Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: dozer tracks  (Read 988 times)
Offline coxy
dozer tracks
« on: July 10, 2017, 12:53:39 PM »
what would make the track bushings wear more on one side than the other every thing was new on both sides
Offline redneck
  • timberjack 208
Re: dozer tracks
« Reply #1 on: July 10, 2017, 02:47:42 PM »
The track could have been too tight on that side OR  I have seen some dozers that worked on the highway doing slopes that traveled the same direction too long and worn one set of chains a little more than the other.
208 timberjack 353 detroit, case 580 super K backhoe, homemade bandmill, 357xp, 372xpg
Offline willysjeeps
Re: dozer tracks
« Reply #2 on: July 10, 2017, 03:11:21 PM »
In addition to the track being to tight, the track spacers could need adjusting such that there is pressure on the bushings.
Offline coxy
Re: dozer tracks
« Reply #3 on: July 10, 2017, 04:40:43 PM »
ok you got me what are track spacers  ??? ???
Offline Riwaka
Re: dozer tracks
« Reply #4 on: July 10, 2017, 05:16:42 PM »
The dozer operator always cleaning the mud/ grit out of one side of the dozer tracks better than the other.
http://www.west-trak.co.nz/wp-content/uploads/2016/03/Undercarriage-Handbook-low-res-1.pdf
Offline coxy
Re: dozer tracks
« Reply #5 on: July 10, 2017, 05:31:45 PM »
the only time it gets cleaned is the winter or if something brakes   I'm the operator  and never had this with any other tracks
Offline willysjeeps
Re: dozer tracks
« Reply #6 on: July 10, 2017, 05:58:00 PM »
Sorry, the better word is shims, not spacers. They correct the track from tracking from one side to the other which can put pressure on the bushings. They slip in on the track adjuster and need to be checked to see if the track runs one way or the other more. Here is a generic link which shows a pic of the shims.
http://www.epsstore.com/index.php/jd-track-adjusters-gseries.html
Offline woodmaker
Re: dozer tracks
« Reply #7 on: July 10, 2017, 09:28:35 PM »
Are the sprockets worn equally,or is one worn more than the other?  Were the front idlers replaced at the same time,or is the center "ridge" higher on one or the other?
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Offline newoodguy78
Re: dozer tracks
« Reply #8 on: July 10, 2017, 09:57:32 PM »
Just a thought but were the tracks the same brand when you replaced them? Maybe the steel is different quality?
Offline coxy
Re: dozer tracks
« Reply #9 on: July 10, 2017, 10:16:14 PM »
I figured that's what you meant ;D  its like the sprocket grove is different maybe smaller where the bushing rides most of the time if the track is running off it will wear  the side of the links from the sprocket teeth chewing at it
Offline aksawyer
Re: dozer tracks
« Reply #10 on: July 11, 2017, 08:10:44 PM »
I welded up an old guys under carriage one time the right hand side was way gone.He ran it for about five more years than we put all new parts on.I think it was about six or seven years after that it needed welded up again didn't hand side way gone. We became very curious and after I watched his operations for several days at different locations found that he always sits his loader up at bottom of hills and brings all logs in and turns the dozer left hard and turns up hill to leave. After that I asked why and he said left turns are the beast way to get them close to loader.  He would really make a hard turn to get the big logs turned . I could see the track work hard on all the track rollers. The
Offline mike_belben
  • Pulp Friction
Re: dozer tracks
« Reply #11 on: July 12, 2017, 05:14:51 AM »
Stand back and look down the end of your pads for a curve, see if track frame is bent.
What do you give up when you convert a dozer from steel tracks to rubber tracks?
Started by LOGDOG on Forestry and Logging
Last post October 25, 2010, 10:58:04 PM
by Mooseherder
653 Allis dozer Torque found, dozer running again!!!!!!!!!!!!!!!!!!!
Started by Striker on Wanted
Last post December 01, 2005, 03:27:05 PM
by tnlogger
ATV Tracks
Started by mitchash on Forestry and Logging
Last post April 17, 2006, 08:33:18 AM
by HARLEYRIDER
Eco tracks
Started by JustinW_NZ on Forestry and Logging
Last post October 23, 2014, 11:48:57 PM
by 1270d
