Arborwear
Author Topic: U-Shaped Stairs in a Timber Frame  (Read 1967 times)
Offline jb9
« on: June 18, 2017, 08:56:13 PM »
Hello,
I am currently working through my design and thought I would share some progress.  I am designing a 26x32 4-bent Saltbox in which the stairs will be in the center bay.  I have seen another thread on this topic so I thought I would share some of what I am learning.  From my experience, stairs are difficult to master and I have struggled to find something I hope is build-able.  It does seem that a U-shaped staircase in a center bay is a common location for a timber frame so I thought it would relevant to this group in the Forestry Forum.  If there are any master carpenters here who have any thoughts or recommendations, I am all ears.  As far as code, I spoke to the Building Inspector and he wants to see 36" treads as per IRC 2009.  I originally drew a "split level" landing but tried to change it to a flat landing without messing up the door entrance locations and headroom height requirements.  I have a center bay measurement of 80" so my width will be roughly 40".  I just hope I can find a railing solution that will work cleanly.  I have drawn the stringers and framing in order to show how I am working through the problem.
Thanks in advance.
Offline ljohnsaw
Re: U-Shaped Stairs in a Timber Frame
« Reply #1 on: June 18, 2017, 09:37:14 PM »
Nice.  How deep is the landing?  It looks to be the minimum 36".  You might want to make it a little bigger to make moving furniture a little easier.  Making it the same as the stair treads (40") would make it seem a little more balanced rather than a bottle neck.  Personally, I'd probably make it 48-50".
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Online Don P
    • Calculator Index
« Reply #2 on: June 18, 2017, 09:42:33 PM »
Not a master by any stretch but some thoughts. It looks like the top tread of the lower flight is a half step or so, if so why?  I like to rest the bottom of the upper stringer on a solid "floor" of landing, so usually I'll build this area out with a wall or header to fully support under the stringer which has a level cut similar to the bottoms of your lower stringers. I usually develop my sketches from the tops and faces of the finish materials and then work backwards to the framing, it helps me account for different material thicknesses easier.
Offline jb9
« Reply #3 on: June 18, 2017, 10:44:50 PM »
Thanks DonP and ljohnsaw.  I would like to go wider but I am probably going to keep it as narrow as
possible and have a removable railing in the event I need to move large items upstairs.  I might go up to 42".  The run will most likely stay at 36" due to the door entries at the top of the stairs.  Also, what appears to be a partial tread is actually just my solution to increase head clearance going to the basement by using 2x6's for the landing platform (instead of 2x8's or 2x10's).  I can get a bit more bearing against the stringer by extending it a little and then feathering the extra length into the platform.  Also, that is a good idea to work backwards from the dimensions of your finish materials, DonP.
Offline ljohnsaw
« Reply #4 on: June 19, 2017, 09:29:38 AM »
What's left of that stringer at the landing is a little scary looking (weak).  Not sure how tall your floors are but how about this?  Move/make the first stair flight 1 or 2 more stairs (move out into the room a couple feet)?  That will increase the height of the landing (and  you could make it deeper) and then the second flight will be a step or two shorter moving away from the bathroom door.  This will also give you more head room for the basement stairs as well as allow a better tie in for the stringers.
John Sawicky
Offline jwilly3879
« Reply #5 on: June 19, 2017, 11:32:08 AM »
I ran into a similar situation with building inspector on a cabin that I built. He insisted that the stair treads were too narrow and that they had to be 36". The code actually reads that the stairway needs to be 36" wide.
This is from the 2015 IRC but reads the same as 2009.
R311.7.1 Width.
Stairways shall be not less than 36 inches (914 mm) in clear width at all points above the permitted handrail height and below the required headroom height. Handrails shall not project more than 41/2 inches (114 mm) on either side of the stairway and the clear width of the stairway at and below the handrail height, including treads and landings, shall be not less than 311/2 inches (787 mm) where a handrail is installed on one side and 27 inches (698 mm) where handrails are provided on both sides.
