Arborwear
Author Topic: Board and Batten + Wrap and Strap  (Read 872 times)
Offline John P.
« on: June 24, 2017, 10:03:39 AM »
I decided to go with the wrap and strap method for insulating my barn workshop, and am trying to figure out how to fasten my siding. I have horizontal girts/purlins every 24" for the siding to screw into. Wood is white pine, cut locally.
I'm processing my siding as follows:
Plane all to an even thickness - approx 7/8" (one side only, rough/bark side facing out)
Apply a wood preservative (all 6 sides)
Apply a latex primer (all 6 sides)
Paint (sides facing out only)
I was reading online about installation, and came across this article:
http://www.hobbyfarms.com/how-to-install-board-and-batten-siding-3/
The author recommends waiting 6 months to put the battens on - but does that make sense, since I'll be painting/etc...? The wood has dried for well over a year, though I know it will continue to dry once up.
Thanks!
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Board and Batten + Wrap and Strap
« Reply #1 on: June 24, 2017, 11:20:51 AM »
If the siding and battens are that dry, I'd put them up.
Jim Rogers
Offline John P.
« Reply #2 on: June 24, 2017, 11:51:09 AM »
One other thing - that website (and I've seen it elsewhere) fasten the boards 1" from the edge - why not the middle of the board? That way, I would suspect at least, that the board would shrink evenly on both sides of the screw/nail.
Offline John P.
« Reply #3 on: June 24, 2017, 11:55:56 AM »
Oh, not to answer my own question... but is the idea to hide the fasteners since the batten will overlap? You'll still see a fastener head on the batten.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: June 24, 2017, 05:55:41 PM »
Board and batten is only supposed to be fastened in the middle. The batten is to hold the edges and allow seasonal movement.
Online Don P
    • Calculator Index
« Reply #5 on: June 24, 2017, 06:59:19 PM »
Notice he is only fastening one edge of the boards and is also putting bark side in, that cups it to the framing and allows the board to move seasonally, it is also putting more heartwood out, might help in the long term. Don't fasten the batten to the boards, only to the framing behind them so the boards can move. You can put the battens on immediately.
Offline John P.
« Reply #6 on: June 24, 2017, 07:03:46 PM »
Wait - bark side in? I was under the impression I needed to put the bark side out from other things I've read.
Online Don P
    • Calculator Index
« Reply #7 on: June 24, 2017, 10:09:06 PM »
Wood cups to the bark side was his rationale for doing bark-in. I've never really paid much attention, just put best face out. What was your reasoning?
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: June 24, 2017, 10:22:59 PM »
Boards cup toward the bark side and away from the pith side.
I always put the pith side out and the bark side in.  This makes the board edges tighten toward the building instead of flaring out.  I nail the boards and battens down the center.
Cement board backer on wrap and strap
Started by dfvellone on Timber Framing/Log construction
Last post December 31, 2017, 11:55:22 AM
by kantuckid
Where to put house wrap on board and batten pole barn.
Started by flatrock58 on General Woodworking
Last post October 04, 2017, 10:37:58 AM
by rjwoelk
wrap and strap
Started by logman on Timber Framing/Log construction
Last post May 21, 2017, 10:26:16 PM
by ljohnsaw
Wrap & Strap - Windows
Started by jcaimbridge on Timber Framing/Log construction
Last post August 26, 2014, 03:43:40 AM
by venice
