Arborwear
Author Topic: Questionm on poplar logs  (Read 875 times)
Offline Downstream
« on: July 10, 2017, 08:10:31 PM »
I have two poplar logs to saw for my own use.  they are each 76"long and approx 24" diameter both pretty straight with little taper.  Normally I live edge cut slabs 2 or 2-1/8 thick for use in rustic live edge furniture.  Wondering if I should cut to 5/4 and use for indoor projects only.  Not sure how poplar will last outdoors or what the grain will look like with clear finish or natural oil finish.  Comments from anybody?
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook
Offline cwimer973
  • I'm new! Wood-Mizer LT10 - Please Help Me Learn
    • Wimer Hardwoods
Re: Questionm on poplar logs
« Reply #1 on: July 10, 2017, 09:18:56 PM »
Just gave my dad 4 boards all ~1" thick and 6 footers, he made a planter.  It is so light I would cut 2.5" thick and then resaw when needed.  The 2.5" seems to be the smallest thickness that my customers want for rustic shelves that they attach the Home Depot pipe fittings to.
Just my opinion but if you have lots of space cut a little of everything, the poplar stacks blow over before maple in my next of the woods :)
Your Fellow Woodworker,
- Chris
Offline samandothers
« Reply #2 on: July 10, 2017, 11:37:17 PM »
Would not think poplar to hold up as a planter. Have you cut one before or make special provisions to protect?
Offline cwimer973
    • Wimer Hardwoods
« Reply #3 on: July 11, 2017, 11:52:43 AM »
They are for condo associations where plants do not come inside and are just used for the season. Dump dirt, flip and stack inside garage, repeat next year.
- Chris
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #4 on: July 11, 2017, 12:37:59 PM »
Poplar is not a bad wood outdoors IF used for board and baton. It will last for years.
I watch BARNWOOD BUILDERS on cable TV and have actually seen Poplar hand hewn logs over 100 years old.
But using Poplar for outdoor planters, outdoor furniture and other projects, I would not recommend.
It is a hardwood but the softest of hardwoods.
As far as what the grain will look like.....from my experience you never know what you will get.
Here are 4 boards I sawed the other week. The next log I sawed lumber out of looked nothing like this.  :D
Poplar will give several different colors when sawn from all clear to green, brown, purple, orange and yellow.
But after drying it all generally turns the color of light brown.
Most of my Poplar is sold to cabinet makers for backing.
Where's the Spoon?
Offline drobertson
« Reply #5 on: July 11, 2017, 07:23:43 PM »
Poplar as with any other specie in regards to what to saw and how to saw it really boils down to the end purpose. I would say regardless of intentions be sure to flip the log/cant maybe every cut. Most I've seen just has inherent stresses. And most likely going for a target of 8" wide for 4/4, 5/4, would fair the best.. JMO,, sticker stack with weight, unless going up on a shed or barn right away.
(Poplar) POPLAR SAW LOGS
Started by thumper on Forestry and Logging
Last post February 21, 2010, 08:28:13 AM
by thecfarm
poplar logs
Started by peterob on Sawmills and Milling
Last post January 29, 2014, 07:57:12 PM
by peterob
looking to buy some logs poplar ?????
Started by bikedude73 on Timber Framing/Log construction
Last post January 13, 2011, 05:52:55 AM
by Jeff
poplar logs for a cabin
Started by ryguy777 on Timber Framing/Log construction
Last post March 17, 2013, 11:07:37 PM
by D L Bahler
