Arborwear
Author Topic: Timber frame Cross for church  (Read 757 times)
Offline kng
« on: June 08, 2017, 09:01:21 PM »
Our church is wanting to replace the timber frame cross in front of our church due to bad checking. I believe the cross is red oak, because that's what was growing there originally, and after it died they sawed it up for the cross.
They want to replace it with white oak logs, which I have two 10' logs that are about 13" and 20" diameter.  The cross is about 7.5"x8.5" and 9 foot tall.
How should I approach this?  Should I box the heart?  Can I cut the half lap joints green?  I was planning on putting 3 ~1" white oak pegs cut from the same log.
Thanks for the help!
-Kyle
2015 LT15G19 with Power Feed and custom trailer
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: Timber frame Cross for church
« Reply #1 on: June 08, 2017, 09:39:38 PM »
Hope they're not going to throw out that "Old Rugged Cross"...
Herb
Offline kng
« Reply #2 on: June 08, 2017, 09:45:54 PM »
Good point Herb!  I'm not sure what the plans are for the old cross.  What do you recommend? Re-saw to get boards from the old tree, or leave as is?
Offline Roger Nair
« Reply #3 on: June 08, 2017, 10:34:32 PM »
If you can, try to cut the logs to yield free of heart timber and trim off sap wood.  With out a heart the checking in the new cross would be more minimal.  Water seeping into the joint should be addressed by sloping the top surface and the bottom surface should have relief cuts so a drip edge is formed.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
Offline Briankinley2004
« Reply #4 on: June 10, 2017, 10:07:46 PM »
If the old,one is still solid you can fill the cracksmwith epoxy then coat with thinned CPES. Finish coat with varnish and it will be born again 😀  You can also use same procedure on the new one with several coats of spar varnish assuming it is dry
Offline Don P
    • Calculator Index
« Reply #5 on: June 11, 2017, 06:55:00 AM »
I don't think you'll be able to get free of heart with the logs you mentioned, that would help with checking. I'd be tempted to put a copper cap on the horizontal wood to keep water from soaking in.
Offline kng
« Reply #6 on: June 13, 2017, 06:39:52 AM »
Do both of these look like white oak?
Offline btulloh
« Reply #7 on: June 13, 2017, 07:33:46 AM »
The one on the left looks like post oak to me.
HM126
Offline kng
« Reply #8 on: June 18, 2017, 11:41:37 AM »
Thanks btulloh!
Offline kng
« Reply #9 on: June 26, 2017, 09:01:48 PM »
Will the post oak and the white oak grain and color be different? I asking if it will be obvious that the horizontal and vertical beam doesn't match.
Cross for the church.
Started by hackberry jake on General Woodworking
Last post February 07, 2012, 10:01:02 PM
by WDH
Milling Timbers for a Church Cross
Started by Ga_Boy on Sawmills and Milling
Last post September 28, 2006, 03:05:56 PM
by Beweller
10' X 12' Timber Frame Shed (Raising the Frame)
Started by jander3 on Timber Framing/Log construction
Last post February 03, 2012, 07:17:55 PM
by jander3
Timber size calculator and timber frame design.
Started by Joe Vachon on Timber Framing/Log construction
Last post July 07, 2017, 10:25:46 PM
by Roger Nair
