BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Heart Pine Farm Table with Breadboard  (Read 2431 times)
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« on: July 07, 2017, 03:33:09 PM »
I am building a farm table for a logger friend of mine.  The boards were sawn from beams that came from an old grist mill that was dismantled.  The old growth longleaf pine is so beautiful to me.  Farm tables are popular, and many beginning woodworkers are building them from Big Box store dimension lumber.  Two problems.  One, the wood is not dry enough for furniture and a lot of issues with tabletops warping and twisting.  Plus, much of this lumber comes from small, fast grown plantation logs, and many of the boards contain the juvenile core of the tree.  The second problem is that breadboard ends are popular, but many people do not understand how to deal with the cross grain situation between the breadboard and the top.  The top is shrinking and swelling with seasonal movement one way (across the grain), and the breadboard end is shrinking and swelling in the opposite direction.  Plus, many people just glue or screw the breadboard on the end of the table preventing seasonal movement of the top, and the top splits or cracks.
I thought that I would show one way to deal with the cross grain situation created with a breadboard and still allow the tabletop to shrink and swell with changes with humidity across the seasons.
Here is the carcass of the table.  The aprons are made from the heart pine, but the legs were bought from a company specializing in table legs, and they are just regular white pine.  The legs will be stained a dark color to not clash with the beauty of the heart pine top.
Here is the tabletop before glue-up and without the breadboard.
The boards for the tabletop are only 3/4" thick, and I wanted the tabletop to appear thicker, so I glued up two 3/4" thick pieces to make the breadboards.  Once attached, the breadboard is 1 1/2" thick.  Then I glue a 3/4" strip underneath the long edge of each side of the tabletop to create a rim all the around the tabletop that is 1 1/2" thick, giving it the look that I want.
To fit the breadboard, a tongue is cut on the tabletop that will fit into a groove in the breadboard.  The breadboard is dry fitted to the top, and holes are drilled through the top of the breadboard, through the tongue on the tabletop, and through the bottom of the breadboard.  Here is a pic of the tongue on the end of the tabletop showing the tongue with one of the holes drilled through it.
Here is a pic of the breadboard with the holes drilled through it.
There are five holes in the breadboard and the tongue.  3/8" diameter walnut dowels are used to pin the breadboard to the tabletop.  Glue is applied to 1" on either die of the center hole, the dowel is driven all the way through the breadboard and the tongue, forcing any shrinking or swelling of the tabletop to the outside edges.  Those two holes on either side have no glue on the tongue.  These holes are elongated side-to-side just a bit to allow the tongue to move in the groove with any shrinking or swelling from seasonal changes.  I use a round chainsaw file to elongate the other four holes.
You want to pin the tongue to the groove in the other four holes too, but you have to keep any glue off the tongue so that it can move.  To glue the dowel to the bottom of the breadboard (to keep it from ever coming out), I turn the breadboard over and put some tape over the holes.  Then, I flip it back over and insert a narrow funnel through the top hole in the breadboard, through the space where the tongue will fit, and then into the hole in the bottom of the breadboard.  The tape keeps the glue from running out of the bottom hole in the breadboard.
Then, the breadboard is attached to the tonge, lining up the holes in the tongue and the breadboard.  The dowel is driven down through the top of the breadboard, through the tongue, and through the bottom hole in the breadboard.  The glue in the bottom hole of the breadboard coats the dowel as it moves through and pushes the tape aside.  Before dowel is all the way through the bottom hole, you stop and add some glue to the top of the dowel where if goes into the top of the breadboard.  Then you hammer it home another 3/16" of an inch or so, gluing the top of the dowel to the top of the breadboard, but no glue gets on the tongue.  This pic is of the center hole where tongue was glued to the breadboard 1" on either side of the middle hole.  You can see the glue squeeze out.  Remember, this is the only place where the tongue gets glue. The protruding ends of the dowels get cut flush with a flush cutting saw.
