Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: Timberpro 830 combo  (Read 508 times)
Offline Gyland
Timberpro 830 combo
« on: July 06, 2017, 06:01:21 PM »
We have just bought a 830 combo with a Logmax 9000. It is old with 11300 hours (head 6000 hours). What is good/bad about this Timberpro?
It is the only one in my country (Norway) and no loggers have been working on a Timberpro before.
Offline Riwaka
Re: Timberpro 830 combo
« Reply #1 on: July 07, 2017, 08:16:44 PM »
There are a few changes between the TF830 and TF830B. 11 300 hours is not old if the machine has been looked after.
How will the Timberpro be used? In some some flatter terrain places with the right size trees; the TF830B can be used to fell/ process trees with the felling/ processing head. The head is then removed/ replaced for a grapple (for loading) in less than ten minutes and the fowarder can shift the logs to a truck loading area. (a one person/ one machine logging system)
http://timberpro.com/Modules/Old%20Brochures/TF810%20830.pdf
http://timberpro.com/Modules/830%20brochure/830B.pdf
Offline nativewolf
« Reply #2 on: July 07, 2017, 09:04:23 PM »
Norway has some flat spots but they are a bit wet (north sea, artic ocean, atlantic ocean)  other than that...not very flat :).
Offline Gyland
« Reply #3 on: July 09, 2017, 11:43:52 AM »
It is wery hilly i our part of Norway. So the Timberpro will work in combinaton with some small skidders (440,540,TJ 240,Kockums 822). Plan is using the cable and bring trees up/down to trail.
Timberpro is here
Started by CTL logger on Forestry and Logging
Last post February 13, 2013, 10:19:27 AM
by thecfarm
question
Timberpro TL735B
Started by BrothersMule on Forestry and Logging
Last post November 16, 2010, 09:38:28 AM
by BrothersMule
timberwolf, timberpro, does anyone out there have
Started by shakor on Sawmills and Milling
Last post December 14, 2003, 02:08:36 PM
by Neil_B
Timberpro TL735
Started by treefarmer87 on Forestry and Logging
Last post February 05, 2011, 02:47:10 PM
by treefarmer87