Offline jb9
« Reply #6 on: June 19, 2017, 11:55:53 AM »
Thanks ljohnsaw and jwilly3879.  I am seeing that exact same language in my code (it seems to read the same for IRC 2006, 2009 and 2015).  The interesting part is that the code really only calls out 36" ABOVE the handrail (I will have one).  I am going to "tread lightly" with my building inspector for sure on this one.  I definitely want the stairs to work well.  Good suggestion ljohnsaw.  I will post another drawing tonight with the entry to the bedroom at the top of the stairs and how I can't move the 1st floor stair "run" out 1 or 2 stairs.  I'll see if it can be done though.
Thanks for all the helpful suggestions so far (especially to jwilly3879 for citing that IRC code for other folks reading this thread).  I think getting this detail correct in a timber frame is crucial since bents really can't be moved once a frame is designed and raised.
Here's a shot of my tread (with a 1" nosing) to assess the space available for banisters and newels should I opt for a railing mounted on the face of the tread.  My aesthetic is definitely more rustic/industrial so it would be great to come up with something that might work.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #7 on: June 19, 2017, 02:37:34 PM »
J:
When you post a picture with text in it, please increase the size of the font in the picture. I had to zoom in to 133% of the page size in order to read it.
thanks
Jim Rogers
Offline jwilly3879
« Reply #8 on: June 19, 2017, 05:12:40 PM »
My stairs went up the gable wall with a cathedral ceiling. The treads were 32" wide and the hand rail was outside the treads. The room it was in was 16' wide so my "stairway" as defined was 16' wide.
Here are so pictures of the cabin. It is in the middle of a 500 acre lot we have been cutting on for 5 years.
Offline jb9
« Reply #9 on: June 19, 2017, 06:41:35 PM »
Those are great pictures.  I see what you mean about having a 16' stairway as defined by the code.  I sent off a diplomatic email to the inspector this morning asking him if I'm ok (and citing the code I am using).
Here's a rendering of the top of the stairs and how I am going to need access to the bathroom AND the adjacent bedroom.  It's close but I think it will work nicely.  This rendering will show why I am hesitant about increasing the run.
Offline ljohnsaw
« Reply #10 on: June 19, 2017, 07:13:19 PM »
No, I guess I didn't explain myself clearly.
Keep the top landing where it is at as necessary for the bathroom and bedroom doors.  Make that upper flight of stairs 1 or 2 treads less thus giving room for the mid-landing to expand a bit.  It will also raise that landing 1 or 2 steps depending on what you do with the upper flight.
Then, make up for it with the lower flight (extending it 1 or 2 treads) to reach the higher landing.  This flight will move into the main level a little further from the wall.  I didn't see any restrictions there.
This will also raise the mid-landing giving you more headroom for the basement stairs, too.
John Sawicky
Offline jb9
« Reply #11 on: June 19, 2017, 07:43:04 PM »
I do like that idea but the problem I keep running into is that I lose the height requirement.  In this drawing, I basically set the man's height to 6' 8" to show what I mean.  Does this make sense?  When I move the stairs out, I have to move/increase the size of the opening above as well to achieve the 6' 8" height.
Offline ljohnsaw
« Reply #12 on: June 19, 2017, 09:10:30 PM »
Yeah, I get it.  I thought your bent spacing was a bit more than it is... What is the spacing?  You only have two choices that I see - make the bent spacing bigger (and redo all your load calcs :-\ ) or move that bedroom door somehow.  Rotate it 90 and make a funky bump in the corner of the next room?
I went through a lot of iterations to get my cabin plan to work.  I ended up having to do 12' BETWEEN the bents to get enough head room.
John Sawicky
Offline jb9
« Reply #13 on: June 20, 2017, 08:21:55 AM »
This is helpful John.  Thanks.  I have been going through those long iterations myself...  I couldn't agree more about some of the complexities when trying to fit a stairway into a timber frame in a way that is efficient and elegant.  It looks like my bent spacing is 11' 4" (outside face of exterior post to inside face of interior post) which are is the relevant dimensional constraint for the "run" of the stairway so that I can get into the rooms adjacent to the center bay.  It's close and will no doubt require a excruciating level of attention when I build it.  The margins between a design and "as-builts" seem scary to me as I want to make sure this detail is correct because stairs are very important for safety.  I have some new drawings I can post later...
