Author Topic: 1999 Fabtek 133 Harvester  (Read 2570 times)
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« on: May 25, 2017, 11:21:34 AM »
I'm putting my 133 Fabtek with four roller head on the market.  Wife says I'm done with it.  It's currently down with a hydraulic issue.  The pump is out and at a shop being rebuilt.  New drive coupler components will also be installed upon reassembly.  It has a 6068D naturally aspirated JD engine.  Runs good with a little smoke on start up.  Doesn't burn oil.  New injector pump and injectors not too many hours ago.  Valve bank is wet.  There are other leaks.  There's new hoses, old hoses etc.  Hoses are an on going event with one of these.  Head works good.  In average hardwood it'll put 5 cords an hour on the ground easy.  I've done more and less depending on conditions.  Undercarriage has lots of life left in it.  It has the Joral measuring computer.  The Iqan just does engine functions.  The readout for it has a bad button but with patience you can navigate to the needed screen.  AC doesn't work.  Heat does.  Extra bars and chains go with it as well as a service manual.  I'll add pics when it's back together and out of the woods.  Hopefully that's the end of next week.  I see similar units priced from $50,000.00 all the way to $130,000.00.  I'm thinking some where in the middle of those as a selling price.  Around $85,000 ??? :)
Offline Corley5
    • Whittaker Farms
Re: 1999 Fabtek 133 Harvester
« Reply #1 on: May 25, 2017, 11:41:43 AM »
Offline Corley5
    • Whittaker Farms
« Reply #2 on: May 25, 2017, 11:51:15 AM »
The last two pics were taken in March of this year.  The first two are older.  I've had the machine since April of 2013.  This was taken just after it was delivered.
Offline Corley5
    • Whittaker Farms
« Reply #3 on: May 25, 2017, 12:17:15 PM »
Partial trade on 580 Case sized 4X4 backhoe with enclosed cab or Bobcat with enclosed cab considered as well ;)
Offline Corley5
    • Whittaker Farms
« Reply #4 on: May 25, 2017, 05:38:14 PM »
Gen​ 1 or 2 Dodge Cummins 4x4 with lower miles and solid body or industrial loader tractor with 3pt and pto in the 50 hp class with a cab also considered as possible partial trade.
Offline Corley5
    • Whittaker Farms
« Reply #5 on: October 27, 2018, 08:40:50 PM »
Updated pics, and price. 1999 Fabtek FT133 Harvester/Processor with four roller head. 6068 JD engine series F150 non turbo, non electronic. Joral measuring computer. New hydraulic pump. Never cut a tree since installed. Under carriage is good. Has some leaks. Needs hydraulic system filter carted. Oil is milky from a leaking filter cover which has been fixed. Not run with the contaminated oil. Extra chains and a couple bars. Complete set of manuals including service manual. Has a Proheat but there's no electric to it. Blown fuse? I've retired and it needs a new home. $75,000.00 as a starting point.  Reasonable offers considered.
I've read, understand and agree to the terms and conditions of selling items on the Forestry Forum.  It's also listed on Craig's List.
Offline Corley5
    • Whittaker Farms
« Reply #6 on: November 14, 2018, 05:37:50 PM »
$70,000.00 :)  Package deal with the Forwarder possible :)
Offline Corley5
    • Whittaker Farms
« Reply #7 on: December 28, 2018, 08:27:01 AM »
It's still here :)  I just ran a filter cart on the hydraulic fluid and have a mechanic coming out shortly to set the new hydraulic pump.  Reasonable offers :) :)
Offline Corley5
    • Whittaker Farms
« Reply #8 on: March 24, 2019, 05:58:24 PM »
Update-
Hydraulic pump has been set to specs.
ProHeat has a new fuel injector tip/nozzle and coolant circulator pump.
Hydraulic oil was filter carted but it should be changed again along the filters.  It has two new batteries in it as well.
 I'm more than likely going to consign it with http://crosstrac.net/home-page/ in the near future.  They've done the work to it.  It's still available directly from me for a bit.
Fabtek Harvester Computer
Started by logloper on Forestry and Logging
Last post January 14, 2012, 10:30:06 AM
by logloper
Fabtek Harvester Joystick Buttons/Switches
Started by Corley5 on Forestry and Logging
Last post October 20, 2014, 09:17:36 PM
by Corley5
Uga VI: 1999-2008
Started by Lanier_Lurker on General Board
Last post June 29, 2008, 09:33:56 PM
by WDH
1999 Lt40H
Started by Kedwards on Sawmills and Milling
Last post August 31, 2005, 06:39:49 PM
by Minnesota_boy
