Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: gearmatic winch 119 trouble bleeding clutch  (Read 274 times)
Offline Pa.Logger
« on: July 09, 2017, 06:46:56 AM »
Having trouble bleeding clutch side is there any better way other than the bleeder and pumping the handle
Offline coxy
Re: gearmatic winch 119 trouble bleeding clutch
« Reply #1 on: July 09, 2017, 07:07:21 AM »
are you bleeding it at the clutch cylinder in side the winch  sometimes you can fill the master and leave the line loose for a little and the air will go out  when bleeding the master control I do it with my finger by holding it over the fitting and pumping the handle when it starts hurting your finger let off then try it again I have never had much trouble with the clutch side of the g matic its always the brake side
Offline Spartan
« Reply #2 on: July 09, 2017, 09:32:35 AM »
When I have a air problem I can't get rid of, I get my Mighty Vac and suck the fluid through.  That has worked the best for me.  I had to do it one time only on the clutch side.  Took the cover off and bled it from the slave at the clutch bands.  Then you just have minimal air to get our at your bearing area when you put it all back together.
If you can't get it that way, check for holes in lines or in the brake cups in the master and the clutch slave.  most auto parts stores have those to replace them.  1" will work I found some 1 1/32" and that was perfect.
Offline coxy
« Reply #3 on: July 09, 2017, 08:48:51 PM »
the ones you get from auto parts store  are better they are  thicker than the ones that come in the repair kit
gearmatic wench clutch.
Started by greasemonkey on Ask The Forester
Last post January 08, 2015, 04:28:57 PM
by rick f
Gearmatic 19 slipping clutch
Started by Plankton on Forestry and Logging
Last post May 15, 2016, 05:23:35 AM
by coxy
Gearmatic clutch/brake bands
Started by overtime on Forestry and Logging
Last post May 25, 2015, 07:53:01 PM
by coxy
Is there anybody on the forum that talks Peterson? (clutch trouble)
Started by Nate Surveyor on Sawmills and Milling
Last post September 06, 2010, 08:49:48 AM
by sigidi
