Probably slightly off topic, but...Seems like I had always heard that the primary considerations for stickers was that they were of consistent thickness, and dry. I know it is probably convenient to mill them from the client's logs but, a year or so down the road, do you get any feedback about mold or sticker stain from stacking wet wood on wet wood? I have seen sticker stain on boards that were stickered with freshly milled stickers, and have tried to plane it out, seldom with good results.
Only the cows will know.
(Image hidden from quote, click to view.) Yes, cows can be very sensitive!Reminds me of the horses in Ocala Fl
When I stack 4/4 I put sticker between the layers but put the boards tight together in each layer which I assume is correct but if I were to stack let's say 8/4 or even 16/4 should I leave air gap between each board ? If I would cut a bunch of 4 by 4 post should it in a sense be stickers in the verticle and horizontal direction and at what thickness should you worry about mold or mildew between boards? And how do you all feel about using cottonwood for stickers sorry to drag on with questions
Started by OH logger on Sawmills and Milling
Started by gtr on Sawmills and Milling
Started by whittle1 on Drying and Processing
Started by pineywoods on Sawmills and Milling
