Arborwear
Author Topic: Thermostat question  (Read 1579 times)
Offline Spartan
Thermostat question
« on: June 07, 2017, 10:15:48 PM »
So its been warmer here and in the 80's on the job.
My Detroit and trans are running warmer than than the old one did.  After putting in a reconditioned motor and rebuilding my converter.  Figures....
Its a timberjack 450, detroit 453, clark 28000 powershift.
Right now on a long heavy haul uphill its hitting 205 on the engine side and 220 on the trans.
I took the oil cooler out to see if it was plugged up, no.  It used to run cooler than that.
The trans cools down quick when not pulling, the motor slower.
So the thermostat I had in it I think is 185.  I don't have time to order a detroit 170.
So I have two generics, a 160, and a 180.  I am reluctant to put either in because one is only 5 degrees difference and the other seems too cold.
Anyone run a 160?
And... am I just paranoid with those numbers?  Maybe its fine, I'm just used to cooler.
Brian.
Offline treeslayer2003
Re: Thermostat question
« Reply #1 on: June 07, 2017, 11:45:28 PM »
the 160 is fine. nor5mally my trans runs about 10 degrees cooler than the engine.
Offline snowstorm
« Reply #2 on: June 08, 2017, 06:45:12 AM »
205 is to warm unless its only for a short time.  i have a 28000 clark my book says 200 to 250
Offline Spartan
« Reply #3 on: June 08, 2017, 06:55:52 AM »
thanks guys,  Ill throw the 160 in and see what happens.
Offline central pa
« Reply #4 on: June 09, 2017, 06:11:34 AM »
We also have a 450 tj same engine and transmission both professional rebuild but the transmission heats up to quickly which pushes the engine temp to high still working on figuring out why
If anyone has any ideas would be greatly appreciated
Offline Spartan
« Reply #5 on: June 09, 2017, 07:10:06 AM »
your brake isn't adjusted too tight is it?
Oil cooler plugged?
That stinks, I hate troubleshooting them.
Thermostat didn't really help btw, I had my doubts.
« Reply #6 on: June 09, 2017, 10:19:54 AM »
maybe a dumb question, but possible wrong filter? to tight? i am thinking its a restriction creating heat.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #7 on: June 09, 2017, 10:55:44 AM »
205 degrees is NOT too hot. Engines run better at higher temperatures. Any temperature that does not cause boiling is OK.
Offline snowstorm
« Reply #8 on: June 09, 2017, 04:06:50 PM »
The old saying with a 671. If it gets over 200 degrees buy an extra head for it.
Offline Spartan
« Reply #9 on: June 09, 2017, 08:57:10 PM »
My book says not to let the engine temp go over 200.
Today it was about 60 out.  engine was 165-170 working.  Trans was 195.
Do you have the remote filter?
It needs to be a full flow design.  Mine takes a Wix #51403 or comparable.
I wouldn't think that would be the issue for you.  The oil comes out of the pump directly into the filter, then through the regulator valve.  After it hits 280psi it dumps the rest into your converter.
I would think you would have drive issues if it was a wrong filter and was resticting.
Do you have drive issues?  Hows your oil level and oil look?
Offline central pa
« Reply #10 on: June 09, 2017, 10:24:18 PM »
That filter idea is good have to check into that Monday
As far as the drive seem very sharp not sponge or sluggish .
Charge pressure is aaround  280 to 295
We just changed the return line  from the cooler to the Trans was a 3/4 and the specs  called for 1" can hardly believe it was that haven't run it since
Offline central pa
« Reply #11 on: June 13, 2017, 10:11:29 PM »
Changing that line might have made a small difference not much
checked the filter I forgot the nnumber but it spec out to yours with a flow capacity of 20 to 30 gpm
I was trying a couple of things today it runs the coolest at 3/4 rpm if I held it flat I could almost see the Guage go up is that maybe how your supposed to run it
Is there something like to much oil in the transmission it's right at the full mark or a little over
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #12 on: June 14, 2017, 08:02:42 PM »
do the transmissions cool through the engine radiator like a car?
I think Central Pa is on to a common thread,
Trans loads are driving the temps up
Does the trans fluid smell burnt or hot?
Radiators clean, open and fully flowing?
D
« Reply #13 on: June 14, 2017, 10:35:34 PM »
D
the old clarks do. and yes you right, trans will drive up engine temp. thats why i find it strange when they say the trans runs alot higher than the engine.
Offline Spartan
« Reply #14 on: June 18, 2017, 12:03:33 AM »
Its a remote cooler on the frame side in the engine bay.
Low oil is usually a culprit for higher temp, but also overfull could do that as it expands under heat it can get into the gears and foam and thats not great either.
Offline central pa
« Reply #15 on: June 20, 2017, 03:38:59 PM »
Did you get yyours figured out spartan
I was still trying a couple of things on ours. Our skid road is about a half mile fairly flat with a short steep part at the back on the first drag going back through I kept the rpms almost maxed out till I got to the back the Trans temp was at 210. Then this afternoon I used the temp gun with the engine at 190 the Trans at 210 oil cooler input showed 210 output 198.
does anyone know is that what I should expect .
I'm beginning to think there might be an internal air leak
Offline Spartan
« Reply #16 on: June 20, 2017, 10:08:07 PM »
Geez, I wouldn't be too worried about those numbers.  especially after a half mile skid.
No, I did not figure our mine yet.
Today was rough.  I was constantly stopping to cool it down.
Tomorrow is supposed to be 10 deg. cooler, so I will run it but only for a half a day.  I have to fall in the morning.  At the end of the day I will pull my water pump and check for blockage or corrosion,  doesn't seem to be anything else at this point so I will check that off my list.  I don't seem to be getting circulation in my reservoir with the t stat open.
We'll see.  the engine sat for a while and I did notice some corrosion in the hose port so its worth a shot.
A suction leak would show up in your oil, and your drive would suffer a bit.
Was the trans charge pump replaced?
Offline timberlinetree
« Reply #17 on: June 25, 2017, 05:52:56 AM »
Most likely  not, but I  have had radiator cap problems on 2 engines this summer. Fixed it :-\. Good luck with it!
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Offline Spartan
« Reply #18 on: June 25, 2017, 09:10:33 AM »
my water pump was fine.
Never thought about a cap problem.
Offline air1514
« Reply #19 on: June 25, 2017, 10:34:59 AM »
Check your fan belts. I couldn't figure out why my 353 was overheating on long pulls and it turned out being the fan belts were slipping a little. I was to the point of having the radiator recored. But after tighting the belts it's doing fine. Never gets hot now.
Thermostat help please
Started by Jack72 on Firewood and Wood Heating
Last post March 07, 2014, 10:23:14 PM
by Jack72
Thermostat(s) for owb
Started by chipsfly09 on Firewood and Wood Heating
Last post January 30, 2010, 09:47:25 PM
by chipsfly09
Thermostat
Started by Furby on Wanted
Last post November 12, 2005, 11:30:54 PM
by Furby
Second thermostat trouble!
Started by Firewoodjoe on Firewood and Wood Heating
Last post November 24, 2015, 10:58:05 PM
by r.man