The dowels hold the breadboard tight to the tabletop.  Here is a picture looking at the end of the breadboard showing the joint.  It has not been sanded smooth yet.
Here is the table with the breadboard attached.
Now I have to round over the edges and apply the finish.
Offline Texas Ranger
  • Forester
  • Texan, by God and by choice.
Re: Heart Pine Farm Table with Breadboard
« Reply #1 on: July 07, 2017, 05:50:36 PM »
I made a similar table for a lady friend out of resawn beams from a 1920's hospital, light powder post beetle damage but no active bugs. They use it as a kitchen table for a log cabin of the same age on the ranch.  Seemed mighty happy as her grandmother had worked there and the lady would go there after school till her folks got home.  Reclaim history for the family.
Offline JV
  • Live - love - laugh a lot today.
« Reply #2 on: July 07, 2017, 06:14:52 PM »
Danny, I'm envious that's a beautiful piece.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #3 on: July 07, 2017, 06:17:04 PM »
Danny, since the lumber came from old beams did you still do any kiln drying to it?
Your way of crafting the bread board allowing for movement is mind blowing to me. First time I've seen this.
I'll have to say your picture really helped me understand why things that you do work.
Very good Danny.....I'm actually printing all this out for my folder. Great job my friend.
Where's the Spoon?
Offline Savannahdan
  • Retired.
« Reply #4 on: July 07, 2017, 06:49:31 PM »
Can't wait to see the final pics on this table.  How long is it?  I like the way you've installed the breadboards.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline WDH
  • Forester
« Reply #5 on: July 07, 2017, 10:16:44 PM »
David, yes, I took the boards and kiln dried them to 8%.  Dan, the table is 96" long (8') and 40" wide.  It will seat 10 people.  Two on each end and four on each side.  You figure 2' per person.
Offline Joey Grimes
  • Quality is remembered long after price
« Reply #6 on: July 07, 2017, 11:24:00 PM »
Very nice
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
« Reply #7 on: July 07, 2017, 11:40:11 PM »
Just curious. do you know what the MC was of the lumber out of the old beams after sawing? Thanks
Where's the Spoon?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: July 08, 2017, 06:19:43 AM »
Hey, I saw that table when it was only a stack of lumber.  That is probably the tightest grained SYP that I have ever seen.  ;D
Looking good Danny, but then I knew that it would.   smiley_thumbsup
Offline WDH
  • Forester
« Reply #9 on: July 08, 2017, 07:18:55 AM »
Moisture content when I got the boards from the customer was about 12% - 14%.
Offline Bruno of NH
« Reply #10 on: July 08, 2017, 06:56:23 PM »
Nice work
I like the looks of Syp
I might have to make a trip south for that and some red cedar
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline reedco
« Reply #11 on: July 08, 2017, 11:27:30 PM »
           we have  one with all of the problems you talk about. will do better next time. misses loves it  will work for now.
Not many trees
Offline WDH
  • Forester
« Reply #12 on: July 09, 2017, 07:23:51 AM »
I sell a lot of wood for Farm Tables.
Offline red
  • we will never forget
« Reply #13 on: July 09, 2017, 07:50:36 AM »
$300 , $600 & $900
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline WDH
  • Forester
« Reply #14 on: July 09, 2017, 09:58:32 AM »
Keep going.  You are shy.
Offline samandothers
« Reply #15 on: July 09, 2017, 06:38:58 PM »
Thank you for sharing your talents so we may learn from your experience and knowledge,  great looking table!
« Reply #16 on: July 09, 2017, 07:07:01 PM »
He's talking about the glue.  ;D
Where's the Spoon?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: July 09, 2017, 08:05:26 PM »
You don't pick a number, you add them up.   ;D
Offline cwimer973
  • I'm new! Wood-Mizer LT10 - Please Help Me Learn
    • Wimer Hardwoods
« Reply #18 on: July 09, 2017, 08:36:12 PM »
If those legs are hand turned I think we need $1,200, $1,500 and maybe keep going...nice job !
