TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Are these Bradford Pears?  (Read 688 times)
Offline mkitchin
« on: June 05, 2017, 04:01:54 PM »
Hello all. First post here. I have seen many issues caused by Bradford Pears over the years, but I have never had any in my yard before. I'm in the Nashville, TN area. I just moved into a new house. I'm far from an expert (obviously) in this are. I have 2 trees that seem to resemble Bradford Pears. One is decent sized and close to my house. Can someone help me confirm if either of these are Bradford Pears? If so, everything I read tells me I need to get rid of them and plant something else. I love having a tree in each of these spots. I hate to have to remove a tree, but I know most of these eventually split and cause a lot of damage. The leaves on the big tree don't look like a Bradford, but the trunk formation seems suspicious. Everything about the little tree looks like a Bradford. Any information would be greatly appreciated! Thanks.
Big Tree:
Little Tree:
Offline Ianab
Re: Are these Bradford Pears?
« Reply #1 on: June 05, 2017, 04:22:23 PM »
Welcome to the Forum.
First tree look like Wild Cherry, Prunus avium. It's native to Europe, but it's a common ornamental and even naturalised in many parts of the world. Should have nice pink or white blossoms in the Spring.
Not sure on the 2nd. I'll leave that to someone else.
Offline curdog
« Reply #2 on: June 05, 2017, 08:31:21 PM »
Second one is a Bradford Pear...
Offline thecfarm
« Reply #3 on: June 05, 2017, 08:52:22 PM »
Them suckers need to come off so it will bear better.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #4 on: June 06, 2017, 07:59:19 AM »
Yes, I am with curdog on the 2nd one.
Offline plantman
« Reply #5 on: July 09, 2017, 04:16:36 PM »
First on is definitely a cherry perhaps Kwanzan, not sure. It looks like it was grafted. Second tree is a Cleveland Select Pear , also called Chanticleer pear. The first pears in ornamental production were Bradford Pears but they were very wide and round in form. The Cleveland Select is narrow and tall like yours.
Offline mkitchin
« Reply #6 on: July 09, 2017, 05:14:31 PM »
Thanks. Does it have all the undesirable characteristics normally associated with bradford pears? I assumed it did, so I planned on removing it in the fall.
Offline plantman
« Reply #7 on: July 09, 2017, 05:54:52 PM »
The Cleveland Select Pear was developed to suit smaller properties where people didn't want a 35' wide tree but also because the Bradford was fairly weak and tended to split when they get a ice load on them. So the narrow tall tree tends to avoid that problem.
So this tree satisfies someone looking for a fast growing narrow tree that will produce an abundance of flowers. It's good for privacy between houses or above the top of a fences. It makes a nice screening with you plant a number of them in a row. The leaves are not too big and fairly easy to cleanup in the fall. The one thing I'm not thrilled with is that the central leader or leaders can grow too fast  and the tree can look lanky. So sometimes it doesn't have a great natural look . But for the most part it fills a need and doesn't seem to have too many insect or disease problems. It's a very popular tree in the nursery business.
Anyone in Bradford PA ...
Started by coppolajc10 on Sawmills and Milling
Last post July 13, 2015, 07:13:04 PM
by nomad
Bradford pear trees
Started by T A Derrickson on Ask The Forester
Last post May 02, 2014, 07:34:04 AM
by chain
So if i graft a bradford pear scion to OHxF 333 rootstock, will that dwarf it?
Started by tlbean2004 on Tree, Plant and Wood I.D.
Last post February 19, 2015, 09:57:40 AM
by mesquite buckeye
Pears
Started by Magicman on FOOD! FOOD! FOOD!
Last post October 31, 2014, 05:39:38 PM
by POSTON WIDEHEAD
