Arborwear
Author Topic: LT40 hydraulic pumps  (Read 814 times)
Offline D6c
« on: May 17, 2017, 09:04:26 AM »
I take it some WM models came with one hydraulic pump and some use two.  I'm in the process of adding hydraulics to an older LT40 and am trying to decide if it's worth putting two pumps on it.
Other than making the hydraulics move faster there shouldn't be any difference.
I'm adding a hyd. log clamp, log turner, side stops, and probably a pair of toe boards....no log loader for now.  I'm not trying to make a living with this saw so that's a consideration.
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: LT40 hydraulic pumps
« Reply #1 on: May 17, 2017, 09:17:26 AM »
You will need a 90 Amp alternator for 1 pump plus a good marine starter battery.  Two pumps require a 140 Amp alternator, larger wiring in the charge circuit, a larger commercial-grade battery, and larger hydraulic hoses on most of the circuits.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline ladylake
« Reply #2 on: May 17, 2017, 10:13:55 AM »
 It would be a lot easier and more reliable to use a 6 hp gas motor to drive a hyd pump like on my TK mill.  Steve
Offline Mt406
« Reply #3 on: May 17, 2017, 10:29:45 AM »
Go with gas motor You will not have to rewire and have more options down the road and more speed.
And when you get half way down the log and see your back stop is to high you can unclamp and lower it.
(Don't ask how I know this would be a nice option)
Look at some of the wood spliter supply outfits you can get all your parts reasonable pump valve bank, remember relief valve.
My 2 cents
Scott
Offline D6c
« Reply #4 on: May 17, 2017, 07:26:02 PM »
So you don't think I can keep the battery up with intermittent use of the hydraulics?....Might be right.  I'd rather not have to run a separate engine for the hyd. if I don't have to.....one more thing to maintain.
I bought a power strip to put on the mill to run the hydraulics but haven't put it on yet.  I've been concentrating on making the mods to mount the clamp and turner.  Pretty much done with that today.
.........And when you get half way down the log and see your back stop is to high you can unclamp and lower it.
(Don't ask how I know this would be a nice option).......
I thought about that....can sometimes be difficult to back out half way through a cut with it pinching closed.  Maybe a reason to install terminals so you can temporarily snap on a set of jumper cables to power the hyd. for that situation.
Offline ladylake
« Reply #5 on: May 17, 2017, 07:38:38 PM »
 After 13000 hours I can tell you those 6 hp gas motors are low maintenance, way less than electric over hydraulic and you not be robbing power from the main engine when cutting. Steve
Offline naturaledge1
« Reply #6 on: May 18, 2017, 09:13:48 PM »
I run a 1989 lt40hd with one pump and a 60 amp alternator and all works well . Put the strip on it's well worth it . brian
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #7 on: May 18, 2017, 09:21:14 PM »
How are you robbing power when cutting with the hydraulics? A standard 40 has, i think,  a 1/2 horse feed motor, and a super has a 3/4 horse. Not enough, even if it were at full load, too make a difference.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: May 18, 2017, 09:36:17 PM »
D6c, Ga Mtn Man answered your questions in Reply #1.  For your use as you described, one hydraulic pump should be sufficient.
I use a battery "jump box" whenever I need to operate the hydraulics and am off of the contact strip.  Very simple.
    • My homepage
« Reply #9 on: May 18, 2017, 09:38:56 PM »
I dropped a couple of heavy leads out of my hydraulic box and i hook up a spare battery when i want "hydraulics anywhere". Normally i am only opening three clamp for dragback.
Offline ladylake
« Reply #10 on: May 19, 2017, 04:09:26 AM »
 The battery's are constantly recharging from using all of the electric, hyd pumps, up down, head drive. I'd guess 1 to 3 hp to run the high amp alternator .  Not much on a 50hp diesel but quite a bit on smaller gas motors' As mentioned 6 hp gas engines work great to drive the hydraulics and are not complicated, plus really reliable.  Steve
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #11 on: May 19, 2017, 06:31:47 AM »
.....Nikon .....
There are now 43 posts on FF containing this word.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
    • My homepage
« Reply #12 on: May 19, 2017, 08:36:41 AM »
 And I spell checked that post, too. >:(
Offline D6c
« Reply #13 on: May 19, 2017, 08:59:42 AM »
Might be a bit of a challenge to mount an alternator on the 20 hp Onan that my mill has.  There is a little room on the crankshaft between the drive pulley and the crank case where I might be able to slip in another pulley for an alternator.
    • My homepage
« Reply #14 on: May 19, 2017, 01:08:54 PM »
I converted an LT40 electric to gas and the WM step pulley wouldn't  fit the new shaft. I ended up using a triple B groove and ran the band at the same rpm as the alternator.
Offline nativewolf
« Reply #15 on: May 19, 2017, 02:07:36 PM »
.....Nikon .....
The things one learns on FF :D
Liking Walnut
LT40 Super hydraulic/LT50/LT70 DC Hydraulic pumps specs question....
Started by Percy on Sawmills and Milling
Last post August 06, 2017, 12:56:15 PM
by JB Griffin
LT40 Super hydraulic pumps
Started by JustinW_NZ on Sawmills and Milling
Last post November 25, 2012, 04:26:09 AM
by JustinW_NZ
2009 LT40 manual updated to include dual hydraulic pumps.......
Started by DGK on Sawmills and Milling
Last post October 30, 2015, 10:49:50 PM
by DGK
Hydraulic pumps
Started by dustyhat on Firewood and Wood Heating
Last post January 28, 2016, 01:33:52 PM
by dustyhat