Your Fellow Woodworker,
- Chris
Offline red
« Reply #19 on: July 09, 2017, 09:06:40 PM »
Priceless because Danny builds these for Friends and Family.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #20 on: July 10, 2017, 05:59:02 AM »
Looking good. 8)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Jemclimber
« Reply #21 on: July 10, 2017, 11:43:57 AM »
Very nice!!!
lt15
Offline scsmith42
    • Whispering Pines Farm
« Reply #22 on: July 10, 2017, 03:11:40 PM »
That looks fantastic Danny ! (as always, too!)
Tom's 3638D Baker band mill
Offline 123maxbars
    • My Business Page
« Reply #23 on: July 13, 2017, 03:05:09 AM »
Great post Danny, nice table also,
Offline flatrock58
« Reply #24 on: July 27, 2017, 09:54:07 PM »
Nice Table Danny.  I am about to cut some nice pine for a friend to build a couple of farm tables.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline WDH
  • Forester
« Reply #25 on: July 28, 2017, 07:09:19 AM »
How thick do you plan to cut it?
Offline flatrock58
« Reply #26 on: July 28, 2017, 09:29:40 AM »
He wanted them 1 1/4".  I told him to cut them 1 3/4" and plane to 1 1/2".  We settled on 1 5/8".  Did you have problems with the rosin or did you set it in the kiln?
6' extension
resaw attachment
CBN Sharpener
Offline WDH
  • Forester
« Reply #27 on: July 28, 2017, 03:18:33 PM »
Set it in the kiln.  1 & 5/8" rough off the mill is a good thickness for farm tables.
Offline WDH
  • Forester
« Reply #28 on: August 17, 2017, 07:58:39 AM »
Table is finished.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #29 on: August 17, 2017, 08:58:39 AM »
Hey Hey Hey, that's slick and to think that I saw it when it was only boards.  Someone is gonna be very happy!
Offline Stoneyacrefarm
  • Farmer/Service manager
« Reply #30 on: August 17, 2017, 01:32:15 PM »
Nice table!!
What do I have to do to be adopted into the family?  :D
It would go well in the new log cabin.
Work hard. Be rewarded.
« Reply #31 on: August 17, 2017, 06:28:10 PM »
Now thats very pretty.....in my book.   8)
Where's the Spoon?
Offline grouch
  • I'm recyclable!
« Reply #32 on: August 17, 2017, 07:28:10 PM »
Beautiful table and work!
I've never heard of or seen that funnel trick before -- always worried about glue getting where it shouldn't. Have to try that one. Thanks!
I'm guessing the offset groove in the breadboard ends doesn't cause any trouble with expansion and contraction because the ledge it pushes against is equal above and below the groove. All the extra thickness is floating in space?
Offline Larry
« Reply #33 on: August 17, 2017, 07:34:55 PM »
Looks nice. 8) 8) 8)
Nine out of ten trees recommend wood for your building project.
Offline thecfarm
« Reply #34 on: August 17, 2017, 08:56:40 PM »
I'm happy to see it.
Offline SlowJoeCrow
« Reply #35 on: August 18, 2017, 10:59:18 AM »
That is easy on the eyes!
Wide Board Southern Pine Farm Table
Started by Lawg Dawg on General Woodworking
Last post June 07, 2016, 10:39:59 AM
by Lawg Dawg
breadboard end table
Started by Dan_Shade on General Woodworking
Last post October 20, 2007, 10:51:20 PM
by Dan_Shade
heart rot, butt-rot of hardwoods, red heart of pine i.d.
Started by caveman on Ask The Forester
Last post November 14, 2013, 10:41:34 AM
by mesquite buckeye
Heart rot or Red Heart of Pine??
Last post December 06, 2016, 09:38:38 AM
by Texas Ranger
