Arborwear
Author Topic: What's wrong with my boards  (Read 4732 times)
Offline mjeselskis
    • Big Rock Lumber
« on: July 02, 2017, 08:37:34 PM »
I just sawed up about 2000 bd ft of white pine that I hauled out this winter. I sawed it in early June and had no blue stain or pine borers. The wood was nice and white and clear. I stacked it all in my garage and now 3 weeks later it's growing stuff like you see in the picture. This is supposed to be tongue and groove for the inside of my garage walls so I don't want it all stained. I already spayed it with some bleach water and it seemed to slow it down but it's still going bad. Any ideas on what's going on?
2006 WM LT28  2002 John Deere 990
Online caveman
  • In the land of the blind the one eyed man is king
Re: What's wrong with my boards
« Reply #1 on: July 02, 2017, 08:47:31 PM »
It looks like you are not getting enough airflow.  If drying it in your garage, you may have more success by running a fan through the stack for the first week or so.
Offline btulloh
« Reply #2 on: July 02, 2017, 08:48:07 PM »
Mold. You need air circulation. You'd be better off outside but probably still need fans. Down here pine will mold overnight in summer.
HM126
Offline mjeselskis
    • Big Rock Lumber
« Reply #3 on: July 02, 2017, 08:51:38 PM »
I have a box fan blowing on the stack now and open the big doors on the nice days. Will the mold stain the wood or will it clear up when I plane it? Anything I can do to stop it besides more airflow?
I Appreciate the help. It's no fun to put all this time into it and have it turn out bad.
Offline bandmiller2
« Reply #4 on: July 02, 2017, 09:00:01 PM »
If I want nice unstained pine I cut it in the winter. Try plaining a board or two and see how deep the stain goes, or just put a stain on it once its installed. If pine is milled in warm weather you must get the surface dry quickly or blue stain will take hold. Frank C.
Offline sealark37
« Reply #5 on: July 02, 2017, 09:44:28 PM »
Surface mold and blue stain are two different problems.  I think that the mold you have will plane out if you can speed up the drying process.  Regards, Clark
Online YellowHammer
  • Take steps to save steps
    • Hobby Hardwood Alabama
« Reply #6 on: July 03, 2017, 12:41:31 AM »
Mold won't grow on dry wood.  Nor will it grow fast on cool wood.  So the best thing to do is put one or two big fans on the stack, and get it out in the open, under shade, if possible where the moisture will vent.  About 650 fpm airflow is good for pine, which is a significant wind, and not only does the high air velocity dry the surfaces of the wood, it will also cool the wood off, as an evaporative cooler. The air coming out of the stacks will be noticeably cool and moist.  A single box fan for 2,000 bdft would be marginal at best, as I don't see how it could cover it, two would be better, and for 2,000 bdft, I would have 2 stacks of 1,000 bdft, and have a set of belt driven fans in the middle of them. Somewhat similar to this:
From the picture, your stickers as growing mold as well, not a good sign, an indication of trapped surface moisture for too long, green stickers, or several their things.
The green fuzzy surface mold will generally plane out, but will also quickly develop into deeper stain.
Spraying with bleach and water will help temporarily, but it also serves to rewet the wood, which if not allowed to dry quickly, only makes things worse, because it has little or no residual positive effect.  Timbor or other moldicide will help with the green and white mold, but not with blue stain.
There are a couple things you can do, none of which are easy.
I would break down the stacks, flip the boards over, and move the stickers sideways a little, a few inches, otherwise you will probably get significant sticker stain if you don't already have it. I can see some mold discoloration directly under the top sticker in your photo.
Fans, fans, and more fans.
Get the stack out in the open, in the shade if possible.
Test some, as bandmiller2 suggested, plane a board and see if any damage has already been done.  That will give you a good indication of if they will clean up.
