Arborwear
Author Topic: Storing logs for future project  (Read 414 times)
Offline rjwoelk
    • countrysidefirewood
« on: June 23, 2017, 12:56:08 PM »
So here in sask i get my logs from BC. This is a major under taking weeks of permits advertising computor goof ups.etc.
My question is how long and in what form should i store these logs.
1 . Get raw logs stack them under cover.( 36x72 shed closed walls open ends)  should they be sticker in layers?
2. Cut into cants as large as possible  and store them in the shed?
3. These are western hemlock logs. I am using them for log house ,cabin building. Timber framing.gazebo. etc
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Re: Storing logs for future project
« Reply #1 on: June 23, 2017, 01:17:01 PM »
Why not saw them into what you want while they are fresh?  Might saw beams oversize so they could be resawed after they dry...in case they move some.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline rjwoelk
« Reply #2 on: June 23, 2017, 01:26:41 PM »
The point is to let them dry up to a couple of years. I have one log doing a twist in the cabin right now and would like to avoid it if possable.
storing logs for future use
Started by muddobber on General Board
Last post December 29, 2006, 07:07:07 PM
by Tom
Storing timber for future use
Started by REGULAR GUY on Sawmills and Milling
Last post February 17, 2010, 07:17:53 PM
by Brucer
Storing SYP for future sawing
Started by Tom Brueggen on Sawmills and Milling
Last post Yesterday at 08:48:13 PM
by clintnelms
moved
MOVED: Storing timber for future use
Started by Ron Wenrich on Ask The Forester
Last post February 14, 2010, 06:16:51 AM
by Ron Wenrich
