Arborwear
Author Topic: Need help with tree farmer c7d  (Read 1768 times)
Offline Cypressgator
« on: June 03, 2017, 07:17:04 PM »
Just nought a c7d tree farmer skidder drove it 3 miles to our property  and it will not move now any ideas
Offline Spartan
Re: Need help with tree farmer c7d
« Reply #1 on: June 03, 2017, 08:37:37 PM »
probably need to give us more info.
Does the engine run?
Tranny engage?
Did you check the fluid levels?
Do you have hydraulics or are they dead too?
« Reply #2 on: June 03, 2017, 10:08:48 PM »
Yes the detroit runs good all fluids are good and all the hydraulics are working just will not move  the drive shaft between engine and tranny will mot engage to turn transfer case it has a powershift tranny
Offline kiko
« Reply #3 on: June 03, 2017, 10:56:28 PM »
Since the shaft between engine and torque convertor won't spin you have lost transmission pressure.  Did this occur after it had set for a while, or did it quit while moving?
Offline Spartan
« Reply #4 on: June 04, 2017, 12:05:35 AM »
do you have a pressure gauge for the trans?
« Reply #5 on: June 04, 2017, 12:11:52 AM »
After sitting overnight will take pictures tomorrow  and post them so it will be easier for everyone  mainly me
« Reply #6 on: June 04, 2017, 12:13:45 AM »
Not sure about gage  will look when i take pics
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #7 on: June 04, 2017, 10:31:15 AM »
I vote for a slipping torque converter.
« Reply #8 on: June 04, 2017, 12:37:31 PM »
No gage for trans
And how do i upload pics
« Reply #9 on: June 04, 2017, 12:55:35 PM »
« Reply #10 on: June 04, 2017, 01:24:28 PM »
Offline Spartan
« Reply #11 on: June 04, 2017, 01:32:28 PM »
Forgive the ignorance, maybe the converter is not the same as mine, but what's to slip?
You need to check to make sure you have pressure and supply to your clutches, and to your converter.  Is there air in your trans oil when running?
What model trans is it, there should be a tag on it.  Get yourself a manual for it, can probably download one for free.
It will tell you the check points and pressures you need to test the hydraulic system in it.
Figure out if its your charge pump before you tear into anything converter related.  If its a clark powershift, it should pressurize your clutches first then dump the rest into the converter.  If either of those are compromised, no drive.
« Reply #12 on: June 04, 2017, 03:26:33 PM »
Ok will check that and see what happensthanks to every one for all the info
Offline Autocar
« Reply #13 on: June 04, 2017, 07:17:50 PM »
Theres a chance running it that far and what your saying it may be the seals on the power shift. When the seals get tired they will let transmission fluid go into first,second and third all at the same time. Gets hot and it won't move.Let it cool down and try it if it works ok your going to have to pull the transmission and have it rebuilt. There a simple transmission to rebuild after seeing mine apart but I had a shop do mine and it cost me twenty five hundred.
Bill
« Reply #14 on: June 05, 2017, 08:37:39 PM »
Thanks  autocar trier it this morning and still have no movement in driveshaft from torque converter im in the process of loosening lines and seeing where i have fluid  and where i dont to narrow down where the problem is
Offline kiko
« Reply #15 on: June 05, 2017, 10:42:56 PM »
If the prop shaft is not turning , you have no transmission pressure.  The torque convertor is still connected to the engine because one of those pumps is a hydraulic pump and you stated the hydraulics are operational.   Concentrate on the suction line to the transmission pump.   It must pull the oil uphill and minor leaks suction will cause loss of prime.  There is also a suction strainer at the bottom of the transmission that could be stopped up keeping you from getting suction oil to the pump.  To identify which pump is the transmission pump, the suction hose will go into the transmission case.   Also address the transmission filter . Note the color of the oil,  black oil is associated with internal aluminum failure.
Offline Logger RK
« Reply #16 on: June 05, 2017, 11:01:26 PM »
If it has a Dana P4 300 or 350 transmission with a Twin Disc 6-F 1307 single stage torque converter,there should be a pressure relief on the right side of the torque. It might be worth looking at that also. That's what my 7 has
« Reply #17 on: June 06, 2017, 05:38:12 AM »
Ok thanks logger rk and kiko will check into that today
Offline coxy
« Reply #18 on: June 06, 2017, 08:00:17 AM »
could it have a fiber gear in it  that let loose like the TJ have for the converter
Offline Logger RK
« Reply #19 on: June 06, 2017, 09:09:22 AM »
If it's the brand that I have,I don't remember anything but steel gears. I did go through mine a couple years ago. I did find a shop manual for mine. Hard to find many people that have worked on my kind. I think there less common then the clarks that were also put in the 7.
Tree Farmer ?????????
Started by Autocar on Forestry and Logging
Last post October 17, 2011, 03:54:31 PM
by mad murdock
New (to me) Tree Farmer C5
Started by mjeselskis on Forestry and Logging
Last post January 12, 2015, 09:11:45 PM
by mjeselskis
Tree Farmer C-4 D
Started by Rob on Forestry and Logging
Last post June 10, 2003, 05:45:28 PM
by Rob
Tree Farmer
Started by woodtroll on Ask The Forester
Last post March 06, 2011, 09:03:46 AM
by SwampDonkey