HobbyHardwoodAlabama.com
Online 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #7 on: July 03, 2017, 06:57:15 AM »
An old timer told me that black mold will be go away in the sun, so with boards like that, without being an expert, I would take them out into the sun and zap em.  Keep tabs on them, dont let them be out there all day, maybe an hr or so then flip.  Stickers out there too.  Then restack with fans like Robert yellohammer said.  He's expert mode lol
Boy, back in my day..
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #8 on: July 03, 2017, 07:42:26 AM »
A garage is not a good place to dry green wood.  You need another place with open sides or build a roof over the stack outside.  Then bomb it with fans.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #9 on: July 03, 2017, 08:43:41 AM »
I've never had much luck with drying pine in warm weather
lots of dull bands and chains
Offline fishfighter
« Reply #10 on: July 03, 2017, 09:00:33 AM »
Yep, bleach and fans are a must along with restacking.
That mold will plane out easy.
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #11 on: July 03, 2017, 12:20:37 PM »
I'd Def replace those stickers with dry ones and move them a bit. A little blue stain isn't so bad but sticker stain is butt ugly.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline DanG
« Reply #12 on: July 03, 2017, 12:56:04 PM »
...or, you could just put that beautifully stained wood on your wall and say, "Look what I created!"   8) 8) :D
Offline mjeselskis
    • Big Rock Lumber
« Reply #13 on: July 03, 2017, 06:16:45 PM »
I won't forget this lesson, but man, this is tough. I have close to 40 hours into these boards with hauling out the logs, sawing, and stacking. Between the mold and sticker stain, they look pretty awful. I'm going to lay them out in the sun and flip them and then restack them outside. Not sure if I'm going to end up using them on the walls or not, but they at least need to be dried.
Online POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #14 on: July 03, 2017, 06:49:56 PM »
You need to pressure wash them now.
Rule of thumb...ALWAYS have dry stickers. Just take a day and saw stickers and let them dry. Dry stickers is an important investment.
Where's the Spoon?
Offline btulloh
« Reply #15 on: July 03, 2017, 07:15:43 PM »
Deck brightener will help the mold stains if all else comes up short.  It's more time and expense, but . . .
I learned about mold the hard way and the deck brightener helped me out.
HM126
Online YellowHammer
« Reply #16 on: July 03, 2017, 08:56:37 PM »
Eeek...yep, that's probably gonna leave a mark.
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #17 on: July 04, 2017, 08:57:36 AM »
You did a great job of stickering.
Too bad about your problem
I concur that lack of air flow is the problem.
What little WP i sawed a few yrs ago was dried outside with my home made tin covers and I had very little mildew, mold or blue stain.
When the wind was blowing the lee side of the stacks was like standing in an air conditioned room
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline mjeselskis
    • Big Rock Lumber
« Reply #18 on: July 04, 2017, 10:10:20 AM »
They are all outside laying in the sun and pressure washed. I used mold armor with the pressure washer on the worst ones. The kids stacked up the stickers like Lincoln logs to dry and I'll restack everything in a few days. It's supposed to be low humidity and sunny the next few days so I'm hoping the surface will dry well.
Offline flatrock58
« Reply #19 on: July 04, 2017, 10:36:18 PM »
I had the same problem over the last two weeks with some 1x12 board and batten I cut.  I have them stacked in the new shed but there is no power so no fans.  I unstacked them and sprayed bleach, but like yellowhammer said that does not stop the moisture problem.
I was wondering if I stood the boards up after cutting the if they would dry better than stacking and stickering them?  They would definitely get more air flow.  it has been raining every day in Georgia and humidity is sky high.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Talk about wrong place at the wrong time
Started by crowder888 on General Board
Last post May 11, 2009, 05:41:17 PM
by Chico
Wrong!
Started by Jeff on Technical Support Topics
Last post June 09, 2002, 12:15:07 PM
by Jeff
What went wrong???
Started by POSTON WIDEHEAD on FOOD! FOOD! FOOD!
Last post April 22, 2012, 06:05:14 PM
by Magicman
something wrong with this?
Started by 1270d on Forestry and Logging
Last post May 28, 2013, 12:50:12 PM
by Forrest277
