Arborwear
Author Topic: WM brg support install  (Read 410 times)
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« on: May 16, 2017, 06:24:15 AM »
Going to install the brg support this Friday as i have help coming.
Anything i should be aware of as regards possible problems?
I have a fair amount of mechanical skill but my fingers and muscles dont work as well as they once did.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Chuck White
  • Sawing Mobile since 2005
Re: WM brg support install
« Reply #1 on: May 16, 2017, 07:02:52 AM »
What's a brg, Pete?
~Chuck~
I LOVE MY SAWMILL
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #2 on: May 16, 2017, 07:24:30 AM »
bearing
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline red
  • we will never forget
« Reply #3 on: May 16, 2017, 07:39:53 AM »
I thought it was British Racing Green ? ? ?
We have a lot of good boys and girls in harms way
lets all support them and their familys.
« Reply #4 on: May 16, 2017, 06:00:43 PM »
Guess I should have been more specific
WM calls it support assembly Cat bearing LT40/50 D51
LT40SHDD51
Kubota 900 RTV
Online moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #5 on: May 16, 2017, 09:12:28 PM »
Wish I could come help you and learn how to do mine at the same time.
If it is true that we learn from our mistakes, I must be Brilliant!
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #6 on: May 16, 2017, 10:09:39 PM »
Hello,
   We started a head gasket and crank support kit on a LT50 with the 51 hp Cat today.
Metric Allen wrench for the stub shaft. You will need to heat the cap screws and they will come out easy. Propane torch may work.
You may need to shim the alternator pulley with a washer to help with alternator belt alignment. After you install the new stub shaft.
This engine already had a belt issue with the outside of the belt missing one strand. I have also shimmed the tensioner if it hits the alternator pully fan.  The Drive belt was also not one but three so it will be replaced also.
Remove the drive belt tension! before installing the drive belt. I like to make sure everything is aligned on the drive belt then engage the drive belt then adjust to the proper spec.
This taper lock on the drive pulley was very tight tight. Three 1/4" 20 bolts. Remove them and then put them back into the threaded holes. Tighten as much as you dare, then take a block of wood and drive the pulley away from the lock. Tighten the bolts again then repeat. I used a puller once it came loose to remove the lock. Lock tite back on the new cap screws for the stub shaft.
Hope this helps.
Sorry I thought I had pictures before . I will do this the next time.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #7 on: May 17, 2017, 05:33:26 AM »
     Pete, I'm glad you posted this.  I'm about ready to put mine in too and I'll be watching this closely.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline Chuck White
« Reply #8 on: May 17, 2017, 06:43:37 AM »
That's kind of what I thought it might be Pete, but just wasn't sure!   ;)
~Chuck~
I LOVE MY SAWMILL
Wood Mizer Crank support Kit install. D51 and D62 HP
Started by MartyParsons on Sawmills and Milling
Last post August 20, 2017, 10:18:15 PM
by Peter Drouin
New E classic install
Started by jdman18 on Firewood and Wood Heating
Last post March 31, 2010, 11:53:06 PM
by MrMojoinCO
New cylinder install on an ms310
Started by palmer78 on Chainsaws
Last post January 06, 2013, 09:51:02 AM
by joe_indi
NEW Central Boiler Install
Started by DDW_OR on Firewood and Wood Heating
Last post July 11, 2017, 09:48:26 AM
by Logging logginglogging
