Arborwear
Author Topic: Help drawing timber frame  (Read 876 times)
Offline Tyler.schmick
« on: May 25, 2017, 11:01:42 AM »
I would like to know if there is a engineer or architect that could look at my timber frame and make suggestions. Also, what is the going rate to have someone draw a truss design?
Thanks!
Offline ljohnsaw
Re: Help drawing timber frame
« Reply #1 on: May 25, 2017, 02:05:10 PM »
Do you need to submit to the county?  IF so, you need an engineer licensed in your state.  I used Ben from Fire Tower Engineered Timber out of Rhode Island.  He is licensed for California and IIRC, Rhode Island and Massachusetts - maybe a few other states.  Cost depend on the work.  I maintained the drawings, Ben over saw the work (highest wage) with a junior engineer doing most of the work.  I spent a few thousand on getting the plans signed off.  Then the county wanted some changes/clarifications.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Online VictorH
« Reply #2 on: May 25, 2017, 04:52:07 PM »
Hi Tyler!  Welcome to the forum.  What part of Nebraska are you in.  I'm in the Southeast corner.  Forum member Jim Rogers does design work.  He has designed 3 structures for me and has an engineer that must be licensed in NE.
Victor
« Reply #3 on: May 26, 2017, 08:57:54 AM »
I am in McCook Nebraska!(southwest)... I don't need to submit anything because my county doesn't require, I just don't want to order timbers until I know my plan is right. I don't need anyone to oversee etc, just to look at the plan.
Thanks!
Tyler
Offline 1234wood
« Reply #4 on: July 13, 2017, 11:53:39 AM »
I need help with bents spaceing for sawmill building I need 16 ft opening for logs to come thru to mill I'm useing white pine 10x10 or 12x12 for bents  24x36 building timber raffters any one can help yes I read and understand and agree
Offline Tsmall07
« Reply #5 on: July 14, 2017, 08:30:21 PM »
What software did you use for that design?
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #6 on: October 12, 2017, 10:49:06 PM »
 This thread is a couple months old, but I believe that drawing was done in sketchup, and it looks amazingly similar to a design I saw in the sketchup 3D warehouse.  If you were not familiar with it, sketchup is a great drawing program available for free use and also in a pro version, about $700.
10' X 12' Timber Frame Shed (Raising the Frame)
Started by jander3 on Timber Framing/Log construction
Last post February 03, 2012, 07:17:55 PM
by jander3
Timber size calculator and timber frame design.
Started by Joe Vachon on Timber Framing/Log construction
Last post July 07, 2017, 10:25:46 PM
by Roger Nair
Timber frame or stick frame
Started by John_Haylow on Timber Framing/Log construction
Last post October 17, 2009, 10:10:36 PM
by Rig
Timber Frame vs Log?
Started by wkheathjr on Timber Framing/Log construction
Last post December 30, 2008, 06:49:39 PM
by logman
