How about one of those paint mixers you use with a drill. Most hardware stores sell them.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Woodhauler
Re: Mixing paint ??
« Reply #2 on: May 15, 2017, 06:42:11 PM »
Good idea! May grab one in morning. Painting the stakes is about last thing I have to do. Took 2 days to paint frame, one day to polish one fuel tank and def box. 1 day to paint one side of stakes and polish ditch side battery box and re-gen / muffler cover. Should be ready mid week to haul wood.
Offline sandhills
Re: Mixing paint ??
« Reply #3 on: May 15, 2017, 06:50:29 PM »
Those are easy to make, just twist a piece of flatiron a little and weld a rod to it  ;).  My shop came with a built in shaker, previous owner built it out of an washing machine gearbox, slow but it works.
Offline Holmes
  • 1840 house
Re: Mixing paint ??
« Reply #4 on: May 15, 2017, 07:39:20 PM »
 I like to put the paint mixer thru a piece of cardboard and hold the cardboard on top of the open can.Then you can move the drill mixer up, down, all over and not splatter anything.
Think like a farmer.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Mixing paint ??
« Reply #5 on: May 15, 2017, 07:59:58 PM »
I take two washers and split them and give them a twist and then
weld them on a rod to put in a drill. One twist up and one down.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Mixing paint ??
« Reply #6 on: May 15, 2017, 08:46:50 PM »
   Cheap to buy and they work great. Go ahead and get the long one so you can use it with a 5 gallon bucket if/when you need it. It will work on a gallon can but short one won't work on the tall cans.
    I roofed my sawmill storage shed with used tin and had to repaint it with the aluminum paint. First can I mixed with a stick and hardly worked at all. Next time I used a drill and long mixer attachment and it worked great.
Offline Hilltop366
Re: Mixing paint ??
« Reply #7 on: May 15, 2017, 09:55:02 PM »
Yep those drill mixers work good.
In pinch I have used a piece of coat hanger wire for 1 gallon cans, just bend it back and forth a few times (3" or 4" long) then up for the shaft.
A old kitchen mixer beater in a drill works well too but the shafts are kind of short on the small hand held ones.
Offline Don_Papenburg
  • I need money
Re: Mixing paint ??
« Reply #8 on: May 16, 2017, 01:01:56 AM »
When your wife goes to the mall , break out the blender .  Push the fast blend button a second or two  , Presto mixed to perfection . Clean it up real good!!!!!!!  and make sure you put it back in the same place with the handle and lid just as you found it . and get your painting done .  At least get out of the kitchen with your paint BEFORE she returns.
Offline coxy
Re: Mixing paint ??
« Reply #9 on: May 16, 2017, 06:26:13 AM »
 :D :D :D
Offline Bert
Re: Mixing paint ??
« Reply #10 on: May 16, 2017, 01:02:32 PM »
Quote
I have to do this procedure with the washing machine. My wife hates sawdust and wood chips in the house. I wash my sawmilling and logging clothes when shes out and return all the buttons to where they were and clean out the lint trap. She knows but doesnt bother her as much. I always tell her she should have married an accountant.
Saw you tomorrow!
Offline coxy
Re: Mixing paint ??
« Reply #11 on: May 16, 2017, 06:32:49 PM »
that's funny I don't even know how to turn them on  :D :D
Offline ljohnsaw
Re: Mixing paint ??
« Reply #12 on: May 16, 2017, 08:31:02 PM »
Those are for the quart cans and you don't even need a drill, just use the electric mixer! :D
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Hilltop366
Re: Mixing paint ??
« Reply #13 on: May 16, 2017, 09:28:39 PM »
That would work!
My brother says they are the best thing he has ever used for mixing drywall compound.
Mixing Oil Manufacturers
Started by Woodhog on Chainsaws
Last post May 14, 2004, 07:14:32 PM
by woodsie
Mixing Walnuts
Started by Randall on Ask The Forester
Last post August 17, 2007, 06:57:14 AM
by Dana
Re-mixing pre-mix fuel
Started by Drifter27 on Chainsaws
Last post April 10, 2018, 11:18:54 AM
by HolmenTree
mixing red and white oak
Started by copperhead10 on Drying and Processing
Last post December 01, 2015, 10:35:14 PM
by GeneWengert-WoodDoc
