Arborwear
Author Topic: Ringmaster bowl lathe  (Read 658 times)
Offline JV
  • Live - love - laugh a lot today.
« on: June 06, 2017, 06:12:34 PM »
Anyone used a Ringmaster lathe?  I dug mine out from storage earlier this spring and made a vase using scrap silver maple and cherry.  The previous owner didn't set the knives right leaving a rough meeting point.  I reset them and smoothed the surface.  I found the angle chart and did the one vase.  I understand that you can vary the angles to get more rounded sides but not sure of the settings.  For 3/4" stock the angle is 22.6 degrees.  Anyone try varying the angles for roundness?
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline Jemclimber
Re: Ringmaster bowl lathe
« Reply #1 on: June 07, 2017, 08:56:20 AM »
I've heard of cutting rings on a wood lathe to make a bowl or a vase. I've never seen a lathe dedicated to cutting rings. Do you have any pics of the lathe or of the vase you made?
lt15
Offline Savannahdan
  • Retired.
« Reply #2 on: June 07, 2017, 10:56:24 AM »
Started to buy a used one off of CL years ago and didn't move quick enough.  If I recall they are neat for doing segmented bowls and platters.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline JV
« Reply #3 on: June 07, 2017, 11:10:28 AM »
The lathe is a 1/2" mandrel with adjustable angle knives, one on each side of up to a 12" blank.  The rings are progressively smaller to stack and glue.  The vase is from scrap silver maple and cherry with 3 coats of shellac.  Basically you see the end grain of the blank.  I want to laminate different woods to see what I can get.  I have some osage orange that would give a yellow and black zebra effect at least for awhile.
John
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: June 08, 2017, 02:56:29 AM »
Now you did it. One more project for me to build...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline JV
« Reply #5 on: June 08, 2017, 10:08:39 AM »
I think I found the answer to my question.  Shopsmith sold a Ringmaster attachment for the Mark V.  They did a video called Ringmaster 3:making curved turnings.  It is 45 minutes long, unfortunately my attention span is only a fraction of that but I'll get there.   ;D
John
Offline Kbeitz
    • My Hobbies
« Reply #6 on: June 10, 2017, 12:50:14 PM »
I will try my hand at making one.
Offline JV
« Reply #7 on: June 10, 2017, 05:20:17 PM »
It is a fairly simple machine.  I want to try more intricate designs.  Taking two 3/8x3/4 pieces and routing a half round or a triangle the length and gluing a colored dowel rod or a small square for a diamond shape between them.  Use this as a sub-assembly, for lack of a better term,  and glue those into a segment to create a stylised flower as an example.  Lots of work but on those miserable rainy or snowy days a fun diversion.  But that requires a bit of attention span.   :D
John
New Lathe
Started by metalspinner on General Woodworking
Last post December 03, 2008, 04:10:31 PM
by SwampDonkey
New Lathe???
Last post December 18, 2007, 09:20:02 AM
by metalspinner
log lathe
Started by revid on Sawmills and Milling
Last post February 05, 2016, 09:19:38 AM
by Fundyheather
Log Lathe?
Started by getoverit on Sawmills and Milling
Last post November 27, 2017, 05:45:18 PM
by thecfarm
