Arborwear
Author Topic: Baker circle board edger  (Read 1563 times)
Offline paul case
  • Original wearer of the PCM.
« on: May 25, 2017, 10:49:57 PM »
03 baker edger model BEO SN 03 205.  Nice machine. will edge 2 1/4'' thick . 3 blade 2 fixed 1 moveable.  currently outfitted with a 7.5hp 220volt single phase electric motor. Originally was a 20 hp honda. Total bolt on change over and the original engine ran when we took it off goes with it. It has infinitely variable feed rate via hydraulic flow control. Wide rough top belt infeed and outfeed.  Most of the paint is still on the rollers so it has a lot of life left in it. It is a bit difficult to change the blades but they are split strobe saws so the shaft doesnt have to come out. long lever to shift the movable blade. Took out of use only 3 weeks ago. Was edging about 3k ft per week since I got it in Dec of 2015. I can hook up the electric to it for a test run. Tires are dry cracked but hold air. Can load.
$5000 firm
Calls work best. 918 542 4008
I have read and understand the rules of posting Items here and I accept those terms.
PC
pc
Offline paul case
Re: Baker circle board edger
« Reply #1 on: May 25, 2017, 10:58:02 PM »
I am not sure how much this one was new but they are $11600 new today from Baker.
PC
pc
Offline paul case
« Reply #2 on: July 01, 2017, 12:07:55 PM »
Sold via sawmill exchange. Thanks for looking.
PC
pc
Baker edger
Started by xlogger on Sawmills and Milling
Last post October 06, 2016, 10:50:17 PM
by Brucer
Baker Edger
Started by YellowHammer on Sawmills and Milling
Last post February 16, 2018, 02:09:01 PM
by YellowHammer
Baker 2" Twin Blade Portable Edger - $6,500
Started by Warren on For Sale
Last post March 21, 2012, 04:55:10 PM
by Warren
looking for a used board edger
Started by paul case on Wanted
Last post September 08, 2010, 10:12:05 PM
by paul case
