Arborwear
Author Topic: Metal stickers  (Read 603 times)
Offline Briankinley2004
Metal stickers
« on: May 30, 2017, 11:02:36 PM »
Has anyone used metal stickers for drying wood? I have bundles of metal stud stiffeners left over from jobs. They are roughly 1-1/2" wide by 1/2" thick c shapes. They are a heavy gauge and probably wouldn't crush. I think maybe 16 gauge. Any negatives to using them and how they would react in kiln. They are dipped galvanized. They are in my way and need to be used for something. Make excellent straight edges but I can only use so many
Offline longtime lurker
Re: Metal stickers
« Reply #1 on: May 30, 2017, 11:18:16 PM »
Ferrous metals - iron, steel etc will stain wood due to chemical reaction.
Copper based- copper brass bronze cupronickel are ok but too expensive to waste  like that.
Aluminum okay so far as i know.
Online GeneWengert-WoodDoc
Re: Metal stickers
« Reply #2 on: May 31, 2017, 12:23:20 AM »
1/2" is too thin, especially for fast drying species and products.
Are the bearing surfaces flat?  Are the bearing surfaces 1-1/2" wide?  What cross-section shape?
Re: Metal stickers
« Reply #3 on: June 03, 2017, 11:19:05 PM »
I will measure when I get to shop next eeek. I think bearing surface is 1.5". They are "c" shape meaning hollow. They will handle the applied load well. Not worried about them crushing. Also have a mile or so of 1" angle iron. Thought about laying it on a "v" to use for stickers. Most of it is primed and not raw wood
Re: Metal stickers
« Reply #4 on: June 04, 2017, 06:41:49 AM »
Iron will react with tannic acid in the wood to form a blue-black colored chemical called iron tannate.  For this reason, metal stickers are aluminum or stainless.
Online ljohnsaw
Re: Metal stickers
« Reply #5 on: June 04, 2017, 11:36:50 AM »
I will measure when I get to shop next week. I think bearing surface is 1.5". They are "c" shape meaning hollow. They will handle the applied load well. Not worried about them crushing. Also have a mile or so of 1" angle iron. Thought about laying it on a "v" to use for stickers.
Is that a 90 corners on the C or rounded?  In either case, I'd be concerned that the two thin channel edges on the bottom of the stack might start to put indents into your wood.  And if a rounded C, then the top might want to dent the wood as well.  I'm thinking softwoods, so maybe not an issue with oaks and such.
Quote
So this is not fresh cut, green wood?  Something that is getting painted and you are stacking it to dry or just to store?  If it is already dry, you can just flat stack.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Where do you all get stickers?
Started by jackganssle on Sawmills and Milling
Last post February 13, 2010, 10:08:51 AM
by John Bartley
stickers
Started by OH logger on Sawmills and Milling
Last post December 03, 2012, 08:51:45 AM
by Okrafarmer
Wet stickers
Started by peterduncan on Drying and Processing
Last post July 12, 2008, 05:09:15 PM
by jim king
OSB stickers OK?
Started by Trent on Drying and Processing
Last post May 13, 2007, 12:52:41 PM
by solidwoods
