Arborwear
Author Topic: Need a Thermometer and Humidity Gauge for my new solar kiln  (Read 321 times)
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
I finally have my solar kiln up and operating, but I have not purchased a meter to measure the temperature and humidity.  The kiln is in an area without electricity so I will need one that is battery powered.
I will only be going by on a weekly basis so I am wondering if I should consider a data logger that plugs into my laptop to download the data?
Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Online GeneWengert-WoodDoc
Re: Need a Thermometer and Humidity Gauge for my new solar kiln
« Reply #1 on: June 08, 2017, 06:32:33 AM »
We never used such measurements to run the kiln.  A meter is not needed and the readings will,not change how you operate the kiln.  More importantly is the daily moisture content of the wood, especially above 50% MC. But even those readings are not critical with the VT design and operation.
Offline losttheplot
« Reply #2 on: June 13, 2017, 06:53:46 PM »
You can get a battery operated temp/ humidity meter from eBay for less than 5 dollars.
The sensors are on around 6 feet of wire.
Its interesting to watch what's going on inside the kiln.
They are meant for reptile terrariums.
DON'T BELIEVE EVERYTHING YOU THINK !
Solar kiln thermometer/hygrometer
Started by WLC on Drying and Processing
Last post April 06, 2017, 09:46:39 PM
by YellowHammer
humidity in solar kiln?
Started by xlogger on Drying and Processing
Last post September 17, 2015, 06:10:16 AM
by xlogger
thermometer for vacuum kiln
Started by wd4000 on Drying and Processing
Last post May 19, 2014, 09:09:48 PM
by Den Socling
moved
MOVED: thermometer for vacuum kiln
Started by chet on General Board
Last post April 22, 2014, 07:48:13 AM
by chet
