BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Sterilize air dried wood  (Read 2761 times)
Offline flatrock58
« on: June 14, 2017, 08:54:06 AM »
I have read many post about the benefits of kiln drying wood and sterilizing it to kill powder post beetles.  I was wondering if you could sterilize air dried wood without kiln drying it.  That would allow you to sell air dried wood free of bugs, but not spend all the time kiln drying the wood.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: Sterilize air dried wood
« Reply #1 on: June 14, 2017, 10:17:11 AM »
And what method would you use while air drying enable you to assure the buyer that the wood is free from "bugs" ???
Rereading your post, I believe that that is actually your question...
Good Luck!
Herb
Offline GeneWengert-WoodDoc
« Reply #2 on: June 14, 2017, 11:19:53 AM »
We sterilize green or air dried wood all the time to prevent insects in the tree from being transported to another country. The PPB does not like the high MCs (30%MC or higher) seen in air drying, so there is a small risk for this insect. Other insects like the higher  MCs.
However, if you were to heat the wood to 133 F throughout the piece, that only kills existing insect infestations, but does not prevent new infestations. Therefore, you could not be sure that the lumber you sell is bug free,  as it could get infected after treatment
Offline flatrock58
« Reply #3 on: June 14, 2017, 11:51:48 AM »
Gene.  I was thinking of building a 10' x 6' x 6' insulated box.  Then I could sterilize it after it had been air dried down to 14% or so.  I am also planning on building a solar kiln and need a way to sterilize wood after it is dry.   This would give me a way to sterilize both air dried and kiln dried wood.
6' extension
resaw attachment
CBN Sharpener
« Reply #4 on: June 14, 2017, 10:07:05 PM »
That would work
Offline tawilson
« Reply #5 on: June 15, 2017, 07:14:05 AM »
Curious as to what you are using to sterilize it?
2017 LT40HDG35 WIDE
BMS250 and BMT250 sharpener/setter
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: June 15, 2017, 07:35:17 AM »
I bet that it is heat.
Offline flatrock58
« Reply #7 on: June 15, 2017, 10:49:01 AM »
Haha.  WDH is right.  But what kind of heat.  Read some post where Yellowhammer was using halogen heat lamps.  Also I have a gas furnace I could rig up.  Will try the heat lamps first then go from there.
6' extension
resaw attachment
CBN Sharpener
Offline tawilson
« Reply #8 on: June 15, 2017, 04:08:07 PM »
Okay my rookie status is showing. I assumed kiln dried was using heat and you were using something like a borax solution.
2017 LT40HDG35 WIDE
Offline samandothers
« Reply #9 on: June 15, 2017, 05:22:33 PM »
I had thought about building a heat chamber also, but that is close as I got to buildingone. I was going to use a thermostat that could be programmed for a band of temperature to allow 150 or 155 as max.  The sensor then place in the unit near the center and on the bottom of the stack.  I had some input from another member about using a oven heating element to supply the heat.  I understand there is a need to have the air circulated to even the temps.  Make sure the equipment you use can withstand the temperatures.
I look forward to hearing how your build goes and the chamber performs.
Offline flatrock58
« Reply #10 on: June 15, 2017, 05:26:54 PM »
Tawilson. The Haha was for WDH for trying to be funny.
6' extension
resaw attachment
CBN Sharpener
Online Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #11 on: June 16, 2017, 02:25:03 AM »
I bet sulfur candles would work...
http://www.dave-cushman.net/bee/fumcandle.html
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline YellowHammer
  • There's a lot more to it.
