EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Mortise chisel drift solution  (Read 455 times)
Offline Just Me
« on: May 23, 2017, 11:41:26 AM »
Mortice chisel drift solution
    I am building some furniture out of highly figured wood with grain running on an angle and had a lot of 1/4" mortises to do with the mortising machine. I had a problem with the chisel wanting to bend and follow the grain so I came up with a solution that I thought some of you may be able to use.
    I took some of the stock of the same thickness and cut a 1/4" slot in the center 7/16 deep, then ripped that stock with the groove to 3/4". I laid that on top of the piece to be mortised, taped it in place on the clamp side so not to mess with center, transferred the marks up to this scrap piece and clamped the whole thing in the machine.
    By starting out the mortise with the chisel riding in the slot the mortise stayed straight and did not wander with the grain any longer. I had three mortise sizes so I made one for each size and just moved it from piece to piece, taping it where I needed the mortise.
    Worked for me............
The other Larry
Offline woodworker9
    • Elite Concrete Raising Co.
Re: Mortise chisel drift solution
« Reply #1 on: May 23, 2017, 03:56:32 PM »
Glad it's working for you
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline WDH
  • April 1998 - August 2008
« Reply #2 on: May 23, 2017, 04:38:45 PM »
Just Me,
What a great tip.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5640SU, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.
Offline 21incher
« Reply #3 on: May 25, 2017, 06:54:15 PM »
That sounds like a great idea, I may try and make some. Thanks for sharing. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Square chisel vs regular chisel chains
Started by husky2100 on Chainsaws
Last post August 13, 2014, 07:54:01 PM
by husky2100
Best Chains Chisel/ Semi-Chisel
Started by cuttingedge on Chainsaws
Last post November 12, 2013, 12:06:18 PM
by Al_Smith
Drift wood?
Started by beerguy on Sawmills and Milling
Last post November 15, 2004, 02:45:42 AM
by Fla._Deadheader
My Daughter's in a drift.
Last post February 26, 2014, 09:05:34 PM
by OneWithWood
