Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: cat 525C transmission  (Read 252 times)
Offline Pa.Logger
« on: July 09, 2017, 06:58:16 AM »
Cat 525c 2006 transmission trouble main shaft has a bearing that has no race the rollers ride on the shaft it wears into shaft now you have trouble was there any up dates for this problem or you just keep rebuilding them seems to be a lot of these for sale with rebuilt trannys
Offline Riwaka
Re: cat 525C transmission
« Reply #1 on: July 09, 2017, 08:05:19 AM »
Do a parts/ numbers enquiry on the problem area. Usually parts numbers on problem areas change - often the online diagrams etc for old models are not updated, so you have to  make a parts enquiry through a dealer back to the parts supplier to see if parts have changed/ new service bulletins etc. Repairers also use their own solutions to problems.
http://s7d2.scene7.com/is/content/Caterpillar/C577695
https://parts.cat.com/en/catcorp/PartLookup
The upgraded part for some operators is called a Tigercat or other brand machine.
Offline kiko
« Reply #2 on: July 09, 2017, 06:23:48 PM »
Pa.Logger,  I have built countless numbers of these transmissions.  The failure you describe is the least common of all on the failures I have encountered.   When this happens it usually damages the rear case as well, making the rebuild more expensive.  Usually don't see that failure where the correct transmission oil was used and serviced at recommended levels.   The majority of the failures I see are burned clutch packs that result from operators not kicking the trans into neutral while reving the engine and holding the brake to speed grapple and boom to get a drag.  A simple decluch system would have solved this. Also see torque converter lock up clutch failure which contaminates the system.  When the trans filter light comes oil, the oil is no longer being filtered and is directing contaminates directly into the control valve.
440 transmission
Started by MICKEY108 on Forestry and Logging
Last post April 07, 2015, 06:54:13 PM
by MICKEY108
need a transmission
Started by troykep on Forestry and Logging
Last post April 08, 2014, 10:00:04 AM
by troykep
518 Cat Transmission
Started by mills on Forestry and Logging
Last post October 08, 2017, 06:43:45 PM
by mills
440 transmission
Last post May 17, 2015, 08:06:19 AM
by MICKEY108
