EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Solar Kiln build  (Read 6987 times)
Offline Ianab
Re: Solar Kiln build
« Reply #140 on: August 12, 2017, 08:54:14 PM »
If the core of the wood is still wet, then moisture will still be migrating from the core to the surface. So if the fans and "heat" are off, that moisture won't be evaporating, and so the MC of the surface would increase slightly.
Offline YellowHammer
  • Take steps to save steps
    • Hobby Hardwood Alabama
« Reply #141 on: August 12, 2017, 11:23:13 PM »
As Ianab said, the case and core have probably not equalized, so there is migration of the core moisture to the case.
The best, least expensive, most accurate moisture meter is using the oven dry method.  It utilizes a cheap food scale and a microwave or conventional oven.
Online Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #142 on: August 15, 2017, 09:44:08 AM »
Thanks for all the help...
Love machine shop work
and Wood work shop work
And now a saw mill work
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
New/First Solar Kiln Build
Started by TCharters76 on Drying and Processing
Last post June 20, 2016, 09:28:15 PM
by samandothers
Solar Kiln Build
Started by Deese on Drying and Processing
Last post May 17, 2017, 07:16:44 AM
by nativewolf
Solar kiln build
Started by Fil-Dill on Drying and Processing
Last post February 12, 2011, 09:49:54 AM
by Den Socling
