Author Topic: Price of logs  (Read 716 times)
Offline Kenny.jenkins
Price of logs
« on: July 04, 2017, 08:37:04 AM »
I live in west Tennessee. I've recently bought a wood mizer LT 15 and have been doing some custom sawing and milling a few logs off my small farm. If I were to start buying a few logs how would I know the the going price to give for it? Is there a web site that that will give the market price of logs? The mills would have to have a way to keep up with the market.
Kenny
Offline paul case
  • Original wearer of the PCM.
Re: Price of logs
« Reply #1 on: July 04, 2017, 08:42:26 AM »
I like to be competitive with local mills on price of logs that I use so I call other mills near me and ask them what they pay for logs. Some even advertise their prices and specs in our local classified news paper.
PC
pc
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Price of logs
« Reply #2 on: July 04, 2017, 01:01:38 PM »
Kenny,
   Be sure to contact the local tree service people in your area and let them know what you are interested in as they may have some free or very cheap. They may even deliver if close by and especially if you give them a little gas money and such. They often have logs they have to get rid of. Good luck and enjoy the mill.
Offline Brad_bb
Re: Price of logs
« Reply #3 on: July 04, 2017, 07:40:29 PM »
I use a lot of tree service trees.  There are a couple of things to be aware of.  Yard trees can have metal so be prepared for that, especially at the bottom of the butt log.  Tree services tend to cut trees up to 5ft long or shorter to make it easy to load with their grapple and haul.  You would have to make relationships to find ones that can cut and haul longer.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Price of logs
« Reply #4 on: July 04, 2017, 09:58:49 PM »
I tried tree service logs and for me there's too much Iron in them to make money out of them.
The other thing, not two logs are the same length.
For me, I make a call and the yard fills up with all the logs I want, and sometimes more than I want. :D :D
All it takes is a lot of $$$$ to stock up.
For me, it's how fast, Or less money per BF to make lumber. I find you can get free logs,
But, If you have a lot of time into making lumber, You're not making $$$
If I spend time looking for steel or cutting to length I'm not making $$$
Way, way easier to call for wood.
A&P saw Mill LLC.
License NH softwood grader.
Price for ash logs KY, OH, WV ?
Started by Warren on Sawmills and Milling
Last post February 16, 2006, 10:01:38 PM
by Warren
Price of logs
Started by Arkyrick on Sawmills and Milling
Last post December 07, 2015, 08:45:46 AM
by Arkyrick
price of E R C logs
Started by paul case on Sawmills and Milling
Last post August 15, 2010, 01:11:13 PM
by taw6243
price on logs
Started by odouls100 on Forestry and Logging
Last post February 23, 2012, 01:20:39 AM
by shortlogger
