Arborwear
Author Topic: Framing lumber  (Read 410 times)
Offline vfauto
  • TimberKing 2000
Framing lumber
« on: June 24, 2017, 06:17:21 AM »
 I am cutting a bunch of pine into framing lumber to build a kiln , what happens if I do not sticker it and I just stack and weight it?
The definition of insanity is to do the same things over and over and expect a different result!
Online Ianab
Re: Framing lumber
« Reply #1 on: June 24, 2017, 06:38:05 AM »
Mushroom farm.  :-\
All sorts of weird fungus will start growing in it if it's dead stacked, within days if the weather is warm.
You can build with green wood, and let it dry in place, as long as it's not enclosed it will dry in place.
Best to either build right away, or sticker it to start drying, for later use. If it's just for construction use it's OK to use green stickers that you make from edgings as you are sawing. You might get some stain, but it wont matter, and you wont get mushrooms.
Offline fishfighter
Re: Framing lumber
« Reply #2 on: June 24, 2017, 07:34:36 AM »
Down here in the south, green stacking will have mold growth in just about one day at this time of the year. Learn that the hard way. >:(
I have nailed it up green with no problems. If you can keep your kiln build out the weather, that pine will dry a lot faster.
Offline Bruno of NH
Re: Framing lumber
« Reply #3 on: June 24, 2017, 08:00:20 AM »
Still need to sticker it.  Imo
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Framing Lumber
Started by AdamT on Sawmills and Milling
Last post February 26, 2017, 10:14:29 PM
by Magicman
Framing lumber help
Started by Timster on Sawmills and Milling
Last post September 15, 2016, 07:48:51 PM
by thecfarm
Framing Lumber
Started by brooksmill on Sawmills and Milling
Last post May 18, 2007, 12:10:33 PM
by Fla._Deadheader
Framing Lumber??
Started by shad on Sawmills and Milling
Last post January 08, 2010, 10:43:31 AM
by brdmkr