    • Hobby Hardwood Alabama
« Reply #12 on: June 16, 2017, 08:43:56 AM »
The only reliable and safe thing I have used are sealed, halogen work lights.  They are every inefficient and convert a lot of their electrical input into heat.    Any heater with a fan, such as a dedicated space heater, milk parlor heater, etc will die within weeks, sometimes days, due to the nature of the air.  They also have safety thermostats which will turn them off prematurely when the area gets too hot.  I have tried many things, and halogens work lamps will last for a year or more before I have to replace the bulbs for about $5 each.  It's very important to make sure not to create hots spots over of around the lamps and risk a fire, so I always put them in front of the kilns fans away from combustibles.  Since they are sealed, they are impervious to the kiln moisture and corrosive environment, and can be purchase for about $20 each at Lowes or HomeD
Hobby Hardwood Alabama.com
LT40 Diesel Hydraulic, Stihl 028, MS440, MS660, 2 Kilns
« Reply #13 on: June 16, 2017, 08:14:31 PM »
You might call your insurance company to make sure you are covered with fire insurance with any heater that you use. Avoid the use of the word kiln, as they will think it is a ceramic kiln that gets really hot.
Remember that the PPB is inside the wood, so any chemical or fumigating gas or heat must penetrate throughout the entire piece of wood, not just the surface.  When using heat, remember that fine dust ignites at maybe 250 or 300 F.  Keep the chamber free of dust indeed.
Maybe you can find an small, old, closed trailer for heating.  Insulate it, of course.  A household furnace using propane could be used for heat with control modification but it does require oxygen to work, so the best is probably using a plenum duct rather than putting it into the chamber.
Offline PNWRusty
« Reply #14 on: June 29, 2017, 05:24:43 PM »
Halogen's and all electrical lights convert 100% of the electrical input into heat. Even the light they produce is converted to heat once the light hits an object (or the air for that matter). A 500W light produces 500W of heat.
« Reply #15 on: June 29, 2017, 11:00:53 PM »
Yes, the first law of Thermodynamics is still in effect even for light bulbs, but that's not the whole story.  I'm talking about luminous efficiency, or more correctly, luminous efficacy (lumens per Watt), and the increased amount of electrical energy required for inefficient types of light bulbs to produce the same amount of visible light.
The two most likely general types of light bulbs that make a reasonable heat source in a kiln are incandescent and halogen.  Sodium and others may work, but have packaging issues I don't want to deal with.
Incandescent lamps typically have short life spans and use significantly more watts than compact fluorescent lights and halogen lamps to to produce the same lumens, or light output. More than ninety percent of the energy used by an incandescent light bulb escapes as heat, with less than 10% producing light. https://www.energystar.gov/ia/partners/promotions/change_light/downloads/Fact%20Sheet_Lighting%20Technologies.pdf
Halogen lamps are slightly more efficient than incandescent lamps, but operate at a much higher lamp temperature. These high operating temperatures can present a safety concern in some fixtures, some of which consume as much as 500 watts each.
Since these two types of bulbs have a relatively low luminous efficacy, they require more electrical energy to achieve the same amount of visible light.  The less efficient the light bulb, the more energy required to produce the same amount of visible light, so more Watts per lumen, or more energy required per lumen, or ultimately, more heat generated per lumen, which is exactly opposite of the corporate light bulb makers strategy.  They want a highly efficient light builb that only uses minimum electricity to produce the same amount of visible radiation.
With incandescent, its rare to get the high wattage levels found in common and cheap halogens.  Most incandescent lights max out at about 100W, and even heat lamps, which may have a higher rating, rarely get to 500 Watts, or the rating of a single halogen.  Most incandescents are not in weatherproof housings, so don't last long in a kiln environment.  These are not a good, long term approach to heating a closed space.
So my preferred and cheap way to generate safe heat from electrical energy, barring actual heat strips, which are an electrocution hazard, is to simply use multiple halogen lights.  So instead of using five 100 Watt light bulbs, and all the associated weatherproof fixtures associated with it, I prefer to use sealed, weather proof 500 W halogens, which are commonly found at any Lowes or Home Depot.
This reference uses the phrase, "buy lumens, not Watts"
https://energy.gov/energysaver/lumens-and-lighting-facts-label
However, for heating a kiln, "buy Watts, not lumens."
