Anyone running the Woodmizer LX450 yet?
Started by Stuart Caruk, May 20, 2017, 08:11:33 PM
Stuart Caruk
I decided to upgrade and put my LT35 up for sale. I had several offers in the first day, and let it go after training the new owner. My LX450 is supposed to show up first part of July. So far it looks like I can get the debarker option added onto this mill, and if I'm willing to wait a month and a half I can probably get the diesel engine. I'm trying to decide if a diesel is worth the $4k upgrade cost for the same HP. I can buy a lot of gas for them $$$.
An extension package won't be available until next year, so I'm going to build my own. Somewhere I saw a jig for drilling the center of the hardened rails to make the rail transition seamless. Any ideas where I can get one?
Any other options on this mill or mods that you would make if you're running it currently?
Thanks,
Stu
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
WV Sawmiller
   I watched it demo-ed at the Albermarle NC Owner's Day 2 weeks ago. It was impressive but my goal is mobile sawing and I think there are existing mills out there better suited for that purpose.
    I liked the side clamps that raise straight up and down but I gather we have other mills with that feature. I have an extra set of side arms and they are very helpful for short logs and such.
    I see from your profile you indicate stationary sawing so many of the concerns I had should not be an issue for you. I'm betting you will love it once you get your routine down pat. Let us know more after you've run it a while.
thechknhwk
scully
With a diesel that mill would be a real ANIMAL!
I bleed orange  .
Stuart Caruk
So having never run a diesel sawmill, what's the difference between it and gas. I thought HP was HP and if the HP is the same the performance should be as well... Of course diesels typically have more torque, but I don't know if that applies in a sawmill application.
Looks like the diesel upgrade is about $4k. That buys a lot of gas. On the other hand I have a 600 gallon bulk diesel tank that can probably reach over to fill my mill up...
I'd love to hear experiences from those that have run the same mill with gas vs. diesel engines. My buddies are trying to steer me to gas saying I can buy and extra couple spare engines for the same $$$.
Stuart Caruk
thechknhwk
HP is HP, but diesel is torque.
My mill has the v1505 33hp kubota diesel.
http://www.kubotaengine.com/assets/documents/13_v1505_30.pdf
That kubota literature shows it rated at 92 nm, which is like 68 ft/lbs of torque.  A gas motor is lucky to have the same torque as it's hp rating.
Torque in a way describes how an engine responds to being loaded up.
With a gas engine, if you start to loose RPM, the torque also drops off, making the slow down even worse. Even less torque available, and you really have to ease up on the feed to regain revs. Different engines have different torque curves of course, but torque on a gas engine generally peaks higher than a diesel. Heck my old Toyota had peak torque at 6400 revs. Having that sitting at 3,000 revs driving a sawmill would have been useless  :D
Where as you look at the torque curve of the little diesel that thechknhwk posted. If that's sitting at 3,000 revs (max power) and you load it up, the torque is actually higher at 2800, so it's not going to bog down the same.
So a diesel tends to maintain torque at lower revs, and resists that slow down effect, and can power through the knot etc easier than a gas engine, and with only a slight slow down.
Electric is even better in that respect as torque actually goes UP as the revs drop. This is why you can run a mill with maybe 60% less HP if it's electric.
tawilson
I ordered my LT40 with the 35hp gas engine mainly cause I was about 3 times my original budget and had to stop somewhere. But in researching I tried to find the difference in weight between the gas and diesel. Woodmizer doesn't list it and the best I could come up with is probably around 200 lbs. Maybe the cooling system adds more. I wonder if the lighter gas setup is less wear on the lift mechanism.  I saw a YouTube video of a saw head breaking something when raising and it came down hard.
2017 LT40HDG35 WIDE
Woodmaster 725
You also get away from carbs problems with diesel.
Quote from: Stuart Caruk on May 22, 2017, 01:34:29 AM...buddies are trying to steer me to gas saying I can buy and extra couple spare engines for the same $$$.
All of the gas and spare engines in the world will not equal the benefits of the Diesel.
grouch
I don't have any experience running a sawmill with a diesel engine, but you've already gotten advice from those who have.
No offense, but that's about the nuttiest reason to recommend a gasoline engine as I've ever heard. The time spent swapping those spare engines would pay for the diesel engine.
Diesels have fewer parts. If it ain't there, it can't break. Flatter torque curve has already been covered.
Diesels inherently burn dirtier than gasoline engines, but what comes out the exhaust is not the only thing you have to measure when considering impact on your world. (I remember the big uproar during the gasoline "crisis" of the '70s there were people screaming for NASCAR to suspend racing. That lasted until it was calculated that Monday Night Football actually cost more barrels of oil than Sunday races).
Quote from: Ianab on May 22, 2017, 03:51:08 AM
And that's how all those marketers come up with ridiculous  "Peak HP!" claims on air compressors, etc. An electric motor produces maximum torque at stall -- and then the magic smoke gets loose.
Find something to do that interests you.
nativewolf
If you were going to be stationary an electric would be super.  Are they offering it?  Lots of folks on here have converted stationary mills from gas/diesel to electric and none complain that I've heard.
