Arborwear
Author Topic: serving trays for a winery  (Read 3826 times)
Offline DeerMeadowFarm
Re: serving trays for a winery
« Reply #20 on: June 28, 2017, 08:27:08 AM »
 popcorn_smiley
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #21 on: June 28, 2017, 08:57:53 AM »
Yup, life is full of curve balls and I'm up to bat............
Offline samandothers
« Reply #22 on: June 28, 2017, 09:42:46 AM »
Always struggled hitting a curve but, when I did it sure felt good!
Offline VT_Forestry
« Reply #23 on: June 29, 2017, 08:47:01 AM »
Well, based on what I've seen, you take those curve balls and knock em out of the park
Forester - Newport News Waterworks
  • roborob
    • tule peak timber
« Reply #24 on: June 29, 2017, 09:04:52 PM »
I spent the day cleaning up the sink. I used Gorilla glue to set the sink because it adheres well to sanded metal. But it also foams up and makes a big mess . So my solution was to set the sink about 50 thousands below the wood surface then carefully flat sand the glue overflow. Next I dragged a thin hacksaw blade between the sink and the wood creating a kerf about 1/16 inch deep . Took several hours to clean out the Gorilla . So now I have a perfect outline of the metal to wood which I then filled with epoxy. There is a slight amount of epoxy overlay and a lot soaked into the end grain causing the little bit of shadow. Now here is the trick -there is an oiled sample  board in one of the pics showing the eventual color of the top next to the thin epoxy soaked transition (the kerf ). Tomorrow I sand and blend the wood to the steel seamlessly and later the final finish colorwise will  blend right into the transition .  Cheers Rob
« Reply #25 on: June 30, 2017, 08:10:46 AM »
Enjoy your threads and you sharing your experiences and ways to manage 'situations' that you have encountered.
I look forward to the progress.
Offline Savannahdan
  • Retired.
« Reply #26 on: June 30, 2017, 12:24:25 PM »
Funny, I so distracted looking at the dog which appears to have one good eye and didn't notice all the other dogs.  Glad to see the kitchen coming along.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
  • roborob
    • tule peak timber
« Reply #27 on: June 30, 2017, 03:23:36 PM »
The little one came to us five months ago SEVERLY abused along with her brother. Tony who works here saw a guy dump them out of a box on to the highway when he was coming to work and he scooped them up before they were killed. Both dogs were in horrible condition from physical abuse. When I first saw them I just sat and cried ..............Now they never leave my side, and will never go without anything they need or want. All of our dogs over the years come to us more or less this way. Tomorrow I'm donating a slab table to be auctioned off for a boxer dog rescue organization.
  We like dogs around here! Cheers  Rob
Offline 21incher
« Reply #28 on: June 30, 2017, 06:09:43 PM »
I have never seen anyone mount a sink in a wood top like that. What happens with seasonal wood movement when the sink is not floating on the top?  ???
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
  • roborob
    • tule peak timber
« Reply #29 on: June 30, 2017, 06:34:22 PM »
I've been subsetting sinks like this for years, so far without problem.The wood in all cases is sealed with epoxy on all faces. This sink also had about an inch of "spin" over six feet making it very hard to get level with the wood surface. We shall see if it holds, otherwise it is off to plan "B"....Rob
  • roborob
    • tule peak timber
« Reply #30 on: June 30, 2017, 06:52:20 PM »
The guys worked the mills today producing  various cookies for the next projects. I'm still stuck on "kitchen duty".
Offline 50 Acre Jim
  • Norwood Manual HD 36
« Reply #31 on: June 30, 2017, 06:57:54 PM »
I'm in the woods but we have dogs/cats that find their way to us that people have tossed out for one reason or another.  I hate people sometimes.
Constantly reinventing the wheel...
  • roborob
    • tule peak timber
« Reply #32 on: June 30, 2017, 07:01:36 PM »
We all do the best we can,,,I hope to help out a little more tomorrow. Rob
Offline Savannahdan
  • Retired.
« Reply #33 on: June 30, 2017, 07:46:33 PM »
Love the project and the donut.  Glad you're helping the dogs.  We even have an orphan parakeet that was on our sidewalk one day.  He let me pick him up which meant he was really stressed.  He provides us with lots of entertainment including teasing our old cat.  BTW, the donut looks like a bobcat face if you rotate it a bit.
  • roborob
    • tule peak timber
« Reply #34 on: June 30, 2017, 10:36:51 PM »
You are welcome to break bread at my table anytime !!!
  • roborob
    • tule peak timber
« Reply #35 on: July 06, 2017, 06:12:43 PM »
I worked through the weekend and got the corner of the kitchen done. VG doug fir cabinets, windows, and entry doors, tan oak ceiling, teak work surfaces.  Meanwhile the march of tables goes on and on.
  • roborob
    • tule peak timber
« Reply #36 on: July 14, 2017, 04:29:14 PM »
The cuttings were finally dry enough that I ran them through the kiln at 155 last night, just to make sure. I am using a penetrating epoxy that will tend to hold the bunch together, but still allow me to unwrap the string that binds the bunches. This epoxy is different in that it has a vehicle or thinner that needs to outgas over a couple of days. It's intended use is for dryrot, but I use it for all sorts of things in the finishing process. After these have hung for a couple of days we'll move onto the next epoxy step. Rob
  • roborob
    • tule peak timber
« Reply #37 on: July 17, 2017, 04:17:09 PM »
Second epoxy application , this time with AeroMarine 300/21, a little more viscous resin to stiffen things up.I'm off to the AWFS wood show tomorrow marking the first day in 6 years that I've set foot outside of the shop.  Next week ---Rob
  • roborob
    • tule peak timber
« Reply #38 on: July 24, 2017, 08:15:22 PM »
  A special jig to safely slice the vines into mini cookies. The guy to the rear shovels the cookies into a wheelbarrow. Everyone keeps a safe distance from the blade.
  This young man is assembling the cookies onto a thin plywood sheet.
  The blank is prepped and allowed to set for a couple of hours.
  Copper infill.
  And two more tray versions , one for export and the other for domestic use in  different woods. Cheers Rob
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #39 on: July 24, 2017, 08:36:44 PM »
I am always amazed with your vision and ingenuity.
Serving Trays
Started by SwampDonkey on General Woodworking
Last post March 02, 2010, 06:37:01 PM
by SwampDonkey
Cable Serving
Started by Fla._Deadheader on Sawmills and Milling
Last post April 21, 2003, 07:41:58 PM
by Fla._Deadheader
Serving my addiction...
Started by mrcaptainbob on Firewood and Wood Heating
Last post May 23, 2011, 05:17:24 AM
by Al_Smith
exclamation
Help! Mesquite Serving Boards for Restaurant
Started by Jkp23266 on General Woodworking
Last post April 10, 2016, 06:30:30 PM
by Just Me