Offline farmfromkansas
« Reply #16 on: August 06, 2017, 05:04:59 PM »
I'm looking at getting an old reefer trailer, of course they are taking the cooling unit off, so it will have a hole in the front to frame in.  Considering making a shelf for my space heater to sit on, and cut a hole for the space heater to shoot the heat inside, and opening a small vent down low in the opposite end.  This is to keep the heater from shutting down the way they do when inside the chamber, and make it get the inside of the trailer hot enough to kill all bugs and eggs.
Offline scsmith42
    • Whispering Pines Farm
« Reply #17 on: August 06, 2017, 08:17:34 PM »
FWW magazine had an article several years ago about a simple home sterilization chamber that used foil backed foam board and a space heater.
A paraphrased version is attached.
Tom's 3638D Baker band mill
« Reply #18 on: August 07, 2017, 07:16:58 AM »
Because the air temperature in a sterilization chamber must be 150 F or even hotter in order to get the wood up to 133 F throughout the piece, the insulation must be able to safely withstand the high temperature and the heater must be able to get the air that hot as well safely.  You also need a high temperature limit switch that will shut the unit off if something goes wrong and it overheats, especially if the sterilization chamber is in a house or shop that could be damaged by fire.  Also, oftentimes, home owner's insurance will not cover damage caused by an accident in a business operation that is operated inside the home.  Bottom line is to be very safety conscious.
Note that although solid wood might need to be around 450 F to ignite, fine dust will ignite at much lower temperatures.  Many possible heaters will be hot enough to ignite dry wood dust that would accumulate in the chamber.
« Reply #19 on: August 07, 2017, 06:51:35 PM »
Would it be better to build a solar collector on the south side of the reefer trailer?  Plan to position it long ways east and west.
« Reply #20 on: August 07, 2017, 07:16:32 PM »
Flat rock,
Did you build your chamber?  I continue to put off an attempt but have not ruled it out.
Online thecfarm
« Reply #21 on: August 07, 2017, 08:12:01 PM »
farmfromkansas,welcome to the forum.
Do you have a mill?
« Reply #22 on: August 07, 2017, 11:22:31 PM »
Had an MP32 for about 10 years.  Mostly my own use, sawed a little for neighbors and friends.  Air dried all my lumber, oak and walnut work ok, but ash and elm mostly go bad to borers and ppb.  Want to make a better way to dry and store lumber, including sterilizing and killing bugs.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #23 on: August 07, 2017, 11:33:53 PM »
FFK,
Welcome to the Forum, where are you in the land of OZ?  I'm near Eudora, in Johnson County.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
« Reply #24 on: August 08, 2017, 07:30:15 AM »
Saline county, near Gypsum.
Offline flatrock58
« Reply #25 on: August 08, 2017, 10:53:28 AM »
samanadothers.  I am still planning on building a chamber, but need to finish my workshop.  I started it last summer and it has progressed slowly since I work on it by myself between other projects.  I am getting closer to having it done.
My plan is to build a 7'x7'x12' insulated chamber.  It will have two 1'x8' insulated doors that can be opened to let in the hot air from the solar collector.  then at night or when sterilizing they can be closed and the air rerouted and halogen lamps can be used for heat.  At least that is my plan.  Gene may have some input that will change that plan.   My quick crude drawing is attached.
6' extension
resaw attachment
CBN Sharpener
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #26 on: August 09, 2017, 07:13:05 AM »
Flatrock, my plan is very similar to yours. Please keep us updated, I was thinking of thermostat controlled vents that would open and close both vents. I've got part of a walk in cooler I'd like to use for chamber, just need to find a few more pieces.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
« Reply #27 on: August 09, 2017, 06:02:49 PM »
The collector can be attached to the side at roughly a 45 degree angle.  The reefer wall itself should not be used.
Offline 69bronco
« Reply #28 on: August 09, 2017, 08:36:49 PM »
Gene, would you clarify? Using reefer panels for box, not collector.
« Reply #29 on: August 10, 2017, 07:05:05 AM »
My comment about the reefEr collector is in reply to the comment in #19.
