Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: Need help with tree farmer c7d  (Read 1766 times)
Offline Spartan
Re: Need help with tree farmer c7d
« Reply #20 on: June 06, 2017, 07:36:19 PM »
could it have a fiber gear in it  that let loose like the TJ have for the converter
If the fiber gear lets loose, your hydraulics should be dead too.  At least thats the way it is on the TJ's.  the converter drives the hydraulic pump as well as the charge pump.
Offline Cypressgator
« Reply #21 on: June 06, 2017, 07:54:20 PM »
Is there any other way to determine  what tranny and torque converter is in it i cant find any tags on mine
« Reply #22 on: June 06, 2017, 07:57:12 PM »
But i did find out that i have fluid to the pump but not much comeing out so im going to pull it off  in the morning if the rian alows
Offline Spartan
« Reply #23 on: June 06, 2017, 09:13:01 PM »
sometimes you can't tell if a pump is bad by inspection because the case is wore out inside and the oil slips by.  If its like my pump, you have a port on the top of the housing you can test pressure at if you don't see anything unusual in a visual inspection.
I don't know what model you have, look on the converter housing for the tag, I've seen them there.
Offline kiko
« Reply #24 on: June 06, 2017, 10:22:22 PM »
A way to check the pump out once it is removed , is to remove the fittings and clean the surfaces with brake parts cleaner or such and cover the holes with good tape like gorilla tape.  Now spin the shaft by hand, one side should suck in and the other will protude.   If the pump will move air it will move oil.
« Reply #25 on: June 09, 2017, 06:08:49 AM »
Well i finally got enough brake in rain to work on this thing today  found a hole in suction line and large piece of trash in pump got everything back together and is up and running again thanks to everyone for all the help im sure i will need some more in the near future
Offline coxy
« Reply #26 on: June 09, 2017, 07:04:18 AM »
thats good news  at least it wasn't thousands of dollars to fix  the only trouble is now you have to go to work  :)
Offline Spartan
« Reply #27 on: June 09, 2017, 07:12:57 AM »
yay
good news
Offline Farmin logger
« Reply #28 on: June 19, 2017, 09:02:31 PM »
Would that transmission be the same as what's in the C-5 power shift?
Offline Bromella
  • Member*
  • I'm new to Logging!
« Reply #29 on: July 13, 2017, 08:26:26 PM »
Thank you all for this very informative forum.  I ran into the same problem yesterday and was able to go directly to the potential problem.  I will see tomorrow if everything works.
Offline aksawyer
« Reply #30 on: July 22, 2017, 05:54:49 PM »
Any leak at all in that suction line will cause what is happening. Pulling lines won't let you see the problem. Find the line coming from resivor to the charging pump. Take someashaving lotion  and apply it to all that lines fittings and hose itself. Start the engine and watch the line. If there is a suction leak it will pull the shaving lotion in also. Apply it a few times when you find leak to assure yourself. If there are no leaks move to the pressure setup valve and shim it till you get it least good pressure.
C5D tree farmer
Started by pigpen on Forestry and Logging
Last post June 17, 2012, 06:08:18 AM
by jftimber
c5 tree farmer
Started by MEloggah on Forestry and Logging
Last post March 18, 2013, 04:13:56 PM
by MEloggah
Tree farmer c4c
Started by deghan2172 on Forestry and Logging
Last post April 02, 2017, 08:52:41 AM
by bushmechanic
C4B tree farmer
Started by moose62 on Forestry and Logging
Last post May 18, 2013, 01:34:07 AM
by moose62
