Arborwear
Author Topic: nailer for trim work  (Read 1580 times)
Offline rjwoelk
    • countrysidefirewood
« on: June 14, 2017, 01:41:01 PM »
Needing a nailer for all the trim work in the cabin. base boards, window and door trim ,any one with sugestions as make model nail size most are 1 inch up to 2.5.  Will be using 3/4 inch wrc. I see porter cable on for 199. most are in the 230 250 range.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline MrMoo
  • Do you have a spare log dar
Re: nailer for trim work
« Reply #1 on: June 14, 2017, 04:54:34 PM »
I recently bought a Porter Cable 18ga brad air nailer that I like. It is light and small and works well.
Offline Hilltop366
« Reply #2 on: June 14, 2017, 07:47:18 PM »
I see that Canadian Tire has some on sale, there not name brand but if my experience with their roofing nailer is any indication it should be alright.
MAXIMUM 18-Gauge Brad Nailer, 2-in    $90
Last year after my Stanley roofing nailer quit so I grabbed a Maximum roofing nailer on sale and we installed over 3 pallets of shingles with it with no issues.
Offline 21incher
« Reply #3 on: June 14, 2017, 08:30:59 PM »
I have been using a porter cable DA250A 15 ga 2 1/2 inch angled one for about 20 years. It works good, but sometimes you get a extra shot when you bump it. I also use a brad nailer and pin nailer for smaller moldings.  They are all timesavers and I use the galvanized nails because they seem to have more resistance to pull out.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Online Don P
    • Calculator Index
« Reply #4 on: June 14, 2017, 09:32:00 PM »
I prefer a 16 or 15 ga nail for most trim and 18 ga for very light work.
Offline Larry
« Reply #5 on: June 14, 2017, 09:33:10 PM »
You really need two guns.  One a 15 gauge for casing and baseboards.  I've had two both Senco that were perfect.  i sold my first one because it would only take up to 2" nails and the newer ones take up to 2 1/2".
The 18 gauge is needed for small stuff.  Its easier to conceal the nail hole and sometimes you can get away with using color head nails.  I've had Porter Cable, Bostich, and my latest is a Hitachi that shoots 2 1/2" nails.  I think they are all Chinese and throw away, but I've had good luck with them.
Larry
Nine out of ten trees recommend wood for your building project.
Offline newoodguy78
« Reply #6 on: June 14, 2017, 10:18:49 PM »
I agree with Larry having two is a really good idea. Same as 21incher I always buy the galvanized nails for my trim guns mostly because I like the way they hold, but it's nice if you have to use a few outside to be prepared.
My trim guns are Senco and Hitachi and for the most part like them equally.
Offline SlowJoeCrow
« Reply #7 on: June 15, 2017, 10:02:48 AM »
Nowadays I would consider going cordless.  I use my dewalt 18v battery powered 18 gauge nailer all the time in the wood shop.  They also make a 15 gauge and 16 gauge as well.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #8 on: June 15, 2017, 08:09:20 PM »
Before you buy I would check E-bay.
Sure is some great deals there.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #9 on: June 15, 2017, 11:40:21 PM »
I use a Porter Cable 15 ga for base, window and door trim.  Crown moulding as well.  I have a 18 ga brad nailer, also a PC, for smaller applied mouldings, and for holding small, glued on mouldings and furniture parts, I use a 23 ga pin nailer.
You can do without the pin nailer if you're working on a cabin, but I would want both the finish and brad nailer available to do a nice job.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline Al_Smith
« Reply #10 on: June 16, 2017, 06:15:59 AM »
I have a framing nailer and a roofing nailer that work great .However I've never found a finish nailer that could drive a nail through ash trim .That I had to drill first .Just bends the nails other wise .
Offline rjwoelk
« Reply #11 on: June 20, 2017, 12:30:21 PM »
Thanks for all he information. HD had a dewalt on sale. Will see how I like it 18 g. There is a big jump between 15 .16 to 18 in price.
Offline 21incher
« Reply #12 on: June 20, 2017, 04:27:16 PM »
You have to be careful in thick hardwood with the 18 ga. I have had them follow the grain around and come back out right next to the nailer. :)
Offline SlowJoeCrow
« Reply #13 on: June 20, 2017, 09:17:40 PM »
Did you go battery powered or air?  21 is right, nails can come out in unexpected places by following the grain- like in your hand/fingers!
Offline bluthum
  • Tick magnet.
« Reply #14 on: June 20, 2017, 09:59:06 PM »
After 41 years as carp and wood worker I would want a 16 gauge if I had to pick one. I very rarely want  a 15 gauge indoors but an 18 gauge is very handy. Narrow crown stapler too.
Battery power is the future but pneumatic still is the current best all around choice.
Offline newoodguy78
« Reply #15 on: June 20, 2017, 10:54:49 PM »
bluthum, I'm curious why you don't use a 15 ga inside? Not knocking it just wondering
Offline rjwoelk
« Reply #16 on: June 21, 2017, 12:57:29 AM »
My thoughts on going to 18 g was to keep the splitting to a min. The other, small nail less notice of the nail head.
Offline bluthum
  • Tick magnet.
« Reply #17 on: June 21, 2017, 07:40:43 AM »
Why I don't use 15 ga, inside? Because it is overkill 90% of the time. Down sides are larger hole and much more expensive nails.
Not fair to say i never use 15 ga. inside but rarely.
Offline rjwoelk
« Reply #18 on: June 22, 2017, 11:50:43 AM »
I went air. We do have a battery  framing nailer in dewalt. But did not want to spend 4 to 5 hundred on a finishing one.
Offline Carpenter
    • Niobrara Timber and Woodworks
« Reply #19 on: June 24, 2017, 03:57:32 PM »
I agree with bluthum on the 16 gauge nailer.  Although I've got a 15 gauge and an 18 gauge finish nailer.  I don't have a 16 gauge, but If I did I think I would use it a lot more than the 15.  However, for setting interior doors I'd still use the 15 gauge.
By the way, all of my nailers are Bostitch.  I've had good success with them.  And, I bought most of them off of E-bay, some used, some new, but I found some pretty good deals on them.
Cordless Nailer
Started by Junior437t on General Board
Last post August 19, 2005, 10:17:20 PM
by Jason_WI
Gas powered Framing Nailer
Started by Fla._Deadheader on General Woodworking
Last post June 12, 2009, 08:02:38 AM
by Fla._Deadheader
Hitachi Gas framing nailer
Started by reelman65 on Timber Framing/Log construction
Last post November 06, 2017, 10:11:08 AM
by limbwood
What brand flooring nailer
Started by LeeB on General Board
Last post December 28, 2016, 10:33:45 PM
by Kellyj
