Arborwear
Author Topic: Woodland Mills tracking problems  (Read 3206 times)
Offline york
Re: Woodland Mills tracking problems
« Reply #20 on: May 18, 2017, 06:50:59 PM »
There is nothing wrong with this mill-it is out smarting you,you are missing something-you may need help from a FF member.....
Albert
Offline clintnelms
  • Woodland Mills HM126
« Reply #21 on: May 18, 2017, 07:26:50 PM »
Have you changed the drive belt out to a Gates Belt? I had a tracking problem and found it was the belt I swapped out that came in my parts kit. It was a little thinner than the Gates belt that was originally on it and the blade would ride on the metal wheel instead of the belt. Took me forever to figure that one out.
Offline Southwood
  • Shoulda bought a Woodmizer!
« Reply #22 on: May 19, 2017, 07:17:20 AM »
I have replaced the belt but am not sure of the brand. It was the belt that came in my maintenance kit. I may be missing something, but you would think woodland mills tech people would have thought of it to. I have replaced both belts, bearings, & blades & nothing has corrected it. Could it be possible the band wheel itself is bad?
Offline pineywoods
« Reply #23 on: May 19, 2017, 08:53:07 AM »
Not sure about the woodland mill, I think there are 2 bearings in each bandwheel. If one of the bearings is loose and the other one normal, it can cause a lot of grief. Tension blade and adjust tracking in both directions while turning wheels manually. Then increase the tension. If tracking changes, bandwheel bearings likely the problem. Been there, done that on a woodmizer..Change both bearings...
Offline qbilder
  • lil helper
« Reply #24 on: May 19, 2017, 09:17:11 AM »
Yes it could be a faulty wheel. The only time I have ever had the issue you describe, it was a blade guide bearing that would get warm and start locking up. At low speed or the first few seconds, it would track perfectly. A few seconds spinning at cutting speed, the bearing would lock, thus putting drag on & slowing the guide. With one guide spinning at speed and the other slower, the blade would creep back. Unfortunately I never figured it out until the grooves began forming on the guide where the blade was running against it full friction as I milled logs.
God bless our troops
Offline Slingshot
« Reply #25 on: May 19, 2017, 09:59:14 AM »
  One of the Band Wheels out of balance or a little warped?
______________________________-
Offline fishfighter
« Reply #26 on: May 19, 2017, 02:58:14 PM »
I notice he says 35 foot pounds in the video.
With the new spring washers, Woodland said 25 FP.
Offline Southwood
« Reply #27 on: May 19, 2017, 10:40:26 PM »
Well may have figured it out. Woodland mills tech said I was taking too much tension off when adjusting the tracking. I took a quarter turn backwards once I had it torqued to 25 lbs & made my adjustments & it worked so far. Who would of thought it? So far I have milled 7 logs today & all was good. I figured as long as tracking was adjusted & checked at 25 lbs torque it would make no difference, but apparently it does. Thanks everyone for your input, I appreciate it.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #28 on: May 20, 2017, 12:21:51 AM »
Good to hear that your mill is up and running!
1992 LT40HD
Offline fishfighter
« Reply #29 on: May 20, 2017, 07:51:57 AM »
Happy to hear you are up and sawing. Yes, one has to have full tension when adjusting everything.
Offline Sawmill Man
« Reply #30 on: May 20, 2017, 08:50:11 AM »
 Didnt someone recommend that back in reply #6?
"I could have sworn I went over that one with the metal detector".
Offline thecfarm
« Reply #31 on: May 20, 2017, 09:00:29 AM »
I have a Thomas and to adjust the tracking on mine,when I change a blade,I spin it by hand and when it tracks off, I adjust one side a little and spin it again. I know which bolt to adjust to get it to track right. I adjust it until it runs true. Only takes me a minute to get it right. Took me longer about 15 years ago.  ;D  Than I start to motor and run it slowly for a few seconds and I know I am good to go.
Offline york
« Reply #32 on: May 20, 2017, 09:01:53 AM »
Yes you did,Sawmill man....
Key word full tension....
Albert
Offline paul case
  • Original wearer of the PCM.
« Reply #33 on: May 20, 2017, 09:30:46 AM »
Glad you are sawing Southwind.
One thing about the FF is the experience here is invaluable and the guys here are really encouraging and helpful.
I guess that is 3.
PC
pc
Offline Sawmill Man
« Reply #34 on: May 20, 2017, 09:53:12 AM »
 On a lot of mills increasing blade tension does more than stretching the band tight. The saw head can flex and twist with different amounts of tension which affects tracking. The weaker the design of the sawhead or the wider the throat the more severe the change.
Offline Briankinley2004
« Reply #35 on: May 21, 2017, 09:52:11 PM »
It's easy to overlook stuff. The manual or video or both say to let tension off only slightly as there is some bolt in there that needs tension but not full to work properly. Another thing I missed initially is to back the guides off when doing tracking so they don't push on band.  Glad you found the problem
Offline fishfighter
« Reply #36 on: May 22, 2017, 07:29:45 AM »
This is the same way I adjust my 126. ;D
Offline Southwood
« Reply #37 on: December 10, 2017, 08:45:44 PM »
I am still having tracking problems, there suggestion has only worked for 1 day of sawing. It is really frustrating when you have so much time & money invested to make no progress. As luck has it my warranty was up last week & today I think I have found the problem. The threads of the tracking bolt & nut that it screws into are flattened & stripped (not sure why they didn't use a higher grade nut & bolt). The nut is welded to the carriage & cant be replaced or fixed without major fabrication. Anyone ever have this problem & if so how did you fix it? I'm gonna call woodland mills in the morning to see if it will be covered by warranty since it only ran out last week & that this has been an ongoing problem since day one. My last question is should the blade be sitting level? Mine has always had a backwards tilt. Changing the vertical tracking has no affect on the blade. Since I have had the mill I have had to replace wheel bearings, throttle cable, clutch, on & off switch, several drive belts, bearings & rollers, & way too many blades for very little saw time.
Offline fishfighter
« Reply #38 on: December 11, 2017, 08:03:01 AM »
That is a lot of parts you changed. :o My 126 is going on three years next month. Only belts and one set of guide blade bearing have been change on mine in that time.
Offline Novascotiamill
  • I walked the “Thin Blue Line “ for 20 years
« Reply #39 on: December 11, 2017, 04:58:16 PM »
Any chance you can post a pic of which bolt and nut is damaged,id like to see if its the same serup on my hm130. Sorry about your badluck with the mill. Any time ive talked with the staff there they have been excellant,im sure they will be able to help you out.
2017 HM130
Stihl 261
2010 F150 xtr
Lots of rigid genx5 tools
1 long haired german shepherd
2017 kioti ck2610HST with FEL and forks
Grindlux band sharpener
Wicked 55” root rake grapple
O
Woodland Mills HM126 tracking problem
Started by clintnelms on Sawmills and Milling
Last post April 07, 2017, 09:53:26 PM
by mattyo5
Woodland mills hm130 tracking resolved!
Started by Novascotiamill on Sawmills and Milling
Last post October 25, 2017, 08:40:53 PM
by Novascotiamill
Problems with my new woodland mill 130 saw blade changing and tracking
Started by Grandpa Rod on Sawmills and Milling
Last post February 05, 2018, 05:17:53 PM
by Novascotiamill
B-16 tracking problems
Started by mike phillips on Sawmills and Milling
Last post February 18, 2017, 12:37:31 PM
by mike phillips
