Arborwear
Author Topic: Skiddertire, can i use ag tires?  (Read 2253 times)
Online mike_belben
  • Pulp Friction
Re: Skiddertire, can i use ag tires?
« Reply #20 on: November 03, 2017, 08:27:05 AM »
ether for what?
Reseating the tire onto the bead after it leaks down over the weekend.
Online teakwood
  • Switzerland
« Reply #21 on: November 03, 2017, 09:26:59 AM »
and if i'm buying forestry's?  put them on the back or front?
Offline treeslayer2003
« Reply #22 on: November 04, 2017, 09:13:12 AM »
i always try and run real skidder tires on back if i only have two, combine tires on front.
note about tubes, i have had terrible luck with combine tubes splitting. if you can try to get natural rubber tubes.
Online teakwood
  • Switzerland
« Reply #23 on: November 04, 2017, 12:25:19 PM »
what does combine tires mean?
i am certain that such tubes i would have to order from the US.
here i can just get normal ag tubes for around 100$. will they hold? or should i buy really forestry tubes?
Offline mills
« Reply #24 on: November 04, 2017, 06:52:53 PM »
After a couple of hard learned lessons, I had to go with forestry tubes.  :(
« Reply #25 on: November 05, 2017, 09:16:54 AM »
combine/ag tubes are not natural rubber......i'm not sure what they are made of but they are thin and don't seem to last long in the woods. its better than nothing in a pinch. natural rubber are thick and last a long time. i think it has to do with the amount of flexing our tires go through. natural rubber are twice as much and hard to find.
Online teakwood
  • Switzerland
« Reply #26 on: November 05, 2017, 09:39:30 AM »
thanks a lot guys for you help.
Firestone makes natural forestry tubes at 165$
http://www.petestirestore.com/231x26-to-75055R265-Firestone-Natural-Rubber-Forestry-Tire-Tube-TR218A_p_6187.html
Offline Stephen Alford
« Reply #27 on: November 05, 2017, 10:06:32 AM »
   Here at least , ag are 8 &10 ply combine 12 and forestry specials 16.  The old rims caused ware holes in the tubes from rust etc. tried cleaning rims only temporary help. The natural rubber tubes are about 300. Combine tires run 1000. To save the tube when a flat occurred in the woods I changed it right there. The combine tires were much easier to do by yourself than the forestry specials. Need spoons 2  long and one short . a large jar of vasiline  for tire lip and rim . Had to lug an air pig. Biggest issue with the combine tires were punchures in the side. Usually from me not cutting square. Found the ag tires did not work for me.  The clearing saw seemed to end the punchure problem. With the net forestry tires seem to be passing through middle men making them more expensive.  Tires or lack thereof played a part in selling my skidder. Did not mind the tire change in the summer but in deep snow it was a pita.  Good luck with what you decide.  Should add forestry tires with natural rubber tubes installed about 2500 each.  Skidder was 38 years old and still working.
logon
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #28 on: November 05, 2017, 03:07:24 PM »
A lot of money for tires [ the good ones] would have less down time than the cheap ones.
For me, I'd go with the 16 ply forestry and they would last for years, Chained up would last even longer.
It's what the guys I buy logs from are doing.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Tires
Started by shawn55 on Forestry and Logging
Last post March 15, 2015, 10:45:26 AM
by smwwoody
Looking for: 18.4 x26 or 23.1 x26 tires
Started by 5akman on Wanted
Last post December 25, 2011, 12:33:26 PM
by 5akman
Bob Cat Tires
Started by MartyParsons on General Board
Last post December 17, 2017, 09:33:13 PM
by NWP
Big Tires
Started by Magicman on General Board
Last post May 02, 2011, 12:37:07 PM
by tyb525
