Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: Sick of 353, change to perkins  (Read 2189 times)
Offline Spartan
Re: Sick of 353, change to perkins
« Reply #20 on: July 07, 2017, 09:58:53 PM »
Mines 50-60 WOT
about 10 at idle when warm
50+ when cold at idle
Offline coxy
« Reply #21 on: July 08, 2017, 06:32:36 AM »
my 671 holds 30lb at 2500 rpm and it doesn't register at an idle  but I know it has it or it would have went bang by now  ;D
Offline Oliver05262
« Reply #22 on: July 08, 2017, 12:13:44 PM »
Coxy, the 6-71's we had at Merrill Transport had an alarm hooked to a Murphy switchgauge on the oil pressure and temp gauges. We had to turn the oil pressure switch down to 5 psi or lower or it would go off whenever the driver stopped for a stoplight, and we were running 40 weight oil!!!
If a tree falls in the forest, and then springs back up again; do the squirrels freak out?
"Abandon hope, all ye who enter here"
Offline coxy
« Reply #23 on: July 08, 2017, 02:09:40 PM »
if I remember right most if not all the older gm motors only had to have 5lbs  to run even at peak rpm  ???
Offline snowstorm
« Reply #24 on: July 08, 2017, 03:25:04 PM »
Merrill transport? They had a garage in searsport me. If it's the same one
Offline Oliver05262
« Reply #25 on: July 08, 2017, 08:44:43 PM »
   Yeah. They had a Vermont Division, with a main terminal on Dorset Street in So. Burlington, a terminal in Fair Haven, and the one in Bennington, where I worked part-time in the winters for seven years. Good company, had good shops and took care of their equipment and people. Safety was a high priority, and if you did your part, they recognized that.
    They paid by the trip, using post office miles, and that made for some uneven pay rates. Example: the Port of Albany is a big place, but all trips from there were figured the same. Mobil was the first terminal you came to, and before security tightened up, you could swing in there around the office to the rack, top load, and be out of there and headed East in 12-15 minutes. Sears terminal (they stored a lot of fuel for Agway)is a long way down 32 in Selkirk, slow to load, and paid the same to Bennington. Guess which trips the part-time guys got. We had a couple of Mobil customers in Bennington that you could turn 4 trips in 12 hours---Agway might take you 4 hours or better each one.
Change band brands...change tracking?
Started by kelLOGg on Sawmills and Milling
Last post July 21, 2014, 05:56:28 PM
by ladylake
Cat/Perkins 51 HP
Started by petefrom bearswamp on Sawmills and Milling
Last post March 15, 2015, 02:43:35 PM
by SawyerBrown
Perkins 248 Gone
Started by Ohio_Bill on For Sale
Last post February 10, 2018, 05:22:00 PM
by Ohio_Bill
Perkins 3 cylinder
Started by Dana on Wanted
Last post January 22, 2017, 06:38:37 AM
by Dana
