Arborwear
Author Topic: Pre cast concrete Foundation?  (Read 446 times)
Offline Dflick
  • I'm new
« on: June 05, 2017, 01:45:11 AM »
Has anyone ever heard of or used Eco blocks  for a foundation?  I am going to build a 20x 24 timber frame on my property.  Problem is i cannot get a concrete truck up my driveway.  My dirt work contractor suggested using those 2'x2'x4' concrete blocks (eco blocks) as footings I would use 9 of them and bury them about a foot in the gravel pad.  It seems like a good idea but i have not found any examples of houses built on these things.  Any thoughts?
Offline red
  • we will never forget
Re: Pre cast concrete Foundation?
« Reply #1 on: June 05, 2017, 05:01:16 AM »
What we have is called Mafia Blocks made from extra cement that is washed out of cement trucks. So no two blocks exactly the same . Sells for about $40. Same rough dimensions 2x2x4.
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Don P
    • Calculator Index
« Reply #2 on: June 05, 2017, 06:28:50 AM »
You probably can't get a fire truck in either  :)
We pulled the concrete trucks up here with a dozer but I happen to know the brush truck is the only one that can get to the house. I wasn't always this brilliant  :D.
Offline Dflick
  • I'm new
« Reply #3 on: June 05, 2017, 12:21:45 PM »
these blocks are about $130 a piece.
Concrete foundation and sill
Started by Chris Nutbean on Timber Framing/Log construction
Last post January 20, 2017, 09:20:00 AM
by Chris Nutbean
Circle Mill Foundation (concrete slab?)
Started by SPD748 on Sawmills and Milling
Last post March 25, 2010, 07:01:06 AM
by bandmiller2
Simpson Strong tie for concrete foundation to post
Started by mmhailey on Timber Framing/Log construction
Last post June 22, 2010, 03:54:32 PM
by Raphael
30-30 cast loads
Started by spencerhenry on The Outdoor Board
Last post September 06, 2006, 09:58:21 PM
by spencerhenry
