Arborwear
Author Topic: Suggestions for straighting timbers?  (Read 1119 times)
Offline JSmithey
« on: June 23, 2017, 12:55:59 PM »
I built some walnut timber frame trusses for my house that I'm starting on and some of my timbers have bowed. 9x7 timbers where cut this spring and some have 2" bow over 16'. Don't think I should have split the hearts to make 2 timbers from one log, my boxed heat beams are very straight. Any suggestions on straightening? I've piled on about 3000lb of weight to get them straight but they will need to be raised in about 1 month.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Re: Suggestions for straighting timbers?
« Reply #1 on: June 23, 2017, 01:06:02 PM »
I doubt that it will help much.  You might get some of it out.   Splitting the heart is usually not a good idea.  Would be better to saw oversize.  Dry.  Then resaw if you want perfect beams.  Maybe someone else will hold out more hope.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline JSmithey
« Reply #2 on: June 23, 2017, 01:11:26 PM »
Offline JSmithey
« Reply #3 on: June 23, 2017, 01:14:33 PM »
Kinda what I figured. Probably just have to live with it
Offline fishfighter
« Reply #4 on: June 23, 2017, 06:09:17 PM »
Maybe wetting them with some wet rags and the weight on them might help. I really don't know. Has anybody try that?
Offline jimdad07
  • Seeking Information
« Reply #5 on: June 23, 2017, 08:34:48 PM »
Could be a far fetched thought here but might be worth a try.  You might be able to take the truss apart and build a large steam box, steam the beam and then try to weigh it down.  Like I said, a far fetched idea but might be worth a shot.  The idea is to loosen up the lignin in the wood to make it pliable and would probably stand a better chance of staying straight that way once it dries out.
Hudson HFE 30 Homesteader bandmill w/28' of track
Couple tractors, a bunch of chainsaws and not enough time to use them.
Offline scsmith42
    • Whispering Pines Farm
« Reply #6 on: June 24, 2017, 12:08:54 PM »
Steam will change the color on black walnut; I would advise against it.
JSmithey - which direction are your beams bowed?  Are they already built into trusses?  If so the bow could be caused by shrinkage in the truss components.
Tom's 3638D Baker band mill
Offline jimdad07
« Reply #7 on: June 24, 2017, 02:57:14 PM »
Good point, I did not think of that.  Makes sense.
Offline JSmithey
« Reply #8 on: June 29, 2017, 09:59:11 AM »
some are built in trusses and some are just going to be beams in the house. I'm sure the bow is due to my sawing they bowed a little as soon as I sawed them and got worse as they started drying
Offline DPatton
« Reply #9 on: August 04, 2017, 09:38:45 AM »
JSmithey
That is a beautiful truss in the photo. I sure hope you can find a way to salvage and use them. It would be a shame to have to rebuild them with all of the work you have into them. your post will definitely keep me from making the same mistake. Good Luck!
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline JSmithey
« Reply #10 on: August 19, 2017, 08:39:42 PM »
JSmithey
Thanks. I realized an inch or so bow in a 16' beam is really hard to notice once it's raised in the air. Definitely salvaged and very happy with the outcome. Trusses will be set this week.
Offline JSmithey
« Reply #11 on: August 19, 2017, 08:40:06 PM »
Straighting a bent chain...
Started by Banjo picker on Chainsaws
Last post September 30, 2009, 10:48:00 PM
by madhatte
Milling own timbers vs ordering timbers from a sawmill
Started by Joe Vachon on Sawmills and Milling
Last post July 03, 2017, 12:45:18 PM
by thechknhwk
question
Hardwood timbers vs. Softwood timbers
Started by jeremy86 on Timber Framing/Log construction
Last post September 23, 2016, 09:01:22 AM
by Heartwood
oak timbers
Started by jmouton on Sawmills and Milling
Last post April 30, 2014, 09:18:53 PM
by backwoods sawyer