Liking Walnut
Chuck White
Quote from: grouch on May 22, 2017, 10:27:37 AM
I don't think so, my brother and I removed the Onan engine from my mill and installed the new Kohler engine two years ago and it took us right at two hours from start to finish and I was back at the saw site and sawing within 3 hours!
Just sayin'!   ;)
grouch
Quote from: Chuck White on May 22, 2017, 04:54:29 PM
Just sayin'!   ;)
Now, times 2 ("couple spare engines") and you are 6 hours behind on sawing, at least. If Murphy has his way, those breakdowns will be when you are covered up with work. That means you stay behind until customers go elsewhere or something else breaks.
The bigger the machine and the more production needed from it, the better the argument for diesel over gasoline.
longtime lurker
I dont have any thin bandmill experience to know where the point of "wasted power" is because you have more power then the saw can absorb...but heres one thing I can tell you as fact in this industry regardless of what type of mill you operate or where you are in the world:
A board isnt worth more because it took you longer to cut it.
So aside from the increased engine longevity and cheaper operating cost over thousands of hours that go with diesel... if it makes a mill cut faster it makes more money.
Randy88
Diesel would be my vote and not look back.
Here's an idea, how much more in a percentage is the 4k diesel on the entire cost of the mill?  Just tossing out figures here, for simple math, say the mill is 36k with a gas engine and 40k for the mill with diesel engine, that's roughly 10 percent more in price on total cost, next question is this, how much more fuel per hour alone will the gas suck, if the answer is anything over 10 percent the better deal is the diesel, not even considering replacement costs for the gas engine, or any maintenance costs, life expectancy or anything else, including downtime.
thechknhwk
I had the 25hp kohler on an LT35, you had to fill it up at lunch time, and it cut slower.  On the kubota diesel you can saw all day and it makes more lumber.
Peter Drouin
I have watched that mill cut, Is all I have to say.
A&P saw Mill LLC.
License NH softwood grader.
Chuck White
Quote from: thechknhwk on May 22, 2017, 11:04:21 PM
Well... The 25hp Kohler on my mill will run all day "easy" on one tank of gas!
Two days ago my grandson and I sawed 1,828 bd ft of White Pine on 4 gallons of 91 octane!
Everything on that sawjob was cut at one (1) inch 4/4, except for one 5" slab for a bar top!
Now I'm not saying that a diesel wouldn't be nice, but what I am saying is that I couldn't justify adding one to my mill!
4x4American
Torque is the ability to do work, hp is how fast said work gets done.  A 30 hp gas vs diesel vs electric gonna all cut slower than the next one.
Boy, back in my day..
ladylake
  Going from a 27hp Kohler  to a 29HP Isuzu , the Isuzu uses 1/2 the fuel and cuts way faster in tough wood. I think payback in fuel savings will be somewhere around 3000 hours.  Steve
Randy88
We figure if your only going to keep whatever piece of equipment far less than 1000 hours, we might consider gas, anything over that and we want diesel right from the git go.
3000 hours might be break even on fuel alone, but its doubtful at best the gas engine will last that long so in essence you need to figure in a replacement engine long before the 3000 hour mark, meaning break even is much closer to 1500 hours or less.
If you put a side load on a Kohler gas, you shorten its life expectancy greatly, the crank bearings are smaller and lighter on a Kohler than Briggs or Honda engines.     If you take two identical Kohler engines and put one with a side load, as in belt drive bandsaw, edger, mower or many other applications and the other engine you use it in a straight line pull such as a direct drive water pump or hydraulic pump, the engine with a side load will last a portion of the hours as the in line direct drive engine will, just due to how much side pull is on the crank shaft and crank bearings.     Many small engine dealers will tell you this if your wanting to buy a replacement engine for a Kohler that has locked up and try to sell a Briggs or Honda for its replacement.
SlowJoeCrow
Jim_Rogers
I recently viewed one of these mills and I did notice that the bed rails have holes in the end for adding on extensions. So that are pre-bored alreary for bed extensions. I would imagine that when the bed extensions are ready that they will "bolt right up"......
Jim Rogers
Jim H
To decide on gas vs diesel you have to consider your situation. If you are paid by production the extra torque of the diesel probably makes sense. I chose the gas engine because my work is hourly. The gas engine has lower initial cost, and in most cases on a mobile site the gas engine keeps up pretty well. I've cut for customers that had previously hired diesel mills, and according to them they couldn't see a difference in speed. Another thing to keep in mind is that these mills are an easy application for the engines. My current mill has over 5200 hours and I've replaced the spark plugs twice, and put on a new fuel pump solenoid. Some years ago Arkansawyer on this forum reported having to change his Kohler at around 10,000 hours. The fuel injected engines are more efficient also, I get about 8 hours on 5gal compared to 7-8gal on my previous carbureted mill. I have run a diesel mill, and while the torque was pretty nice ;D, when I looked what was best for my business the gas engine was a better choice.
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