For a kiln, we want to have very good insulation for the walls and floor.  With fiberglass, 2x6 is better than 2x4.  2x4 is ok for polystyrene insulation panels.
« Reply #30 on: August 20, 2017, 06:52:08 AM »
 went to check out a reefer trailer for sale.  The axle had been torn off, and the floor is broken and has about a 6" hump.  Wonder if driving my skidsteer on the hump would push it back down flat.  The guy will deliver the trailer, and put it down flat on the ground.  Need to get a couple chunks of hollow core concrete to put one under each end.
« Reply #31 on: August 20, 2017, 09:32:34 AM »
Kiln floors really need to be dead flat as the wood stacks will conform to them as they dry.  If it can be shimmed, that would work, but flat floors, when fully loaded, in kilns are very important.
« Reply #32 on: August 20, 2017, 05:38:26 PM »
The hump is right in the very back of the trailer, over where the axles attached underneath. The frame pieces under the floor are bent, but only in about a 4' area.  It would have to be pushed down to allow the use of a cart to roll a stack of boards into the front of the trailer. Maybe if I scoop up a bucket of gravel, and roll the skidsteer back and forth over it,  would push it down flat. The trailer is 53' long
Offline BigZ La
« Reply #33 on: August 20, 2017, 07:00:29 PM »
Could you block the track up and still use it. You would only lose a little head space.
« Reply #34 on: August 23, 2017, 08:02:27 PM »
Thinking about maybe cutting half way through the steel floor joists before putting the thing on the ground, so it would come down easier.  If I put a concrete chunk right under that part of the trailer, it would not be able to sag.
Offline PA_Walnut
« Reply #35 on: August 24, 2017, 07:12:59 AM »
What are the requirements for "sterilizing" material that comes from a quarantine area? Is there specific verbiage as to what needs to be done to meet the restriction?
Thx
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
« Reply #36 on: August 26, 2017, 08:12:25 AM »
Because it is difficult for many people who are inspecting or enforcing the law to determine the species and if there is a valid sterilization, the requirement is something like no wood movement if the wood has bark.  Dried lumber does not have such requirements within the US, but lumber exported does.  Exported wood requires a third party certification and each piece needs to be stamped with a ink stamp indicating certification.
Offline PA_Walnut
« Reply #37 on: August 26, 2017, 08:16:43 AM »
OK. Thanks. So, does air-drying material with bark removed satisfy the quarantine restrictions?
« Reply #38 on: August 27, 2017, 09:23:04 AM »
Each state and region are different.
Offline TractorBoy78
  • Rather saw than go to the office!
« Reply #39 on: September 25, 2017, 12:25:57 PM »
I built a foam board box and am using 4 plug in oil heaters as heat source.  Have been thru several versions.  Current one holds temp at 145 degrees F and will hold 10' length.  Have inexpensive 2 prong moisture meter, remote thermometer, and infrared thermometer.  Remote thermometer that I place in box reads same as infrared thermometer when measured.  Saw in a chart that 140 degrees would sanitize a 4" thick by 12" specific gravity wood of 35 in about 300 minutes starting at a 25% moisture content.  I am thinking 24 hours in the hot box should sterilize oak 2.5 inch slabs.  Notice variance in moisture content from Center to outside of slabs by about 7%.  Have had red oak starting at 21% moisture content in for about 24 hours.  Trying to run it to sterilize and realize less than 10% moisture content.  Am I heading in right direction?
How do I know if the wood already dried
Started by alsayyed on Drying and Processing
Last post December 13, 2005, 07:00:01 AM
by Max sawdust
Storing dried wood
Started by RoyBoy on Drying and Processing
Last post June 03, 2011, 09:23:59 AM
by scsmith42
Better for dried or green wood
Started by earlsyr on Timber Framing/Log construction
Last post December 02, 2008, 01:09:56 AM
by Stephen1
What wood is this.....aired dried for 27 months
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post May 20, 2017, 09:05:03 AM
by francismilker
