Arborwear
Author Topic: 540B clutch or transmission is slipping  (Read 278 times)
Offline Snowdens Loggin
« on: June 29, 2017, 08:37:03 PM »
I have a 540b if I put my blade on the ground it won't move or spin the tires I'm not understanding which clutch it maybe inside the trans or out on the motor end. Took the motor out out today and took clutch and pressure plate all the springs was in the disk. Just want to make sure I'm buying the right parts
Re: 540B clutch or transmission is slipping
« Reply #1 on: June 29, 2017, 09:04:21 PM »
Also lost my clutch in all gear high and low gears. Was told if I lost a few gears it would be the clutch packs inside the transmission but if I lost them in all gears it was the outer clutch not sure if that's true...need help please
Clutch slipping fix//
Started by JP on Sawmills and Milling
Last post February 11, 2006, 09:04:59 PM
by sawguy21
Slipping clutch
Started by nektreeworks on Chainsaws
Last post October 31, 2015, 05:49:25 PM
by larry1
Clutch Slipping ??
Started by Magicman on General Board
Last post July 13, 2015, 08:07:04 PM
by Delawhere Jack
Gearmatic 19 slipping clutch
Started by Plankton on Forestry and Logging
Last post May 15, 2016, 05:23:35 AM
by coxy
