Author Topic: Getting things dialed in "finally"!  (Read 690 times)
Offline mad murdock
« on: May 21, 2017, 10:23:52 AM »
Got things going well finally. The large lag is my fault due to so many irons in the fire concurrently!  I moved the mill to my neighbors log stack and started in on his wood last night. I modified Jakes dolly with some better tires and wheels (learnt the hard way) and will be making a trailer dolly that will attach to the beam as I fashioned a tough adapter to fit into the head post on the front end of the mill.  I will get a few pics and put with this post later. I really like the 395XP on this mill. Plenty of power with the dual port muffler and it rips through the cuts no problem. I tired a 4" cut and even one single pass 6" cut, they were doable but 2" and 3" cuts are much faster and are definitely the way to go. First log a 15' doug fir, planed across the top of the log to check adjustments, all looked good, planed a vertical face to check vertical adjustments and all was good. After the move I had to re square the carriage to the beam as there was some jostling that occurred in transit, due to the wheel failure. No damage to anything though. A testament to the tough nature of these awesome mills!  Very easy to move. With the wheel and tire upgrade I made, the mill will travel in the woods much easier also. Neighbors Douglas fir logs. I hope to get through these this week of spare time milling.
Dialed in on the first log. About 110 bd ft. Took about 30 min. Like Jake said, once I get my brain geared to the turbosaw speed will increase. Still about 10 times faster than the CSM 8)
A shameless pic of the wonderful piece of engineering that Jake and Mike at Turbosaw helped me to get up and going ! Hunks guys!
Finally bought "my" mill, after a 3 year trial period!
Started by Piston on Sawmills and Milling
Last post March 29, 2013, 08:28:10 PM
by WDH
Bad Things happen to "Good People"
Started by Magicman on Sawmills and Milling
Last post March 21, 2014, 09:48:40 PM
by Magicman
"Taking over" the business aspect of things. HELP
Started by Goals2017 on Forestry and Logging
Last post August 19, 2017, 09:30:24 PM
by gman98
1- Twisted Sister or "Walnutz!" and 2- "Pre-Bent" or "Saw Mill Nightmare?
Started by MbfVA on Sawmills and Milling
Last post September 08, 2017, 12:33:17 PM
by MbfVA
