Arborwear
Author Topic: PPB  (Read 916 times)
Offline xlogger
PPB
« on: June 21, 2017, 03:02:00 AM »
For the first time I've notice what I think are PPB in my slabs that are waiting to get into the kiln. They are poplar and river birch stack on top of each other. After I kiln dried them and heat treat them I know it will kill the PPB but what are the chances of infecting my other slabs that already been dried and waiting to sale?
I'm sure others have have this to worry about, so what do you do? I don't see any that might be in my dry slabs now.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: PPB
« Reply #1 on: June 21, 2017, 07:22:59 AM »
Spray your slabs with disodium octaborate tetrahydrate green off the mill.  Make sure that any bark gets coated good with spray.  A bit of piece of mind, but aggravating to have to do it.  You could also sequester the dried slabs in a different place that is enclosed and sealed off from the elements, but that takes more room or another building  :).
Offline GeneWengert-WoodDoc
Re: PPB
« Reply #2 on: June 21, 2017, 11:17:26 AM »
This are more likely ambrosia bettles.  They prefer wetter wood and hatch within weeks versus lower MC and hatching pin a year. PPB like rough wood with pores, not smoother wood.
These can spread easily with three crops a year. They love woody debris on the ground.
Offline fishfighter
Re: PPB
« Reply #3 on: June 21, 2017, 11:48:55 AM »
Yep, DanG ambrosia beetles give me hell. They get into my oak logs like overnight. >:( How can one stop that? I keep my logs stacked off the ground.
Offline DDW_OR
Re: PPB
« Reply #4 on: June 21, 2017, 02:35:58 PM »
Is this the stuff?
http://www.ebay.com/itm/Timbor-Insecticide-Termiticide-Fungicide-25-Lbs-Termites-Beetles-Carpenter-Ants-/141026954196?hash=item20d5dc8bd4:g:nYoAAOSw4CFYvWP-
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Turbosaw 26EX, Hakmet Arbro 400 stroke harvester, BrushHound 30EX
Offline Ianab
Re: PPB
« Reply #5 on: June 21, 2017, 03:32:24 PM »
Yes. Timbor is a commercial blend of the  borate salts that WDH is talking about. You can also mix your own from farm supply chemicals.
Offline Don P
    • Calculator Index
Re: PPB
« Reply #6 on: June 21, 2017, 07:02:27 PM »
I noticed the timbor in that ad is $4/lb, the last Solubor I bought was exactly half that price and I was a little upset, it had just about doubled. They are chemically identical.
Offline WDH
Re: PPB
« Reply #7 on: June 21, 2017, 08:10:59 PM »
Last Solubor that I bought was $1.60 per pound.  Timbor is priced way up there.  Technically, Solubor, while exactly identical to Timbor, same compound and same concentration, is labeled for use in liquid fertilizer as a source for the micro-nutrient boron.  Timbor is labeled as an insecticide.  Technically, you are not supposed to use a chemical in a different way than specified on the label per the EPA  :) :) :) :).
Offline xlogger
Re: PPB
« Reply #8 on: June 22, 2017, 05:23:17 AM »
Will the Solubor take care of the Ambrosia beetles also? I've looked on internet and see where you can but it fairly cheap. If I got some would it be any help spraying and dry slabs under the shed that I have for sale. I don't want to sell someone an infected slab and way too much trouble to reheat them again.
Offline WDH
Re: PPB
« Reply #9 on: June 22, 2017, 07:52:51 AM »
It will prevent ambrosia beetles from infesting your logs, but you have to spray the logs before sawing the slabs.  Too impractical for me, so I just live with some ambrosia beetle holes.  The key thing to prevent ambrosia beetles is to saw the logs immediately after felling, then spray the lumber with disodium octaborate tetrahydrate before stickering the lumber.  As to the dry slabs, spraying them now prevent any fresh infestations from PPB's, but if the PPB's are already in there, it won't help that.
Offline Don P
    • Calculator Index
Re: PPB
« Reply #10 on: June 22, 2017, 09:52:41 PM »
Ambrosia beetles feed on a fungus the adults inoculate the hole with.  They burrow in wet wood but really feed on the fungus, the hole is black. I don't really worry too much about them, when the wood is dry their food source dies.
Anobiids feed on the wood, preferably wet, but they can reinfest dry wood. The hole is wood colored. I borate more for those types of insects.
This is a good article;
http://articles.extension.org/pages/70170/beetles-order-coleoptera
Offline fishfighter
Re: PPB
« Reply #11 on: June 24, 2017, 07:27:37 AM »
Those ambrosia beetles holes do look real nice when one finishes out a board. This is some wainscoting in water oak I did.
One can see the black holes. :D
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Re: PPB
« Reply #12 on: June 25, 2017, 06:44:10 AM »
If possible, buy fresh cut logs, mill them quickly, and segregate the wet sawn wood from the kiln dried.  Scrape up the log yard down to dirt routinely and burn the debris.
If I see logs with fresh insect activity, I mill them immediately and slab heavy, which also goes into the burn pit.
I have a buddy who stores his logs in a pond if he won't mill them for awhile. I tried it for myself with a few cherry logs a couple years ago.  I saw no degrade or insects at all, if anything they had a deeper reddish color than I was used to seeing, and made beautiful wood.  I fished the floating logs out with a tractor grapple when the wind blew them to the bank.  I still have one nice log in the pond, it sank and has become a fish attractor.  Oh well.
HobbyHardwoodAlabama.com