Offline timberwrestler
« Reply #14 on: June 20, 2017, 10:01:58 AM »
To gain that head height, there are a few options, but the easiest is to add a riser.  The most simple spot is that you can add a riser is in the middle of the U-landing.  You could also change it to winders, or decrease the tread depth.
I design a lot of stairs, and I wanted to point out that you should draw all of the parts--the newels, rails, balusters, etc.  That way you can ensure that everything works together.  The continuous handrail requirement with the proper clearances can sometimes be tricky.  By the book, the handrail does not need to continue around the landing, but some inspectors like to insist on it.
Offline ljohnsaw
« Reply #15 on: June 20, 2017, 10:26:35 AM »
JB9,
Looking at your measurement:  The code (as I read it) requires 6'8" vertical height.  You can have the nose of a tread just back of the beam and have less than 6-8 and the next stair down gives you the height requirement.  That is what I had to do for my basement stairs.  I really like the suggestion that TimberWrestler has, one riser on the landing perpendicular to the stair runs.
One other thing I've seen you need to avoid.  I was doing a little work in a historic Victorian.  They refinished the floor, including the stairs.  They had a set up like yours.  Going down, the last tread projected beyond the newel post at the landing.  Looking down, you could not "see" the edge of the tread as all the wood grain blended together.  MANY people stumbled and fell because they thought the last tread was the same height as the landing.  I think it was a combination of camouflage and your assumption that the newel post marked the end of the stairs.  They solved it by putting a little rug on the landing ::)
John Sawicky
Offline jb9
« Reply #16 on: June 20, 2017, 11:58:38 AM »
Thanks Timberwrestler and ljohnsaw.  I do have a version of this staircase with a step on the landing.  From what I understand, this is called a split-level landing.  In terms of safety and comfort, I would say a flat landing is my first choice, a split-level landing is my second choice and the winders are a distant third.  Also, I do think the flat level landing could be the easiest to conventionally frame (with 2x6's running from bent to bent).  I think what I might do is confirm with a rendering that a plumb line from the front face/leading edge of that ceiling timber will give me at least 6' 8".   I will post that rendering with some dimensions.  Additionally, that is good advice Timberwrestler to detail the newels and banisters to confirm the tread is sufficient.  I'm working with a few stair supply places (that have technical support folks who see these details daily).  If anyone knows a good stair supply vendor that they have worked with in the past, that would be great.  I will keep drawing and posting my results .
Offline jwilly3879
« Reply #17 on: June 20, 2017, 01:04:16 PM »
As a Building Inspector the most common correction I write is for stairs.
People don't seem to realize how dangerous the are.
Consistent rise and tread width are critical. Variable rise is the most common violation.
Offline jb9
« Reply #18 on: June 20, 2017, 03:59:09 PM »
Thanks for following this thread jwilly3879.  It's helpful to hear the recommendations of a Building Inspector.  I completely agree that stairs are dangerous and really want to get this aspect of the project well-defined.
Offline jb9
« Reply #19 on: June 20, 2017, 06:45:00 PM »
I think I have some good news to report.  The one tread that needs to clear the tie beam is currently sitting at 6' 10 11/16".  Additionally, joist sizing was solved for the longest span (which this center bay is clearly NOT).  Floor joist is 7 1/4" deep (a 6x8) which means I could certainly down size or chamfer this one floor joist if needed (I know this is not a best practice but this detail is a lynchpin for my model).  Additionally, I could probably apply the 3/8" variance to this one tread if it came to that (definitely a last resort as consistent riser height is most important to me).
Here is a rendering for those folks following along:
Attaching heavy timber stairs in a frame
Started by danreed76 on Timber Framing/Log construction
Last post August 04, 2014, 08:28:50 PM
by razor
Timber stairs
Started by Troy Schon on Timber Framing/Log construction
Last post October 16, 2014, 08:49:23 AM
by ziggy
timber framer to take on stairs and porch in NJ ASAP?
Started by emanaresi on Timber Framing/Log construction
Last post January 08, 2016, 06:09:57 PM
by maineframer
10' X 12' Timber Frame Shed (Raising the Frame)
Started by jander3 on Timber Framing/Log construction
Last post February 03, 2012, 07:17:55 PM
by jander3
